td04-15t 5cm to 18t? - The Saab Link Forums
Old 09-20-2011, 10:44 PM   #1
pitman's Avatar
does anyone have info on machining the intake housing for the bigger wheel?
also if i buy a balanced turbine will i have to balance it after the rebuild?
pitman is offline
Old 09-21-2011, 05:01 AM   #2
gm
gm's Avatar
Don't do it, you need to get the 6cm housing from a 9000 & mod that for the 18t. Most people/tuners state the 18t doesn't work properly with the 5cm housing, to restrictive.... to much heat.
I forget the years the 6cm housings came on 9000's..... go that route, it's what I did & it's a great combo
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 09-21-2011, 05:40 AM   #3
Marks9-3's Avatar
I think it was '93 - 97 manual aeros and the manual 98 CSE. Autos had the T25
Marks9-3 is offline
Old 09-21-2011, 10:37 AM   #4
pitman's Avatar
i keep hearing that too. but i guess theres guys runing the 18t with 5cm and they say the egts are fine.
i wonder if i clipped the exhaust turbine if it would act like a 6cm unclipped? to lower egts?
i want my saab to have low end power. breaths enough up top right now for me.
pitman is offline
Old 09-21-2011, 10:53 AM   #5
gm
gm's Avatar
Yea, it can work..... with a 2.0T I am sure there is a lot more room to play since the pistons are stronger then what is in my Viggen.
In addition to added heat it will also spool up slower vs a 6cm
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 07-13-2014, 08:48 AM   #6
So on a 2.0L, clipped wheels/exhaust side work on the 5 cm housing is ok...but on a 2.3L, it is not. Is this correct? In other words, NO 5 cm housing, regardless of what is done to modify it and the wheels, will function well with the 18T wheel...that is on a 2.3L?
Progression is offline
Old 07-13-2014, 09:44 AM   #7
Cark's Avatar
you definitely would not want to upgrade to an 18t without going to at least a 6cm turbine housing. Lots of guys are even going with the 7cm housings now.
My 18t in unclipped, which helps a bit with low end spool. If I spent a lot of time in the upper RPM's then clipping the wheel would be great to help keep EGT's down, but that's not a concern of mine.
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
