264 Cams, set to TDC, but not degreed...Kaboom? - The Saab Link Forums
Old 05-16-2012, 01:56 PM   #1
Can I run the car like this, or will it cause interference?
Should I wait and have the cams professionally degreed before starting the engine?
Old 05-16-2012, 02:04 PM   #2
DrewP's Avatar
Do they have the alignment tick marks like stock cams?
You can accidentally assembly the timing with either sprocket advanced or retarded a tooth and not bend the valves (constant threads on SaabNet confirm how many people get the timing off and it just makes the engine run funny).
If there aren't any tick marks to get them close to timed I wouldn't risk it though until you can get a dial indicator on them.
DrewP is offline
Old 05-16-2012, 02:09 PM   #3
Yep, They're Enems that have the alignment marks set to TDC like the stock cams, and they're matched with the crank. I hand rotated the crank twice to check for any odd noises or misalignment and it looked OK...
Old 05-16-2012, 02:21 PM   #4
Harvey's Autohaus's Avatar
Just go ahead & Dial the cams in on no4 cyl first. Then rotate 180 & make sure the measurment you set 4 to is excactly the same as No1. if it is. Your done
HakbarSAABzzz
Harvey's Autohaus is offline
Old 05-16-2012, 03:03 PM   #5
What is that paying these days? & Who does that?
HakbarSAABzzz
Old 05-16-2012, 03:05 PM   #6
LOL....I figured it was probably worth an hour's labor for my peace of mind.
I'm just going to start the fucker and see what happens.
Old 05-16-2012, 03:12 PM   #7
Pat is alot closer to you than I am. He also own's one of those Voodoo things with the Fancy pointer & Dial.
HakbarSAABzzz
Old 05-16-2012, 04:21 PM   #8
So...double checked the cams...looked good...
Disconnected the fuel pump fuse to crank over a few times to build oil pressure. Reconnected the fuel pump fuse and fired it up...
After a couple of false starts it roared to life with a shit load of smoke from the old gas, and I cheered wildly!!!! No nasty clanks.
And then I noticed the puddle of oil growing under the car dripping from the clutch housing.
Fuck.
Rear main seal.
Dashed to the store for kitty litter and now it's time for scotch, no ice, in a tumbler glass.
Old 05-16-2012, 04:42 PM   #9
SPG-GASM's Avatar
Skip the glass and go straight from the bottle.
SPG-GASM is offline
Old 05-16-2012, 05:25 PM   #10
Scotch is going down quite easy with these: GLACIER ROCKS - For Men - Gifts
All the cooling, none of the dilution. I'm about half a tumbler into what my wife calls "recession scotch" but I don't really care.
I checked and saw that I actually have a spare rear main seal still in the Eeuroparts packaging, so I don't have to worry about that. I just need to find to time to put the bastard in...
EDIT: Kitty litter is stupid. Make the feline fuckers use the grass outside like dogs.
Old 05-16-2012, 07:21 PM   #11
yllwJet's Avatar
the car will definitly run on the stock setting for 264 but no where near the cams potential. the 276 enem cams will interfere with the pistons if you run them at stock settings. they need to be degreed for proper usage
hahaha ill finally get to use it again. id be more than happy to degree someones cams, dont get to do that too often haha
yllwJet is offline
Old 05-16-2012, 07:43 PM   #12
JK
JK's Avatar
Ha! I saw your previous post and was going to suggest those. Looks like you're all set though!
I love 'em!
always a SAAB guy at heart
JK is offline
Old 05-16-2012, 11:34 PM   #13
bogan's Avatar
Good luck with your rear main seal.
Mine is still hold up (touch wood)
bogan is offline
Old 05-17-2012, 02:55 AM   #14
Cark's Avatar
whiskey rocks are the shit! Always help take the edge off. Only problem I found (if you can call it that) is the scotch disappears a lot quicker since it doesn't get watered down with the melted ice...
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 05-17-2012, 03:27 AM   #15
DanF.'s Avatar
What kind of scotch? I'm more of a whiskey person, and enjoy that Jameson 12 year, neat.
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1987 900 SPG parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 05-17-2012, 04:20 AM   #16
bogan's Avatar
You got any pics of your car Mike?
bogan is offline
