Looking to upgrade turbo please read - The Saab Link Forums
Old 03-05-2012, 07:27 PM   #1
supersaabturbo's Avatar
Question Looking to upgrade turbo please read
I have a 1997 saab 900 se turbo talledega.. I am looking to upgrade my turbo please look at my pics and my garage and tell me what you think i shoud run for a turbo keep in mind i have a guy that will do my computer software if i do some upgrades i prefer direct bolt on but!! Here is what im looking to get out of it..
This is a street/strip car
i would like atleast 300 whp the more the better
i'm on the boost fuel cut off now so around 21 or so psi sounds good i think..
I found a tdo4hl-15g from a 1996 volvo 850r on craigslist.. Any good for me?
supersaabturbo is offline
Old 03-05-2012, 07:38 PM   #2
bogan's Avatar
The volvo turbo is no good, it wont fit.
You have a T-25 on your car now get it upgraded to a "Big T-28"
No install mods required, its a direct fit.
You can run easy 300+hp. But I'm bias because that's what I got.
A TD04-6cm-19T is just as good. But you will need to change coolant lines and maybe oil lines (no sure).
bogan is offline
Old 03-05-2012, 07:48 PM   #3
Ok cool i will not bother with the volvo turbo.. Whats the big t-28 ?
So a td04-16t will work.. I wonder wich turbo will be easyer to get... Also dos it matter if it is water cooled or not? I see alot of oil only turbo's out there
Old 03-05-2012, 07:59 PM   #4
bogan's Avatar
A "big T-28" is basically a journal bearing version of the GT2860rs.
It flows within 5% of the GT. The guts of the T-25 are taken out and the guts of the 2860rs put in.
If you go the TD04 route you want the 6cm exhaust side version not the 5cm.
the EGT's will be to high and melt your valves.
These are both watercooled.
bogan is offline
Old 03-05-2012, 08:08 PM   #5
Thank you.. How do i tell if its a 6cm exhaust side
Old 03-05-2012, 08:10 PM   #6
What should the tdo4-19t come off of or be for?
Old 03-05-2012, 08:10 PM   #7
bogan's Avatar
The 6cm exhaust intake is oval shaped. the 5cm is round.
bogan is offline
Old 03-05-2012, 08:14 PM   #8
bogan's Avatar
That's a 6cm Turbocharger 93~ SAAB 9000 TD04HL-15G / 49189-01600 6cm | eBay
I thinks they came off 9000 aero's and some 95's
Not to sure.
The stock TD04 then needs to be upgraded to a 19T
bogan is offline
Old 03-05-2012, 08:15 PM   #9
OK COOL..What should the tdo4-19t come off of or be for?
Old 03-05-2012, 08:16 PM   #10
that link is for a 15g lol
Old 03-05-2012, 08:17 PM   #11
bogan's Avatar
I think the stock TD04 is a 15T
bogan is offline
Old 03-05-2012, 08:17 PM   #12
something like this?
TD04HL-19T Upgrade SAAB 9-3 9-5 2.3L Aero B235R B205R B235L Turbo Turbocharger on eBay!
Old 03-05-2012, 08:20 PM   #13
bogan's Avatar
None will be a 19T version except a china charger
SAAB AERO 9-3 9-5 B235R Upgrade TD04HL-19T Turbo 0.8bar | eBay.
Good luck with the quality on these .
bogan is offline
Old 03-05-2012, 08:21 PM   #14
bogan's Avatar
Originally Posted by supersaabturbo View Post
That's it
bogan is offline
Old 03-05-2012, 08:28 PM   #15
ok cool.. thank you i will look for a mits td04-19t or a big t-28
Old 03-06-2012, 05:57 AM   #16
Hey, SuperSaab.....
You can't just slap on a turbo and call it good. There are other supporting mods that you'll need to make before you can even think about coming close to your goals. Bogan has prepped his car properly and is adding the turbo as just one of a half-dozen critical changes that will enable his car to hit 300 whp. Please study his posts, and understand that while there's no one way to mod your car, there's definitely a right way and a wrong way.
Seriously, bro....I don't want to pee in your cornflakes, but there's a LOT more you need to do...mainly research to understand what the individual mods do to change the car's performance....
I think everyone here wants you to succeed because we were all in the same boat...
Old 03-06-2012, 06:06 AM   #17
Originally Posted by mike saunders View Post
Hey, SuperSaab.....
You can't just slap on a turbo and call it good. There are other supporting mods that you'll need to make before you can even think about coming close to your goals. Bogan has prepped his car properly and is adding the turbo as just one of a half-dozen changes that will enable his car to hit 300 whp.
I, for one, am glad you are not planning on peeing in his cornflakes. Yeech.
BobSabbert is offline
Old 03-06-2012, 06:08 AM   #18
Now his wheat bran...that's a different story.
Old 03-06-2012, 08:10 AM   #19
132417SAAB's Avatar
okay supersaabturbo Im going to give you a quick run down on
"things to do before bigger turbo"
Fuel pump
injectors
clutch
better brake rotors and pads
intercooler
your oem bypass valve will probably only last a few months with high boost pressure so its best to upgrade to a forge unit
these are the BASIC things needed for a bigger turbo; keep in mind though with the added power your suspension is not going to be happy so if I where you Id think about getting a bigger rear sway bar and steering rack clamp kit. Both of those things and many other parts can be found at Taliaferro Imports, Inc.
goo ruck
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 03-06-2012, 08:27 AM   #20
Hahaha i'm glad you dont want to pee in my cereal!! Now @ (13247saab) i have already done my brakes and rotors drilled and slotted with full ceramic pads front and rear also have upgraded clutch and have a huge yonaka 33"-12"-3" intercooler i am installing in a few weeks. I am no longer running the stock bypass valve i am running dual blow off valves seen in my pics..
