Koni rear spring solution? - The Saab Link Forums
Old 12-05-2011, 11:47 AM   #1
2legit2quit's Avatar
Send a message via AIM to 2legit2quit
So I got koni lowering springs, and i put the rears in (front have been done for about 4 months) and like i was afraid of, the rear end sits lower than i want. What sort of solutions are you guys using to get rid of the rear sag?
Can i run like stiffer shocks or like taller shocks in the rear? Car need to get raised about .5-1" to make it look like its not raked.
Stage 3 manual 9-3 se
Hell yeah. All the FWD caddys have roll races like all damn day. Then the cruise over to 'Luca's house for some hard parking and body work tips.
2legit2quit is offline
Old 12-05-2011, 12:06 PM   #2
WSW
WSW's Avatar
Shocks blown? Usually it's the front that's lower than the rear on these cars
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 12-05-2011, 12:59 PM   #3
1995BlueBeast's Avatar
Put in a spacer on the spring like Wrangler guys do. You could raise it up just enough and its easy enough to remove if need be. But I agree with WSW, it might be something else as other cars have sat nice and level with the same kit.
Also, do you have a larger woofer in the trunk or anything heavy?
1995 900 SE Black on Black Coupe RIP 4/22/12
2002 9-3 Viggen Convertible Black on Tan
2000 9-3 Viggen Sedan Silver on Black
1995BlueBeast is offline
Old 12-05-2011, 01:55 PM   #4
You might want to check this thread and see how your heights compare: Height (Spring) Survey - SaabCentral Forums
Second, springs hold the car, shocks just dampen what the springs do (air shocks excepted). If you're too low, then you need to affect a spring solution, not a shock solution. Cutting the fronts might be a choice, although it will further stiffen the front, or custom spacer plates in the rear might help... depends on what's out of whack. See the thread I mentioned above.
BobSabbert is offline
Old 12-05-2011, 02:52 PM   #5
Well i mean my fronts have been done for 4 months now, and my back end was sky jacked with me fitting 3-4 fingers between tire and fender arch.
Now im at 2 fingers and i do indeed have subwoofers in the back.
Old 12-05-2011, 02:53 PM   #6
???? Show me who has a koni kit and is lower in the front than back.
Usually these koni rear springs sag in the back or settle and rest on each other and drop lower in the back than front.
Old 12-05-2011, 04:01 PM   #7
I have a 'vert and it's almost level - with the front just a hair lower than the rear. I'll try to take a pic when I'm at my brother's place (don't have a camera) - just don't know exactly when.
2002BlackViggen is offline
Old 12-05-2011, 04:03 PM   #8
WSW
WSW's Avatar
Im not gona look for you but if youd like you can look for some pics
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 12-05-2011, 04:07 PM   #9
http://photo.platonoff.com/Auto/2006...14a.Intrax.jpg
Old 12-05-2011, 04:25 PM   #10
Thats what you dont want! As far as I understand you really cant help that. When the spring compresses like that its all in the spring design and material composition. The only way I understand to fix that is by using a different spring.
Also, having woofers in the back could affect the ride height ever so slightly if they are big enough.
Old 12-05-2011, 04:46 PM   #11
saabkid37's Avatar
Welcome to why I tell people not to run the Koni/vogtland springs.
Tons Of people have them and most peoPlenhave the same comPlaint
You could get rubber spring spacers which will fix that height, but you will still have a nearly fully compressed spring.
saabkid37 is offline
Old 12-05-2011, 04:58 PM   #12
Hmm and where do i find myself rubber spring spaces ?
Old 12-05-2011, 07:00 PM   #13
Take a photo of your springs first and let us see what they look like compressed.
Old 12-06-2011, 04:16 AM   #14
Turbo00's Avatar
Eibach rears seem to be the best design as far as not compressing into a pancake.
Turbo00 is offline
Old 12-06-2011, 04:44 AM   #15
This.
The Koni/Vogtland springs and the B+G springs drop the rears to an equal road height as the fronts, killing the factory "rake." On the plus side, there's less weight transfer during hard turns because the rear is already sitting lower, so theoretically they should handle better.
But I agree that they make the car look like a toddler with a full diaper. (I have the B+G springs and I'm considering cutting half a turn from the fronts...)
Old 12-06-2011, 05:08 AM   #16
Im not saying my back end sags just saying id like to raise it a bit. It sits level but the second i put something heavy in the back it immediatly sags.
Old 12-07-2011, 05:45 PM   #17
Originally Posted by mike saunders View Post
This.
Based on the photos I've seen, they should be using stiffer wire and/or fewer coils. Those things look like they have maybe two live coils left. That's not a suspension, it's a cushioned bumper.
Old 12-07-2011, 06:07 PM   #18
Drew in Houston's Avatar
Swap them for Eibachs.
Took pic this morning, >100k from another car on these springs
Drew in Houston is offline
Old 12-07-2011, 06:24 PM   #19
Is there any where i can buy JUST eibach rear springs?
Old 12-07-2011, 06:31 PM   #20
saabkid37's Avatar
Yeah, definitely not.
