flex fuel viggen without tcs? - The Saab Link Forums
Old 03-09-2012, 07:29 PM   #1
yllwJet's Avatar
is it possible to run e85/petrol without the tcs? from what i hear theres some kinda file/software update that allows this. also swapping an abs module from a tcs car and software upgrades make it possible. anyone actually do this? or is it just a talked about theory? i found this:
Originally Posted by mackan View Post
Just thought I'd make things clear regarding the Biopower softwares.
Biopower sodftwares look for the speed signal on the canbus, this is sent out by the TCS or ESP system. If there is no TCS or ESP in the car there is no speedsignal on the canbus.
What I have done with the softwares on trionictuning.com and ecuproject is to reroute the speedsignal readings to the ABS sensors instead, this way even cars without TCS/ESP can use the Biopower basefile.
Cars that were sold as petrol only does not have any E85 maps whatsoever in them, a software change is neccesary!
The mod with a cable to be able to run later softwares only applies to early MY98 cars. MY99 should be fine with just software.
Original red injectors max out at 230bhp, after that an intake upgrade is in order to be able to fit later style injectors. You can however increase torque in the low and mid range to make the car a lot faster than stock with E85!
Another route is to retrofit a TCS from a MY00 and onwards Trionic7 car, an easy job, just replace the old ABS unit and connect the canbus cables to it. This also requires newer software that has got support for the TCS unit.
yllwJet is offline
Old 03-09-2012, 08:08 PM   #2
Yeah it's possible, My '00 viggen is currently running on flex tune based on mackan's base file.
denmann is offline
Old 03-09-2012, 08:28 PM   #3
DrewP's Avatar
It's not just the ABS/TCS controller, the harness is different too IIRC.
DrewP is offline
Old 03-09-2012, 10:52 PM   #4
Nothing to do with the Tcs it self.the actual software base is altered to ignore/disable Tcs.works flawlessly.my tune is based on mackan's file and I didn't had any problem in a past year.i can run any percentage e85/petrol.havent dynoed the car but according to t7 suite it's 295hp/400nm crank on petrol or 315hp/430nm on e85.this is with 875cc Deka injectors.
Here is the link to base files :
trionictuning.com • Login
denmann is offline
Old 03-10-2012, 04:38 AM   #5
Drew in Houston's Avatar
True. Mackan made a file with some modified base coding, ie changes not in the mappable calibrations. I fooled around with it for a little bit and it seems to work pretty well, the only issue I found was how it handled setting the transition line between open and closed loop.
Drew in Houston is offline
Old 03-10-2012, 05:46 AM   #6
yllwJet's Avatar
awesome. thanks guys. johns going to be tuning my car for flex fuel. I plan to always use e85 but just in case I get stranded somewhere with no fuel, I can put in petrol and have no issues. there's only 2 gas stations that sell e85 by me
yllwJet is offline
Old 03-10-2012, 06:27 AM   #7
DrewP's Avatar
Innnnnteresting! Good to know.
DrewP is offline
Old 03-10-2012, 06:46 AM   #8
This will help you: AFDC Ethanol: E85 Fueling Station Locations
Old 03-10-2012, 08:07 AM   #9
mvadenais's Avatar
0 in RI, 5 in all of Mass. Great
88 900 SPG Black
95 9000 Aero Green
00 9-3 Viggen Silver
mvadenais is offline
Old 03-10-2012, 08:42 AM   #10
saabkid37's Avatar
theres one 8 minutes out of providence in seekonk now, to add to the one in canton. but yeah...RI is never getting any.
saabkid37 is offline
Old 03-10-2012, 11:34 AM   #11
User
zingZACH's Avatar
Closest station to me is an hour and a half away.
I wish NH and VT would get a couple of pumps. I'd love to have a flex fuel tune.
1988 900 Springtime in Sweden
zingZACH is offline
Old 03-10-2012, 01:52 PM   #12
byastremski's Avatar
would i have to run bigger injectors than the deka 660cc or would those be sufficient? i see denmann is running 875cc, what fuel pump are you running?
byastremski is offline
Old 03-10-2012, 02:10 PM   #13
NeedForSwede's Avatar
Yes it is. It's been done and is fairly simple. I was looking into it last year but with the lack of e85 stations and time, i didn't follow through. Sign up on trionictuning.com to view this link. trionictuning.com • Login
NeedForSwede is offline
Old 03-10-2012, 03:49 PM   #14
For stage 1 e85 stock injectors/pump are fine however stage 3 requires bigger injectors and pump.
There is already made tuning packs for st1 and st3, look into t7tuning/tuning packages sub- forum.all you have to do is apply TP to the base file and flash the Bin using canusb or bdm.there is more steps in beetween so please read instructions before hand
denmann is offline
Old 03-10-2012, 04:36 PM   #15
yllwJet's Avatar
denmann, how many miles roughly do you get out of a full tank on e85?
yllwJet is offline
Old 03-10-2012, 04:47 PM   #16
pat did you end up going with bigger injectors for the gtx?
Old 03-10-2012, 04:55 PM   #17
yllwJet's Avatar
im running the 630cc injectors. theres still plenty left on them but might not be enough for e85. so i picked up 830cc injectors just in case. once john starts tuning my car well see if the 630s are enough.
yllwJet is offline
Old 03-10-2012, 05:51 PM   #18
You have the right idea. Go 750 or 830. With the GTX flowing 10-20 percent more than the GT, and E85 requiring about 20 percent more fuel (due to less energy per equivalent amount of 93 octane) you'll probably be out of the 630 in no time.
John knows his shit, tho...You'll probably end up with a sore face from the permagrin after it's tuned.
Old 03-10-2012, 06:12 PM   #19
yllwJet's Avatar
yea john was the one that recommended the 830s. all his cars and a bunch of his buddies over there all run on e85. it just blows theres only one gas station around here that has it. having the flexfuel ability is critical for me
yllwJet is offline
Old 03-10-2012, 06:19 PM   #20
21mpg on petrol and 18mpg on e85
denmann is offline
