poly vs. stock control arm bushings - The Saab Link Forums
Old 09-24-2011, 08:01 PM   #1
saabkid37's Avatar
viggen ball joints are shot of course, and im sure the bushings are tired at 167k.
the question is, being a daily driver, and not used as a performance car, is it worth the extra 100 bucks to have poly bushings?
suspension is already konis/eibachs/poly front arb bushings/poly steering bushings.
idea is to keep comfort, as i live in a city and its very bumpy, and i use it for long ski trips all winter.
saabkid37 is offline
Old 09-25-2011, 04:59 AM   #2
bobg450's Avatar
I'm facing the same decision, except I already have the bushings. I wouldn't think that the large outboard bushings would affect ride/noise. As for the subframe and body connection(s), I'm leaving them stock. They're smaller and should not allow that much movement, compared to stock, but will still isolate mechanical and road "noise". My 2c
"Wow, is it actually a reading comprehension problem you have, or just a small one with literacy?
" a TrollhattanBilism"
'00 VigVert- Nirvana
'00 9-3SE DD
2013 Silverado Z71 4WD
bobg450 is offline
Old 09-25-2011, 05:03 AM   #3
I had poly control arm bushings and all the other typical suspension mods. I put about 45k on the poly control arms and never found it to be anything too extreme for a DD(which it was for most of it's life).
Jameson is offline
Old 09-25-2011, 05:09 AM   #4
bobg450's Avatar
Hey Jameson (or anybody else), can the control arms be bought without the stock bushings?
'00 9-3SE DD
bobg450 is offline
Old 09-25-2011, 05:15 AM   #5
Turbo00's Avatar
Have them in my vig, daily driven 200-300 miles a week, no ill effects.
Turbo00 is offline
Old 09-25-2011, 06:16 AM   #6
IX III's Avatar
get the poly. it's a non-decision.
IX III is offline
Old 09-25-2011, 06:34 AM   #7
saabkid37's Avatar
It actually is a necessary decision, and without any evidence you have brought nothing to the table.
Poly is not always better
Old 09-25-2011, 06:46 AM   #8
IX III's Avatar
Well if you're going to pout about it...
I've had the poly for 3 years, and I think they are worth the upgrade.
I too take long trips (i.e. 12 hour trips once yearly and 4-5 hour trips once or twice monthly) with koni's (set at full firm) and the whole shebang of poly bushings. I have no complaints at all. There is a much tighter steering feel, and it wanders less on crowned/ rutted roads. Like I said: It is a non-decision. Get them and you will be happy.
IX III is offline
Old 09-25-2011, 06:55 AM   #9
GS gives you the option of stock bushings, or the poly ones.
GenuineSaab.com
2001 9-3 SE HOT
Minibuddha is offline
Old 09-25-2011, 08:03 AM   #10
k1llsh0rty's Avatar
I daily drive my car in and around boston. I have every poly bushing offered by GS and have noticed no changes in ride quality. Put them in. They are cheaper and more durable than stock. The one thing I did notice was crisper turn in and less slop. That being said it has not added any harshness or extra road vibration.
Originally Posted by Ironjoe
I'm sure you'll find that quite a few TSLers are well-equipped enough to service even your 3" downpipe.
k1llsh0rty is offline
Old 09-25-2011, 08:09 AM   #11
IX III's Avatar
so you did notice changes in the ride quality... they were just positive changes.
IX III is offline
Old 09-25-2011, 08:18 AM   #12
WSW
WSW's Avatar
I had poly bushings all around with koni kit here in chicago where the roads are crap and i wouldnt say its a harsh ride...its definitely much much firmer but the car feels much more planted and you have way more control..
I say poly
WSW is offline
Old 09-25-2011, 08:50 AM   #13
k1llsh0rty's Avatar
Yes, my bad. No changes in terms of ill effects.
Old 09-25-2011, 10:21 AM   #14
pitman's Avatar
i have both stanchion arm poly bushs, lca bush,tie rod bushes they didnt effect my daily driving i think they inprovved it.
a little off topic but if your into ride quality dont get low profile tires. theres a big difference between 16x6.5 205/55/16 and 17x8 235/40/17 in ride quality. i feel bumps i didnt feel before just by swaping tires.
and one more thing to mention. you know the stock bushes can got to 167k on the vig. does anyone have any long term use with poly bushes? like 100k miles?
pitman is offline
Old 09-25-2011, 11:10 AM   #15
saabkid37's Avatar
If the stock can go 167k with only the ball joints failing poly should technically last longer
I doubt anyone has done mileage that significant since the bushings haven't been out more than 3ish years or so
Old 09-25-2011, 11:26 AM   #16
IX III's Avatar
just shy of 40k on mine. they looked just like new when I tore down my suspension last night
IX III is offline
Old 09-25-2011, 02:00 PM   #17
a little off topic but if your into ride quality dont get low profile tires. theres a big difference between 16x6.5 205/55/16 and 17x8 235/40/17 in ride quality. i feel bumps i didnt feel before just by swaping tires...
Yeah, but you don't look as kuel with 16" wheels!
I'm a 16" fan too, from a view point of ride, acceleration, and pothole protection. But, most people opt for 17's, or even 18's (good gawd) now, because it's trendy.
BobSabbert is offline
Old 09-25-2011, 02:14 PM   #18
GenuineSaab.com
Word of warning: there were some posts in another forum by a guy who ordered arms from GS. They guaranteed they were OEM before he ordered, then they sent him Scantech. He had to argue with them long and hard to get a refund and he still got stuck for some shipping.
I'd order the poly from them if you like, but get the arms elsewhere.
Old 09-25-2011, 03:45 PM   #19
saabkid37's Avatar
big freakin whoop about scantech.
they about the biggest aftermarket supplier available.
Old 09-26-2011, 04:36 AM   #20
There's definitely better steering feel with the poly control arm bushings, and less of the wandering feeling on rough roads. But...I replaced all the subframe and steering bushings at the same time, so I can't isolate a specific value for the control arm ones
So...
Your question about whether it makes enough of a difference, especially on a car you're planning to sell, is pretty valid....
