Will it fit? (Intercooler) - The Saab Link Forums
Old 03-31-2012, 11:14 AM   #1
I know there are a million threads about this, but haven't seen one with this size.
28"x9"x2.75" -- Will it fit behind my ng900 bumper?
Shaner3721 is offline
Old 03-31-2012, 11:56 AM   #2
comtrang's Avatar
No, 9" is too tall
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 03-31-2012, 12:49 PM   #3
StoneSilver's Avatar
https://www.saablink.net/forum/genera...tion/59758.htm
2000 9-3 SE - BCB Tuned
2008 Evo X GSR
Now the Car Gods @ DOT are gunna come Smack your PE PEE
StoneSilver is offline
Old 03-31-2012, 03:46 PM   #4
Half way through this thread it is stated that 9" would fit...
Old 03-31-2012, 04:03 PM   #5
bogan's Avatar
9' would be to high.
I have a 7' in mine and 8' would be the max.
But you need to raise the AC receiver dryer *Carefully*
bogan is offline
Old 04-01-2012, 05:34 AM   #6
I posted the original thread. The guy who made the comment about the 9" IC posted that he was going to try a 9' one, but I don't think he ever posted whether he was successful or not.
You don't want the IC to dip below the bottom of the front radiator support crossmember, which is where the plastic undertray mounts -- and where you'll have a little bit of protection from curbs and parking wheel stops. Even though a bar-and-plate IC is pretty robust, it's still made of aluminum and you don't want to ding it too hard against something concrete.
Several people have relocated or deleted the AC dryer components, and then ran much taller ICs.
EDIT: With a stock setup, you're limited by the 8.25-8.5" distance between the AC receiver dryer at the top, and the oil cooler hard lines at the bottom. If you remove the oil cooler lines, you might be able to squeeze a 9" IC into the space. An 8" IC is a more common size, so you'll have more luck finding suitable width and length combos.
EDIT: If big power is in your plans, then you might want to consider AC dryper removal since you'll probably be ditching the AC system anyway. If that's the case, you can remove the AC condenser coils (smaller radiator in front of the actual engine radiator) and run a 4" thick core that's 18" high. One of the guys in Finland did that with his 500+ whp car.
EDIT: Also....a 28x8x3 IC is more than enough for nearly any turbo you're going to use with a street car. Consider that a reasonable upper size limit. Even coming down a few inches in length would still provide ample charge air cooling, have less of a pressure drop, and would be easier to fit.
Old 04-01-2012, 06:48 AM   #7
Greek Mod
grkguy89's Avatar
28x8x3.5 | eBay
now pick one that is actually a bar and plate intercooler
edit: there are only two and they are bout $115
Current Activity: Moderating
grkguy89 is offline
Old 04-01-2012, 12:15 PM   #8
This is why I am asking...
Old 04-01-2012, 01:18 PM   #9
It likely WILL NOT fit in a stock setup. It will probably dip down below the lower radiator cross member. You'll have difficulty refitting the plastic undertray. Your intercooler will have its bottom vulnerable to dings.
It WILL fit if you relocate your AC dryer OR you can remove or relocate your oil cooler lines.
There's a reason both the Forge and ETS units are the dimensions they are.
Old 04-01-2012, 02:23 PM   #10
comtrang's Avatar
CXRacing INTERCOOLER 28x8x3.5 Talon Civic RX7 CRX Supra | eBay
Buy this one.
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 04-01-2012, 02:50 PM   #11
DanF.'s Avatar
First post...
Asked and answered in following post. Awesome.
Edit: more "A's"
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1987 900 SPG parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 04-01-2012, 04:26 PM   #12
turbojohnny's Avatar
I hate to be an ass, and so critical. but there is a big difference between the annotation of " and '
just sayin...
turbojohnny is offline
Old 04-05-2012, 07:40 AM   #13
So, I am planning on relocating the oil cooler anyway... Is there any benefit to adding the additional 1in in the height if I am losing the 3/4in in the depth? I realize that the total surface area will be a little smaller, but is the height more important than the depth?
Old 04-05-2012, 07:42 AM   #14
Height is more important than depth. The frontal area is the main cooling zone.
That said...an 8" IC is plenty big.
Old 04-05-2012, 07:45 AM   #15
That was what I was thinking, but if I'm switching up the oil cooler anyway I may as well go with a little more height since it fits... right?
Appreciate the help!
Old 04-10-2012, 04:38 PM   #16
Adrenaline406's Avatar
Consider that while frontal area is great, there are two things you're going to run into.
1) The IC is going to start to go behind the bumper as we increase height, then the frontal area is not being increased.
2) Too bit = too much pressure drop. You'll have to compensate with more boost pre-IC to get the same boost post-IC. Like almost everything else in the automotive world, there is a happy medium.
Fortunately this bumper comes off with 2 bolts (okay the headlights too) but it's damned quick. Start with removing the grill and make some measurements. If I remember correctly there are people who have gone big enough with IC's to run into issues hitting the headlights (they removed AC components). So keep an eye out for that.
GLHF! (Good luck! Have fun!) (And with regards to your title: That's what she said )
Adrenaline406 is offline
Old 04-11-2012, 05:54 AM   #17
Cameron,
Thanks for your input on the subject. I have considered both your thoughts and I can understand the concern of it being behind the bumper, but I still think more frontal area will be beneficial as it is not like no air will get to it even if part of it is behind the bumper. Also, as for size, the one I am currently looking at is 28x9x2.75 so it is a little thinner which means it is actually a hair smaller than the average size ebaycooler people use around here (I believe a lot of people get 3 or 3.5 thick).
Agreed, I will have to measure it out and then have a go at it!
And thanks, I now appreciate the humor in the title of the thread
Old 04-11-2012, 06:03 AM   #18
I think on Jesse's 900, we went big.. like 20" tall big or something. I think he had removed the a/c completely, though.
It happened to be an IC I had kicking around from my eclipse, and with piping I had kicking around, it worked well.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
