need ideas to why my car is base boosting - The Saab Link Forums
Old 07-05-2012, 04:24 PM   #1
Easily's Avatar
took off a GOOD BPC off of turbojohnny's vert
put on my car
and it base boosts.
i'm lost.
Timothy Morath
97 saab 900se
99 9-3
Easily is offline
Old 07-05-2012, 04:30 PM   #2
lms
What else have you tried, how's the wastegate?
lms is offline
Old 07-05-2012, 05:05 PM   #3
turbojohnny's Avatar
the car has been boosting fine without the bpc, it just hits fuel cut
because he drives like a fuck
turbojohnny is offline
Old 07-05-2012, 06:39 PM   #4
NahumCC's Avatar
Have you checked all your brake lights? As odd as it sounds after I got hit I was stuck at base boost and after having T/S for a while we eventually found that a bulb had gotten dislodged and completed the circuit making the car think I was riding on the brakes.
Just a quick 2 minute check there.
2013 FR-S
NahumCC is offline
Old 07-06-2012, 09:26 AM   #5
Easily's Avatar
kids mad im faster
Timothy Morath
97 saab 900se
99 9-3
Easily is offline
Old 07-06-2012, 10:43 AM   #6
Originally Posted by Easily View Post
kids mad im faster
Not if you only have 5 PSI boost.
Old 07-06-2012, 10:49 AM   #7
Harvey's Autohaus's Avatar
Try another DI.
HakbarSAABzzz
Harvey's Autohaus is offline
Old 07-06-2012, 11:16 AM   #8
lowbudgethero's Avatar
try MBC, to figure out if your computer is pulling boost back or not
lowbudgethero is offline
Old 07-06-2012, 12:08 PM   #9
with the bpc disconnected, he has full boost. 20+psi it boosts until he hits fuel cut.
with the bpc connected and running, it boosts to 5psi only.
Old 07-06-2012, 05:36 PM   #10
What Harvey said.
Your turbo is OK
Your wastegate is OK or at least closed
Your wastegate starts out closed. With the BPC and the ECU controlling it, it's being told to open. So the real question is why the ECU thinks it needs to cut boost and open the wastegate.
If your DIC was bad, that might do it. Swap with jonny and see what happens.
BobSabbert is offline
Old 07-07-2012, 08:52 AM   #11
Easily's Avatar
going to swap it out
Timothy Morath
97 saab 900se
99 9-3
Easily is offline
Old 07-07-2012, 09:25 AM   #12
Easily's Avatar
swapped the di, still base boosts.
Timothy Morath
97 saab 900se
99 9-3
Easily is offline
Old 07-07-2012, 10:32 AM   #13
Check to see if the 7.5 AMP APC fuse in the engine compartment fuse box is blown.
It could indicate bad mosfets in your ecu. that fuse blew in my car every time I replaced it until I soldered new mosfets in my ecu. What stage 3 tune do you have?
Whilhelm is offline
Old 07-07-2012, 10:38 AM   #14
the tune is from Casey, Brew City Boost
Old 07-08-2012, 09:13 AM   #15
Easily's Avatar
fuse isnt blown, im going to clean the bpc today.
Timothy Morath
97 saab 900se
99 9-3
Easily is offline
Old 07-08-2012, 09:27 AM   #16
NahumCC's Avatar
Have you checked your brake bulbs in the back. I went down the same road you are chasing right now. It will only take you 3 minutes to make sure all your bulbs are good and not possibly grounding out the brake circuit which would make the BPC give you base boost.
2013 FR-S
NahumCC is offline
Old 07-09-2012, 02:56 AM   #17
we went through the other day and looked at all of his bulbs. they're all functioning properly.
