Plagued LC1 - The Saab Link Forums
Old 10-25-2011, 08:52 PM   #1
Unhappy Plagued LC1
Wont heat sensor:
I wired up my innovate LC1 to a desktop power source @ 12 vdc. After going through the first "2 blink" sequence I hooked up the O2 sensor and it went into its rapid blink mode to indicate calibration of the heating element in the wideband sensor. It is supposed to start slowly then increase frequency as the heater heats up. The sensor tip never broke ambient temp and the little LED blinked like mad for about 5 mins before I called it quits. According to my multimeter it oscillated between 1 Amp and 3.85 amps draw. The manual says it needs at least 5-what my desktop unit puts out i don't know but I can write my ECU just fine with it. Should the setup not work when it's wired into the car's juice instead, where do you pro's suggest I start?
Anyone know wtf is going on with ECU project btw?
Thanks,
Cm
Cm452 is offline
Old 10-26-2011, 09:03 AM   #2
Out of all the people with tunes on here, I'd imagine at least half of you are running an LC1; any ideas?
Also, if anyone knows what's going on with ECU project that'd be cool too.
Thanks,
-Cm
Cm452 is offline
Old 10-26-2011, 09:50 AM   #3
saabkid37's Avatar
The lc1 works like 60% of the time...and when it does it's good.
It is EXTREMELY sensitive to wiring/grounds/signal noise. Try it wired in the car, if it doesn't work either rma it with innovate or buy one of the sidebands that has a better reputation for working and not needing constant toying to work.
saabkid37 is offline
Old 10-26-2011, 08:29 PM   #4
what wideband is better then? I was told LC1's were the best but required a little more finessing?
Mmm, I may eat the cost on this stupid thing-I ordered it several months ago, though I never used it, so I doubt it won't be taken back
-Cm
Cm452 is offline
Old 10-27-2011, 07:30 AM   #5
Nick Taliaferro
GenuineSaab's Avatar
Mine has been durable in the Viggen. Only problem is dyno when i steal the sensor and plug into dyno LM1s and it is turned on with no sensor it freaks out the second start. I usually have to update it with the laptop.
Thin you have to power it up no sensor then plug it in. Not sure. Critical to get the initialization just right.
The LM1s have been used since -06 one let the smoke out when we crushed the sensor cable in the dyno lift. They warrantied it even though we told them what happened. Only if they made sensors that would bounce and not crack with error08 open heater. haha
Nicholas Taliaferro
GenuineSaab is offline
Old 10-27-2011, 08:30 AM   #6
saabkid37's Avatar
-Cm
you always have the option to RMA it with them and have them try and fix it. they are pretty good about that since it is done soo often by soo many people.
they make a good product, but it is waaaay to finicky/technical. had one years ago that worked fine on first install, got on the dyno and it was .4 off from the dyno wideband and thats not good. it turned out to be a not absolutely perfect ground.
the one that came in my evo never worked after 4-6 hours of troubleshooting and 100's in new sensors.
i ran the aem inline uego (aems version of the lc1) and it worked fine on first install, just couldnt log it with the software since they played with the baud rate (not sure t5/t7 suite or logworks matter on baude rate).
i then got a regular gauge type uego, 15 minute install, and flawless since. and i was against the flashy gauge from the beginning...all it did was cost me money in the long run.
Old 10-27-2011, 04:32 PM   #7
NeedForSwede's Avatar
Thanks,
-Cm
You'd be surprised how many people run tuned saabs without a wideband. "But my craigslist tuner said it's okay....."
NeedForSwede is offline
Old 10-27-2011, 06:09 PM   #8
I am excited and worried at the same time.
Excited because the car behaves exactly like stock in moving it up and down my driveway in terms of throttle response, and starts much more easily with the 630's or whatever the common Dekka's are (some call 'em 660's, which I believe is CC). I am nervous for the same reason...
I have done the proper set up-first with sensor unplugged from main unit, then with it plugged in. It blinks properly, I'm just not getting any heat outta the sensor.
I am having serious Saab DT's-especially since I rebuilt damn near the whole car over the summer it's that much more of a taunt with it not running
Thanks for the feedback. I'll give it another go and then prolly RMA it with innovate.
-Cm
Cm452 is offline
