Lighten up my flywheel - The Saab Link Forums
Old 05-14-2012, 02:18 AM   #1
bogan's Avatar
Hey there all,
I'm pulling out my gearbox again in a few weeks, my viggen clutch disk shit it's self.
I'm going to try a 6 puck.
I'm going to get the fly wheel machined again and thought I might get a bit of weight taken of the back.
Does anybody how much I can get taken off without causing any drama?
Has anybody else done this?
Cheers
bogan is offline
Old 05-14-2012, 05:55 AM   #2
A couple of folks have had the flywheel milled...You can easily shed a few pounds off the back. There's a raised center portion that makes no sense, except to add mass for smooth shift transitions.
Old 05-14-2012, 12:34 PM   #3
Originally Posted by bogan View Post
Hey there all,
Cheers
In what way? I ask because I have reason to suspect my viggen PP/disk is failing with the stg 5+ tune. I have to figure out if it's the tires or clutch that is slipping at higher revs-hard to tell...
-Cm
Cm452 is offline
Old 05-14-2012, 11:56 PM   #4
bogan's Avatar
-Cm
My Viggen disk/pp slipped last weekend.
If its your clutch that's slipping you get a filthy smell of the disk (like stinky pussy)
bogan is offline
Old 05-15-2012, 04:58 AM   #5
mike d's Avatar
i usally lighten ng flywheels 4-6lbs,, i think thats the sweet spot. If you go to light the car sucks to drive
Mike
MikeDTuning.com
mike d is offline
Old 05-16-2012, 04:36 PM   #6
I had about 5 pounds shaved off my non-vig b204 IIRC. No drama in the last 30k miles.
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 05-16-2012, 11:41 PM   #7
bogan's Avatar
Mike
Hey Mike, please excuse my noobness,
Why does the car suck to drive if the flywheel is to light?
What happens?
Thanks guys, That's what I wanted.
I'll go 5lb
bogan is offline
Old 05-17-2012, 03:31 AM   #8
DanF.'s Avatar
I think the revs will drop too fast, and you'll have to constantly be rev-matching the gear-changes. I'm just guessing.
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1987 900 SPG parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 05-17-2012, 03:02 PM   #9
bremund's Avatar
Bingo
Lightening the flywheel makes a turbo car rev faster and so come on boost faster, however the opposite will also happen i.e. revs drop quicker and you a quick drop off of boost which make gear changes suck.
Motorsport; because Golf, Soccer and Rugby only require 1 ball.
1978 99 Turbo
2000 9-3 Viggen
2002 RenaultSport Clio
2005 Suzuki Grand Vitara
bremund is offline
Old 05-17-2012, 03:06 PM   #10
bremund's Avatar
I should add, the lightness of the flywheel should be proportionate to the time spent at WOT. e.g. a drag car sill have a super light flywheel (as always at WOT). However a car you drive on the road won't spend that much time at WOT (traffic, etc).
1978 99 Turbo
2000 9-3 Viggen
bremund is offline
Old 05-18-2012, 02:41 AM   #11
bogan's Avatar
That's good info Brendan.
Maybe I should just leave my flywheel standard ?
After all, it is just the car that gets me to work and back.
Or as mike D & poison beef added 5lb's is the sweet spot ?
Thoughts....
bogan is offline
Old 05-18-2012, 06:44 AM   #12
mike d's Avatar
when the flywheel gets too light, you also have to rev it very high to start from a stop, hill starts become a royal pain,, This will lead to you burning out your clutch quicker as well
MikeDTuning.com
mike d is offline
Old 05-18-2012, 07:08 AM   #13
viva_brasil's Avatar
I have a fidanza lightweight flywheel on my previous car (fiance's car now) and it is great - heavy flywheels help make driving smoother but the engine feels much less responsive.
Revs do drop faster but just tap the gas lightly to bring them back up - you'll get used to it and the responsiveness is more than worth it.
I'd say the clutch affects drivability much more, like my 9-3 with a stage 3 clutch and stock flywheel is more "difficult" I'd say compared to a lightweight flywheel and stage 1 clutch car...
viva_brasil is offline
Old 05-18-2012, 08:36 AM   #14
lowbudgethero's Avatar
I have the lightweight spec flywheel and standard viggen clutch and it revs quite nicely while still being able to start relatively easy. I do notice coasting in neutral does require more of a blip from the throttle to get back into gear, but that's not really a big deal imo.
However, people at the inspection station always stall it multiple times.
lowbudgethero is offline
Old 05-18-2012, 09:58 AM   #15
lms
I have a fidanza as well and what is good about those wheels is that they have a steel friction plate which is replaceable.
lms is offline
Old 05-18-2012, 11:07 AM   #16
DanF.'s Avatar
You will usually hear that shaving a few pounds off the back of the flywheel doesn't produce that much of a difference is driving characteristics. So I'd look at that as an option.
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 05-18-2012, 03:09 PM   #17
bogan's Avatar
I'll do that
bogan is offline
Old 05-18-2012, 04:06 PM   #18
If you like to heel and toe get a spec flywheel or equivalent. I personally prefer a light fly, and enjoying banging through the gears on a twisty road.
Drifting-FB is offline
Old 05-20-2012, 04:25 AM   #19
Jaws's Avatar
Removing the balance chain also makes it like having a light fly so I wonder how it is to have both light fly and no balance chain? Never been much of heal and toe guy but I am starting and I really nailed it the other day. I find I need good shoes (Pilotis).
Jaws is offline
Old 05-22-2012, 07:40 AM   #20
8valvegrowl's Avatar
I took 4lbs off my stock flywheel when I installed a Viggen Clutch/PP combo on my Stg3 B204. It revs noticeable faster and is perfectly streetable.
A tad more revs required on a hill start and a touch of gas on the down shifts. But, I have always tended to heel/toe my shifts.
I spent $80 to have the flywheel resurfaced and lightened. The Fidanza was around $400. No way was that worth it unless you are building a race car, and we all know how silly NG900/OG9-3 race cars are.
8valvegrowl is offline
