Stage 6 build - SC44 turbo, custom up-pipe, etc. - The Saab Link Forums
Old 05-06-2012, 12:07 PM   #1
viva_brasil's Avatar
Decided to get a thread started for this build I've been working on. My goal is to finish it by May 18th so I can take the car up to the first New England Hill Climb event of the year.
This car had a td04-19t when I bought it, now that it started burning oil I decided to go with something else. Below is a list of what is being done:
- Precision Turbo SC44 (similar specs to a HY35)
- Saab 9000 T3 manifold
- Top mount up-pipe from manifold to turbo
- Precision 39mm external wastegate
- 28x8x3.5" intercooler and 2.25" charge pipes
- 3" downpipe
- Viggen brakes
Other supporting hardware - 3 bar map sensor, 630cc Dekas, and walbro pump, and a tune by Mike D.
Day 1 - pulled the td04, manifold, oil and water lines, dropped the JSP downpipe
viva_brasil is offline
Old 05-06-2012, 12:09 PM   #2
Pic of some of the hardware:
Some fab work - new 3" top mount downpipe and up-pipe
Mounted turbo and intercooler - fitment is perfect, may have to remove hood liner as compressor is pushing up against it.
Had to grind the T3 manifold on the edge to clear:
Old 05-06-2012, 12:11 PM   #3
Finished pics:
Old 05-06-2012, 12:33 PM   #4
Wondering what size spring to use with the external wastegate - anybody using an EWG or have any input?
Old 05-06-2012, 05:58 PM   #5
comtrang's Avatar
What spring do you have in it now?
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 05-06-2012, 06:39 PM   #6
saabkid37's Avatar
New England hill climb?
saabkid37 is offline
Old 05-06-2012, 06:42 PM   #7
SevierSaabOG93's Avatar
what are your plans for the 19t?
SevierSaabOG93 is offline
Old 05-06-2012, 06:57 PM   #8
KPAero's Avatar
Very cool, looks like you have some nice stuff going in. Ill also be at Ascutney with my 85' SPG.
KPAero is offline
Old 05-06-2012, 06:58 PM   #9
KPAero's Avatar
New England Hillclimb Association (NEHA) - www.hillclimb.org
KPAero is offline
Old 05-06-2012, 07:37 PM   #10
For the wastegate spring - I have what it came with in it (I think the smallest - 2 psi - spring), plus 3 other springs. I was planning on running 11psi (which is 2 springs together) but not 100% sure. I may run like 2 psi or something while it's on the 19t tune and then install the 11psi spring for the new tune.
Mike D will be acquiring my 19t turbo.
Nice - KP have you taken your car to DSG? I was there for other stuff and they mentioned a crazy caged SPG that runs at NEHA events.
Old 05-06-2012, 09:27 PM   #11
comtrang's Avatar
Interesting idea, making an up pipe. I'm curious to see in what way that affects spool.
I'm using a .7 bar (~10psi) spring in my Tial V44 and that's worked fine for me. No issues controlling boost with T5suite.
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 05-07-2012, 03:29 AM   #12
lms
Very cool, but get some light in that shop.
lms is offline
Old 05-07-2012, 04:10 AM   #13
Greek Mod
grkguy89's Avatar
wish i had thought of doing an up pipe....
i wouldve had a holset right now instead
who knows, maybe on the next setup i build?
Current Activity: Moderating
grkguy89 is offline
Old 05-07-2012, 04:26 AM   #14
Curious...What are the benefits of the up pipe?
And I just looked at the NEHA site and the SPG driver is Pascal Belperron. He has a lot of vids on YouTube
Old 05-07-2012, 05:37 AM   #15
Mike - I wanted to keep A/C so with a bottom mount set-up the turbo would have to be mounted with the DP on the A/C side, which would be less than ideal for the DP, and the intake would be on the right and crossing over to the left to get to the intercooler (could have used a right side in/out intercooler). Would have to replace the fan with a slimmer one.
Overall I wanted more space for the downpipe, oil lines, keep A/C, use an external wastegate and best flow for the intake and exhaust sides.
Also curious to see what it does to spool. The diameter is 2" but the wall thickness is .14" so internal diameter is about 1.72".
Old 05-07-2012, 05:49 AM   #16
The car is in a public garage, I have a battery-powered black and decker light which works well but not a lot of options... The other shop I use for welding/machining is a place called Artisan's Asylum.
Old 05-07-2012, 07:34 AM   #17
Send a message via AIM to KaMiKaZi_t0M
That up-pipe is a new one. I'm HY35'ing my 9000 and I would also like to keep the AC. If clearance is a problem I may take a page out of your book...
KaMiKaZi_t0M is offline
Old 05-07-2012, 12:06 PM   #18
DanF.'s Avatar
Cool project!
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1987 900 SPG parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 05-07-2012, 12:08 PM   #19
DanF.'s Avatar
A/C compressor would probably be an issue on a 9000 with an up-pipe. I have no evidence to support this other than cocking my head sideways while looking at my engine bay.
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 05-07-2012, 12:40 PM   #20
Ahhhh....I just saw the angle of the turbine-side flange that you can't just reclock the turbo. This looks like a pretty elegant solution to the problem....and a really kick-ass project in general.
Four thumbs up on this one....
