Compression Numbers - The Saab Link Forums
Old 11-25-2011, 05:01 PM   #1
Drew in Houston's Avatar
Compression Numbers
Engine: B235R, 2000 9-3 Viggen
Miles: ~600 on rebuild
History: one oil change, still on regular dyno oil for break in
Internal Mods: JE Pistons, 1st over
Test: dry, other plugs removed
1: 181
2: 187
3: 185
4: 190
Drew in Houston is offline
Old 11-26-2011, 07:11 AM   #2
Greek Mod
grkguy89's Avatar
doing this next chance i get at the shop... i feel like cyl 2 in my car is gonna be low
Current Activity: Moderating
grkguy89 is offline
Old 11-27-2011, 06:00 AM   #3
Found an old note with more numbers
Engine: B205R, 2000 9-3 SE
Miles: unknown, bought car with transplanted engine, bad instal didn't run right. 87k on body, engine lower, suspect 40-60k(?)
History: unknown
Internal Mods: none, stock engine
Test: Dry, other plugs removed
1: 185
2: 185
3: 185
4: 175
Old 11-27-2011, 06:05 AM   #4
Engine: B205R, 2001 9-3 SE
Miles: 189k
History: this was my modified 19T car, purchased with 60k original miles. After 129k hard miles, most over 300whp, finally cracked #4 piston at 26psi, between ring lands. Always ran synthetic
Teardown/Plans: bearings were in great shape, cross hatching on walls very visible. Out at machine shop currently. Wear wasn't enough to catch your fingernail on it, probably could put stock pistons back in it, going 1st over though since it's going to be balanced.
1: 150
2: 140
3: 160
4: 90
Old 11-27-2011, 06:10 AM   #5
Yeah for sure, post up when you can. It'd be great if we could get a lot of info together, after rebuilds, mid-life, tuned...
I tend to write stuff on scratch paper leave it in the garage and then eventually lose it...pretty worthless long term.
Old 11-27-2011, 07:06 AM   #6
Green9kAERO's Avatar
As soon as i find a compression gauge i trust!
Green9kAERO is offline
Old 11-27-2011, 07:24 AM   #7
yllwJet's Avatar
ill be doing one as well prob next week. im not expecting any numbers though lol
yllwJet is offline
Old 11-27-2011, 07:54 AM   #8
Greek Mod
grkguy89's Avatar
mine will probly show the affects of leaving water in the cylinder for days time after an hg blowout
grkguy89 is offline
Old 11-27-2011, 05:05 PM   #9
oliversexpedition's Avatar
Got one running 120s across the board, any thoughts?
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 11-27-2011, 05:43 PM   #10
Greek Mod
grkguy89's Avatar
normal wear engine if they are all equal
grkguy89 is offline
Old 11-27-2011, 05:51 PM   #11
mike d's Avatar
Could be an off guage, or an older motor. or both, Usally anything over 100 will run. a fresh strong motor is between 185-205psi.
Last time i checked my old wagon (yours now) with around 245k on it, it got a solid 175 +/- 5 across the board..
Could just be the guage, Also are you taking comp reading at WOT, if the throttle flap isnt open it will get alot less air to compress.
Mike d
MikeDTuning.com
mike d is offline
Old 11-27-2011, 05:54 PM   #12
WSW
WSW's Avatar
How about cylinder 1 with 120psi and the rest in the 150-155 range.. Oil is milky so it needs a head gasket but am wondering if it's possible for the low reading in one cylinder could be due to a HG when usually its cyl 2&3 that have low readings
99 Viggen
04 9-5 Aero Wagon
WSW is offline
Old 11-27-2011, 05:56 PM   #13
Mike d
Good point. Mine were all with the throttle closed.
Old 11-28-2011, 10:24 AM   #14
I always compression test with throttle plate closed..... I'm consistant about it, as im sure most of you are. I'll have to do a Back to back test to see the difference between WOT and closed throttle.
Old 11-28-2011, 10:25 AM   #15
Its an older motor with new headgasket. Cranks but won't run. Changed out CPS, etc.
Mike d
99 9-5 Wagon
01 9-5 Sedan
94 C900 Vert - Sold
94 325i Vert
Old 11-28-2011, 01:30 PM   #16
mike d's Avatar
Motor depending (single cyl/ITB cars have a bigger difference) also if your doing the test with the plugs still in it matters more,,,
with all the plugs out, some air is alowed back into the intake mani via the other cyls open intake valves
MikeDTuning.com
mike d is offline
Old 11-30-2011, 08:33 AM   #17
Greek Mod
grkguy89's Avatar
Engine: B204R
Miles: ~4k
History: 2 blown HG
Test: dry, other plugs removed, WOT
Cyl 1: 170
Cyl 2: 165
Cyl 3: 175
Cyl 4: 195
So this is the affects of water sitting in your cylinders
gonna recheck it again to confirm but that was a quick test between classes
grkguy89 is offline
Old 12-23-2011, 02:28 PM   #18
NeedForSwede's Avatar
Do you guys let the motor crank the same amount for each cylinder? I thought that was the right way to do it, but then I heard you should crank each cylinder until you reach max compression for each one...can someone clarify?
NeedForSwede is offline
Old 12-23-2011, 06:42 PM   #19
yllwJet's Avatar
just keep cranking until the needle maxes out
yllwJet is offline
Old 12-24-2011, 03:03 AM   #20
bogan's Avatar
I done mine.
Not wot, All plugs out
97 mod 188,000 klm's
In PSI
1&2 - 190
3 -185
4 -180
bogan is offline
