seam welding - The Saab Link Forums
Old 10-10-2011, 12:55 PM   #1
Greek Mod
grkguy89's Avatar
seam welding
seam welding the subframe specifically
i remember this coming up in some thread
has anyone gone and done this?
any results? good/bad?
im planning on doing it this weekend in addition to reinstalling my 6-point brace (took it off for some repairs and have yet to reinstall)
Current Activity: Moderating
grkguy89 is offline
Old 10-10-2011, 01:11 PM   #2
srp
srp's Avatar
Send a message via AIM to srp
Yadda yadda, probably effects what will happen to the vehicle in a crash, yadda yadda.
srp is offline
Old 10-10-2011, 01:18 PM   #3
Greek Mod
grkguy89's Avatar
oh wah... not planning on crashing
grkguy89 is offline
Old 10-10-2011, 01:20 PM   #4
srp
srp's Avatar
No one ever plans on crashing...
I say go for it.
Worst comes to worst, you throw another subframe on.
Hell seam welding it may remove part of the need for the 6-point.
Regardless, I am no engineer.
srp is offline
Old 10-10-2011, 01:22 PM   #5
Greek Mod
grkguy89's Avatar
i do have 2 spare subframes
grkguy89 is offline
Old 10-10-2011, 01:23 PM   #6
srp
srp's Avatar
You put the SE sway bar on yet? If not, perfect chance. That is if you plan on removing the subframe...
srp is offline
Old 10-10-2011, 03:02 PM   #7
Greek Mod
grkguy89's Avatar
the ng verts had a larger front sway bar
grkguy89 is offline
Old 10-11-2011, 05:23 AM   #8
b dash rian's Avatar
i believe the discussion of warping came up last time, but if you've got spares, i'd say go for it!
b dash rian is offline
Old 10-11-2011, 05:28 AM   #9
srp
srp's Avatar
Yeah warping would be an issue if someone just runs one hot bead the entire way around without stopping to allow it to cool. But if you stitch weld it properly leaving a decent gap between your welds and working around it should be fine. If their is access to do most of it in the air on a lift with it all still bolted to the chassis, I would do it that way. Would act like a jig.
Is the subframe aluminum or galvanized steel? I don't remember.
srp is offline
Old 10-11-2011, 09:34 AM   #10
Greek Mod
grkguy89's Avatar
its def not aluminum
i plan on doing all of the welding on the car in the air on the lift
of course i will jump around so as to not let the metal get too hot
grkguy89 is offline
Old 10-11-2011, 09:42 AM   #11
srp
srp's Avatar
If it's galvanized, make sure you wear the proper respirator. I think WIS says what the metal is. I'll check when I get home.
srp is offline
Old 10-11-2011, 10:11 AM   #12
Ero
tl;dr have fun, dont die
'01 9-3 SE wheeeee
Ero is offline
Old 10-11-2011, 10:59 AM   #13
JK
JK's Avatar
x 1,000,000,000
Be safe! An I do believe it would be galvanized. It is steel, I've never encountered one that appeared to be factory painted...so I would guess there's a heavy galvanized coating there.
As far as doing this...I seam welded parts of the front frame horns and other areas on the first Lemons car we raced and crashed. I noticed no difference in the car, and post crash, teh whole thing was so screwed up there was no knowing exactly what was affecting what in terms of handling.
The car did hold up to the crash very well, considering what it hit, and how hard. Or at least it held up well enough to kind of bend it out enough to keep racing. I don't attribute that to seam welding though...although I reall have no way of knowing.
always a SAAB guy at heart
JK is offline
Old 10-11-2011, 12:03 PM   #14
Greek Mod
grkguy89's Avatar
well i do drive a '95 year model, so the car would most likely be totaled if it were to be hit
grkguy89 is offline
Old 10-11-2011, 02:43 PM   #15
theres not much you can do if you do not have a fresh air resperator. Just plan on keeping your head out of the fumes and plan on feeling sick. its prob some of the worst stuff to weld, i have tried using paint resperators and it still affects you badly. oh and make sure you have some good vents
99 lb viggen
dcr99vig is offline
Old 10-11-2011, 03:35 PM   #16
Greek Mod
grkguy89's Avatar
might borrow my friend's respirator with hose and pump system to give me air from outside the shop.
we'll see
grkguy89 is offline
Old 10-11-2011, 04:47 PM   #17
lowbudgethero's Avatar
Practice first, I have no idea how or if it will warp, but our subframes are pretty flexible so seam welding doesn't sound so absurd. Pictures and results are a must.
lowbudgethero is offline
Old 10-11-2011, 07:39 PM   #18
Greek Mod
grkguy89's Avatar
no worries... if i find my digi cam picture will be up. results will deff be up if i do infact do this
grkguy89 is offline
Old 10-12-2011, 05:20 AM   #19
Nick Taliaferro
GenuineSaab's Avatar
Also try and box in the weaker parts.
The welding of the galvanize is a problem. Def ++ on the remote air supply.
Really needs to be re-plated after, to keep it from rusting inside out.
Nicholas Taliaferro
GenuineSaab is offline
Old 10-12-2011, 10:47 AM   #20
Looks interesting, but after adding the 6pt brace I wonder how much difference it would make. It will be interesting to hear your butt-chassis (goes along with a butt-dyno) analysis.
OTOH, Fitting a subframe brace above the engine would probably make things quite rigid
BobSabbert is offline
