How Much Damage...? - The Saab Link Forums
Old 11-16-2011, 08:31 PM   #1
How Much Damage...?
could I have caused? I wired up my LC-1 and got it working despite being quite finicky. However, the car was bucking and putting out adapt errors and "int" errors like crazy. I was befuddled! In returning back to school and thus 300 miles from the car, I realized I accidentally soldered the simulated narrow band of the LC-1 to the GROUND wire of the 4 wire OE sensor, harness side, and left the sensor lead hangin'. I was supposed to solder it to the signal wire, which is black so that the ECU pulled the readings from the wideband that is in my exhaust bung and not the OE narrowband I have zip-tied to the chassis (so it doesnt throw a heater code, and yes I know it can be programed out).
Do you think I messed anything up? The wideband seems to work fine, but whilst trying to auto-tune the car it died right in the middle of the road The car was running in the 10's AFR wise, so I don't think it went lean
I fixed the issue by unplugging the battery for 5 mins.
I can't see it doing harm, but figured I'd ask so I can shell out and buy a damn replacement so the car is running during thanksgiving.
Thanks,
Cm
Cm452 is offline
Old 11-16-2011, 11:13 PM   #2
JZW
Auto tune smotto tune, not worth the space it takes up in the file in my opinion.
The only thing that is good is the wide band logging feature that allows tracking by cell location, no auto functions work worth a darn, just log the information and then make corrections manually,
John
JZW is offline
Old 11-17-2011, 09:39 AM   #3
DrewP's Avatar
If you were feeding a 0-5v signal into the O2 sensor ground line it's possible if fried the grounding transistor on the ECM board, but you won't know until you fix the wiring and try it again. Chances are probably decent that it's fine, but worst case you'll have to get another ECM.
It's also possible it hurt the wideband controller if current was shorting through the ECU.
DrewP is offline
Old 11-17-2011, 11:17 AM   #4
^Those possibilities are exactly the ones I am worried about. I can't imagine the wideband benefited from such an act of stupidity, but it continued to read, so I assume it's fine
Ugh, I hate stupid mistakes.
and JZW, yeah, I am doing it in cell block regions instead of the autotune function. A little more tedious, but IMHO, there is no sense of security like doing it the old fashioned way.
-Cm
Cm452 is offline
Old 11-17-2011, 01:23 PM   #5
Wait, hold on... isn't the "ground" a return from the sensor? Meaning, isn't the ground that feeds into the ECU designed to take the electricity used heat the sensor? I learned from the maker of the OE sensor that the sensor is NOT a ground to case sensor.
I dunno, I feel, for lack of a better term, the the ECU ground is "designed" for input and not output?
Clarify?
-cm
Cm452 is offline
