Tell me what you think it will run 2 - The Saab Link Forums
Old 11-22-2011, 04:01 PM   #1
I will be getting my infamous full weight vert to the dragstrip in the next couple of weeks. Just like I did with my dyno thread, I want to know what everyone thinks the car will run.
Please include the following:
60' Time
1/4 Mile Time
Trap Speed
For background, I have made hundreds of passes down my local 1/4 mile track but this will be my first runs in a FWD car. (Although I have driven this particular car aggressively now for five years on the street.)
Here's the current build specs:
1996 SAAB 900 Turbo Convertible
Engine:
-Factory Turbocharged 2.0 L 16V-
Transmission:
-Manual, 5sp-
Clutch:
-Spec Stage 3 Disk Viggen PP-
Engine Upgrades:
-Garrett T-28 Turbo-
-Forge UNOS Manual Boost Controller-
-Forge Wastegate Actuator (Base Boost 18 PSI)-
-Forge Dual Piston Atmospheric BOV (Blue Spring)-
-ETS Bar & Plate Intercooler (Core Dimension 24”x8”x3.5”)-
-GlowShift Boost Gauge-
-Kenne Bell Boost-A-Pump-
-Vortech Engineering FMU 3:1 w/Adjustable Bleeder-
-Walbro GSS 342 255Lph High Pressure Fuel Pump-
-DEI Exhaust Wrapped Exhaust Manifold / Downpipe-
-Port Matched Exhaust Manifold-
-ARP Exhaust Studs-
-2.5", Turbo Back, Exhaust w / Magnaflow 18" x 4” Round Resonator-
-Throttle Body Transition Casting Port Work-
-Custom Catch Can-
Wheels, Tires, Suspension & Brakes:
-ASA JH8 17x7.5-
-235/40/17 Sumitomo HTRZ II-
-Vogtland Lowering Springs-
-Cross Drilled Rotors FR/RR w/Ceramic Pads-
-Sport Struts / Shocks FR/RR-
-GS Strut Tower Brace
-Curb Weight = 3156#-
Last edited by David in Tallahassee; 11-22-2011 at 05:04 PM. Reason: Forgot to add the dyno numbers 340whp 360wtq
David in Tallahassee is offline
Old 11-22-2011, 04:05 PM   #2
Harvey's Autohaus's Avatar
15 flat.
HakbarSAABzzz
Harvey's Autohaus is offline
Old 11-22-2011, 04:11 PM   #3
mike9000aero's Avatar
2.5
14.5
99mph
97 9000 cse stage x Holset hx35w 330whp 373lbft sold
09the VW GTI day stg 1
mike9000aero is offline
Old 11-22-2011, 04:38 PM   #4
Drew in Houston's Avatar
14.3
98mph
Drew in Houston is offline
Old 11-22-2011, 05:10 PM   #5
Originally Posted by Harvey's Autohaus View Post
15 flat.
Trap speed there "Harv"?
D-
Old 11-22-2011, 05:15 PM   #6
D-
Well i was Joking a little But also Not. I Love Sumitomos but unless they are brand new you may have a real problem finding traction. Even with LSD my sumitomos from last year went up in smoke on a regular basis. . Trap?? 98mph
HakbarSAABzzz
Old 11-22-2011, 05:24 PM   #7
I totally understand. My tires are not new and traction will be at a premium for sure. On the street, I can spin them at will in 2nd gear to redline. However, my right foot has become quite deft at feathering the throttle on the edge of spin so it should be interesting!
I expect wheelspin to be significant in 1st but 2nd should hook fairly well based on my experience at this particular strip.
I'll be sure to post back!
Seriously though, what is your projection for trap speed. That has much less to do with traction and much more to do with power to weight ratio.
D-
Old 11-22-2011, 07:44 PM   #8
JZW
With open diff and any street tire, I would guess:
60' 2.3
1/8th 9.8 at 83mph
1/4 in 14.3 at 105mph
JZ
JZW is offline
Old 11-23-2011, 04:32 AM   #9
FWDLOL on a drag strip...
But I'll bite: 13.8...maybe a trap of 110
Old 11-23-2011, 04:36 AM   #10
You are a kindred spirit Mike.
D-
Old 11-23-2011, 06:53 AM   #11
Jaws's Avatar
1.9
13.9
114
Jaws is offline
Old 11-23-2011, 07:14 AM   #12
Originally Posted by Jaws View Post
1.9
13.9
114
I wish Jaws...but thank you!
With a 1.9 short time and a 114 trap, my ET would be about 12.5s unless I stopped off for snacks between the 60' mark and the 660' mark - LOL!
D-
Old 11-23-2011, 07:42 AM   #13
saabkid37's Avatar
Yllwjet was in the 2.1-2.360' on slicks with an lsd
saabkid37 is offline
Old 11-23-2011, 07:44 AM   #14
DrewP's Avatar
I thought the point of a drag strip was so that you didn't have to guess?
DrewP is offline
Old 11-23-2011, 07:47 AM   #15
Obviously once I get there we won't.
D-
Old 11-23-2011, 10:24 AM   #16
Jaws's Avatar
Corn Dog anyone?
Jaws is offline
Old 11-23-2011, 10:07 PM   #17
bogan's Avatar
If you crack a high 13 I'd be impressed.
13.9 @ 105mph
bogan is offline
Old 11-23-2011, 10:19 PM   #18
It oughta be 13's, +100 for sure.
I ran a 14.000 @ like 98 with a stock 15T and crappy 205 BFG radials on the front at 15psi, flat shifting, open diff, stock rev limit.
I haven't spent enough time driving a T5 to know how the gear ratios work out for 1/4 mile duty, but I know on my '01 SE the 3-4 shift was a problem with the stock rev limit. By the time I got down there it was either time to shift to 4 and lose some more time or run through the trap bouncing off the rev limit for a little bit.
Old 11-23-2011, 10:55 PM   #19
Ask Comtrang what he ran w/400 at the wheels.
Old 11-23-2011, 11:37 PM   #20
bogan's Avatar
I've changed my mind. Because of your "deft right foot"
13.5 @110mph
Go the hybrid !!
bogan is offline
