Can i put a BOV of a 2001 Saab 9-3 SE? - The Saab Link Forums
Old 03-05-2012, 10:34 AM   #1
Just looking for the pshh sound. the ladies love it!! not so much with the bpv
Mr. Saab is offline
Old 03-05-2012, 10:45 AM   #2
You can do anything you want for the ladies.
Old 03-05-2012, 11:00 AM   #3
Wagon Shaggin'
Saabeh's Avatar
Please don't, just put an open air intake on the car and be done.
Saabeh is offline
Old 03-05-2012, 11:08 AM   #4
StoneSilver's Avatar
get a open air intake, and a forge Diverter valve. that should give you some sound.
2000 9-3 SE - BCB Tuned
2008 Evo X GSR
Now the Car Gods @ DOT are gunna come Smack your PE PEE
StoneSilver is offline
Old 03-05-2012, 11:13 AM   #5
upstateViggen's Avatar
Everyone seems to ask this question
'99 Viggen
'05.5 Jetta
I'll be sticking around here for the MS paint wieners.
upstateViggen is offline
Old 03-05-2012, 11:15 AM   #6
jk88's Avatar
It's part of the n00b rite of passage.
Also I think this is the 67th variation of "Mr Saab" now registered on TSL.
jk88 is offline
Old 03-05-2012, 11:28 AM   #7
Yes but it said i was available so i took the name. Mr. Saab lives for another day
Mr. Saab is offline
Old 03-05-2012, 11:37 AM   #8
Thanks for the advice with the Open Air Intake guys ! ill look more into it
Mr. Saab is offline
Old 03-05-2012, 11:38 AM   #9
soccerrplyr's Avatar
you can get one but it must vent into the pipe, which muffles the sound a bit as the car's calculation on air mass with be off if you vent it into the air. It will them through a check engine light
1999 9³ Stage 18t
2000 9³ Stage 19t
2005 CRV
soccerrplyr is offline
Old 03-05-2012, 12:22 PM   #10
Would a new diverter valve without an open air intake make some of that sound?
Mr. Saab is offline
Old 03-05-2012, 12:22 PM   #11
friggin viggen's Avatar
Send a message via AIM to friggin viggen
i have an open air and forge BPV, and with good timing on shifting and throttle play I get a great sound after the sexy spooling
Stärka = NVIGR8 = To impart vigor, strength, or vitality to
6/3/06 - 224whp/285wtq
friggin viggen is offline
Old 03-05-2012, 12:38 PM   #12
User
zingZACH's Avatar
My Forge BPV and open intake makes for a pretty loud noise upon shifting or letting off of the gas. I also disconnected the sensor on the firewall and blocked the hose on the intake manifold and it made it even louder and more responsive.
1988 900 Springtime in Sweden
zingZACH is offline
Old 03-05-2012, 12:51 PM   #13
Greek Mod
grkguy89's Avatar
^ got the link for bypassing that valve?
i was searching for it the other day
Current Activity: Moderating
grkguy89 is offline
Old 03-05-2012, 12:53 PM   #14
User
zingZACH's Avatar
I'll look for it... it also helped with turbo spool and it seems to hold it a lot better now. Very noticeable difference.
zingZACH is offline
Old 03-05-2012, 12:54 PM   #15
User
zingZACH's Avatar
http://trolltuner.com/?p=219
Saab-Tuners.com ][ Trionic 7 turbo faster response modification
https://www.saablink.net/forum/perfor...-9-5/54214.htm
I don't recommend using a nipple plug/cap on the intake manifold port though. I kept popping them off (no matter how tight of a fit they were), I lost about 4 of them. I ended up using a small piece of silicone vacuum hose with a bolt stuffed in the end and zip tied it tight on both ends. Haven't lost it yet and it's been about 8k miles.
But it's only for T7 cars.
zingZACH is offline
Old 03-05-2012, 01:03 PM   #16
User
zingZACH's Avatar
This is exactly how my bpv sounds in my Viggen.
zingZACH is offline
Old 03-05-2012, 01:06 PM   #17
snowsaab's Avatar
Do not run a BOV on a T7 car. Your car will hate you. As said before, trionic 7 measures the left over boost through the MAF. If it doesnt sense that air, the car will go wtf? and itll get pissed quickly. So make sure you re-circulate the air with whatever diverter valve you get. NO ATMOSPHERIC DUMP VALVES.
Anyways, now that i got that out lol
I have an open air setup (auto parts "cone" attached to stock intake tube) and a Forge 007dv on my 01' vert, and after a good spool up you can get a pretty nice audible "pssh". Though....do this by yourself....speeding up and then letting of the gas is...well...lets say passengers dont appreciate it lol.
I highly highly, recommend buying a Forge Diverter Valve, they are one of the BEST out there.
'01 9-3 Vert Stg 2/e85
dont make me photoshop a dick in your mouth
snowsaab is offline
Old 03-05-2012, 01:24 PM   #18
Greek Mod
grkguy89's Avatar
[QUOTE=zingZACH;886683............But it's only for T7 cars.[/QUOTE]
thanks!!
i know... it's for my buddy's gt30 viggen build
he's trying to finish it up
grkguy89 is offline
Old 03-05-2012, 01:26 PM   #19
SAABOOST's Avatar
Dual port BPV/BOV I have a few associates running these, with no wtf!
SAABOOST is offline
Old 03-05-2012, 01:38 PM   #20
User
zingZACH's Avatar
thanks!!
Gotcha, and no problem... it's a quick and easy mod that is defintely well worth it! It's amazing how much smoother boost is and let offs are. Just immediate response.
zingZACH is offline
