MTF equivalents... - The Saab Link Forums
Old 04-25-2012, 04:52 AM   #1
mdegracia's Avatar
MTF equivalents...
Topping off the MTF and need another liter...
Does anyone know if the GM Saturn MTF fluid (pn 21018899) is the same equivalent to the Saab 0063 (pn 93165290) fluid?
Both are BOT 0063, so I am thinking they are equal.
Thanks,
Matt
2010 Ducati 1198s
2003 Audi RS6 Revo Stage 2 (515/500)
2000 Audi A6 Avant (For Sale)
2000 Viggen-JZW tuned GT3071 .64A/R topmount
1998 Dodge Quadcab-Kenne Bell SC
mdegracia is offline
Old 04-26-2012, 02:54 PM   #2
watkins's Avatar
Send a message via AIM to watkins
I recently learned that Dex IV should be a good substitute for MTF 0063
watkins is offline
Old 04-26-2012, 03:10 PM   #3
Harvey's Autohaus's Avatar
O63 works great in the winter, Its Water thin, Flows great. Thats why I don't use it. When Saab switched to 063 I watched the service life of Normal use & especialy hard use Bearing failures multiply. I think it has more to do with if you are Over or Under the mason dixon line, Cold climate use 063, For Warm climate, I Use Gm or Penzoil Syncromesh, For a tuned car under much higher torque loads, Use the syncromesh, Your trannys will last longer. Just my opinion.
HakbarSAABzzz
Harvey's Autohaus is offline
Old 04-26-2012, 03:25 PM   #4
DanF.'s Avatar
I concur.
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1987 900 SPG parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 04-27-2012, 03:59 AM   #5
Turbo00's Avatar
I haven't been blown away by 063 since switching, but yes, winter was much smoother while cold. May look into the above suggestions, tx
Turbo00 is offline
Old 04-27-2012, 07:11 AM   #6
yllwJet's Avatar
synchromesh
yllwJet is offline
Old 04-27-2012, 07:33 AM   #7
mdegracia's Avatar
Thanks guys.
I ended up putting in redline mt-85, @ $11.25 a quart, I couldn't complain!
2010 Ducati 1198s
Old 04-27-2012, 09:47 AM   #8
PimpMyPc's Avatar
Running mt-90 in mine. Shifts way better than 063.
PimpMyPc is offline
Old 04-27-2012, 11:51 AM   #9
Fu&* 063. I paid for it x3 following the Saab flush procedure. Was a real waste of dough. Regret.
BuHuSPG is offline
Old 04-27-2012, 02:54 PM   #10
bogan's Avatar
I run MT-85 at mo.It works great, but is real thin
Next change I'm going to run MTL. Its just a bit thicker and is meant to be the equivalent to syncromesh.
MT-90 is just a bit to thick in my opinion. Have heard reports that shifting is real hard at cold but gets better as it warms up.
I can't get Pennzoil syncromesh over here.
bogan is offline
Old 04-27-2012, 03:42 PM   #11
You should be able to get it at a Holden dealer. I'll see if I can dig up the GM part no.
Ask for "GMSMFM'' fluid or Friction Modified Part #10953509, or 12377916, Honda guys love it too.
HakbarSAABzzz
Old 04-27-2012, 05:09 PM   #12
bogan's Avatar
Thanks Harvey, Nice work
bogan is offline
Old 04-27-2012, 05:16 PM   #13
Found this about it too, ""A post on the message board at Machinery Lubrication Magazine Home found Synchromesh to consist of a 5W30 non-detergent oil with a friction modifer and an EP (extreme pressure) additive. It is made under contract for General Motors by Pennzoil (APC 337 or by Texaco (Code 1874 MTX Fluid)."
HakbarSAABzzz
Old 04-27-2012, 05:24 PM   #14
bogan's Avatar
I wish I lived next door to you Harvey.
I think I would become annoying tho
bogan is offline
Old 04-28-2012, 05:24 AM   #15
This is a great thread...
I just added 0063, but I think I'll keep it in for a month or so as a flush, then dump it for Synchromesh...
Old 04-28-2012, 06:21 AM   #16
Greek Mod
grkguy89's Avatar
Ya ever since Harvey told me about Synchromesh, my trans felt smoother and sounded better
Current Activity: Moderating
grkguy89 is offline
Old 04-28-2012, 06:29 AM   #17
Drew in Houston's Avatar
I've been thinking about trying some of this stuff: AMSOIL - Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 (MTG)
edit: It seems to be recommended for some of the same applications as the MT-85. Hmm. Anyone ever try it?
Drew in Houston is offline
Old 04-28-2012, 12:56 PM   #18
Two questions:
Is the Penzoil Syncromesh the same as the GM product?
Anyone used the Syncromesh in the Winter in the Northeast? I noticed that even with the 0063 that my first shift out of first gear was a little tight in the Winter. After the first one, it was smooth sailing.
BobSabbert is offline
Old 04-28-2012, 07:24 PM   #19
bogan's Avatar
The GM oil is made by Pennzoil.
bogan is offline
