To big brakes, or not to big brakes. - The Saab Link Forums
Old 08-01-2012, 06:30 PM   #1
PimpMyPc's Avatar
Brakes are pretty much toast at this point, looking at replacement.
Is it worthwhile to source some viggen / 9-5 aero calipers and carriers, or just get some really good stock sized brake hardware? Car is a 176k 9-3 coupe.
PimpMyPc is offline
Old 08-01-2012, 06:38 PM   #2
gm
gm's Avatar
Love my big brakes on my viggen, huge improvement over stock viggen brakes. The rear I went with the 9-5 aero brakes.....
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 08-01-2012, 06:51 PM   #3
BALDSAAB's Avatar
is the ebrake affected when you switched calipers
2002 saab 9-5 JZW STAGE 5
2001viggen 5 door
2000 saab 9-3 vert jzw stage 5
sold parted out
1972 nova 396 BB
2008 LINCOLN MKX ELITE
BALDSAAB is offline
Old 08-01-2012, 07:04 PM   #4
secret ingredient's Avatar
I know on the ng900 you do, should be roughly similar to the 9-3. I just flipped the bracket that holds the ebrake spring, and that was it.
1983 900 8v turbo- sold
1998 900 SE- sold
1995 9000 CSE
secret ingredient is offline
Old 08-01-2012, 07:22 PM   #5
PimpMyPc's Avatar
So you just got 9-5 Aero rears? IIRC, the Aero fronts are the same as Viggen.
PimpMyPc is offline
Old 08-01-2012, 07:56 PM   #6
srp
srp's Avatar
Send a message via AIM to srp
Front Viggen/Aero calipers and rotors are a great bang-for-the-buck improvement. Add some Hawk pads and a full brake fluid exchange and your good to go. Want to go a little further, grab the Aero vented rear setup and some stainless brake lines. That's what I have along with koni/vogtland springs. The car stops hard and flat, and has great balance.
srp is offline
Old 08-01-2012, 08:09 PM   #7
PimpMyPc's Avatar
Weird, the brakes were done on my car by the previous owner about 25k ago. Stopping power just isn't there. Also doesn't help I have 176k dampers on the car, nose dives on braking and shoots for the sky on acceleration.
PimpMyPc is offline
Old 08-01-2012, 08:20 PM   #8
srp
srp's Avatar
How are your rear calipers? Make sure they aren't frozen.
srp is offline
Old 08-01-2012, 09:15 PM   #9
gm
gm's Avatar
I have ap racing racing front brakes on my car.
A good set of pads do help out a lot with stopping power, not as good as a big brake kit but good pads do help.
If money is tight and if your suspension is stock w/o a doubt..... At least buy some new shocks for your car, preferably with springs and just buy some good pads for stopping better. Depending on the tires you run just a good set of pads might be at the limit of your tires....
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 08-01-2012, 10:08 PM   #10
fiveiron9688's Avatar
You haven't been in my car when I get on the brakes, have you? I have Viggen fronts with HPS pads, stock size rears with EBC Redstuff, stainless steel brake lines and super blue fluid. And it's way better. I actually think the SS braided lines were the best part of the upgrade.
1998 900 SE turbo convertible
fiveiron9688 is offline
Old 08-01-2012, 10:31 PM   #11
Yes, do the upgrade. It's worth it. Also do you still have good feel in your pedal? Maybe the brake fluid is cooked (old)? Master cylinder calling it a day?
Thanks,
Joe Reichard
10 Saabs
1 Mercedes
Complete Addict.
Slow Joe is offline
Old 08-01-2012, 10:48 PM   #12
PimpMyPc's Avatar
Going to bleed some brakes and see what happens. Pedal is solid, more solid than my Taurus. But I can just stand and put all the force I can muster on the pedal, the car nose dives bad but no ABS and the speedo just creeps down. Pedal remains firm/doesn't sink or get spongy. Stomping on the Taurus or any other car in my family yields my face in the dash and ABS pumping something fierce.
Granted I am running those really sticky hankooks, but I would expect stomping the crap out of the pedal to yield some ABS work.
What car am I really jealous of the braking power of? My dad's 2010 Ford Fusion Hybrid. The thing is a tank, and extra heavy at the curb from the massive battery pack in the trunk and all the traction motor bs under the hood but literally stops on a dime. One time I had to do a double foot stomp for deer in that thing and holy shitsnacks. The regenerative braking plus hydraulic brakes working in tandem caused me to brace as much as I could on the steering wheel to keep the seatbelt from cutting me in half and after I stopped I thought I was going to puke.
PimpMyPc is offline
Old 08-02-2012, 06:47 AM   #13
lms
Brakes can never be to big, but some kits require bigger/different off set wheels. If you have the money, go for it.
lms is offline
Old 08-02-2012, 07:20 AM   #14
viggenkid's Avatar
I'm betting that there is something wrong with his stock system. Even the small stock brakes have enough stopping power to lock up/engage abs at least once. Remember bigger brakes become a great advantage when high speed, continuous, or repetitive hard braking comes into play.
If I were you I would take a good look at my pads, calipers, and rotors. My money is on one or more seized calipers and/or an issue with your brake master/booster.
viggenkid is offline
Old 08-02-2012, 07:44 AM   #15
If the car is an automatic 9-3, the vacuum booster on the right end of the head might be failing. Bad braking is an early symptom of that.
Old 08-02-2012, 08:37 AM   #16
Marks9-3's Avatar
This.
Marks9-3 is offline
Old 08-02-2012, 09:09 AM   #17
PimpMyPc's Avatar
3 Pedals and 5 speeds here. Can't rule out the master cylinder itself but the booster is good, holds vacuum for some time and can get a couple pumps before its rock hard.
PimpMyPc is offline
Old 08-02-2012, 09:11 AM   #18
srp
srp's Avatar
Don't just bleed. Do a full fluid exchange.
srp is offline
Old 08-02-2012, 09:54 AM   #19
Passenger 57's Avatar
Viggen/Aero 308mm front brakes & 9-5 Aero 300mm vented rears require at least 16" rims. You will also need a 16" spare. Worth wile upgrade.
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.
Passenger 57 is offline
Old 08-02-2012, 10:13 AM   #20
PimpMyPc's Avatar
Have a full set of 17in OZ Racing rims. There's plenty of gap around the rotors LOL.
PimpMyPc is offline
