Killing my tdo4 turbos. Why? - The Saab Link Forums
Old 06-11-2010, 03:40 AM   #1
soccerrplyr's Avatar
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
soccerrplyr is offline
Old 06-11-2010, 03:53 AM   #2
Marks9-3's Avatar
Are the lines/banjo bolts clogged at all?
Marks9-3 is offline
Old 06-11-2010, 04:31 AM   #3
BurnsSide42's Avatar
How much boost are the TD04's rated to run at anyways? I know it's not a 350hp Turbo - I mean, it can do it - but will be pushing it HARD. I'd look for an OEM Td04 or just get a Holset at this point...
Check out
for your repair needs
BurnsSide42 is offline
Old 06-11-2010, 04:45 AM   #4
8valvegrowl's Avatar
Originally Posted by soccerrplyr View Post
Both are from xsboost turbochargers company.ONe was bought via ebay, the other from a person who sent there card when shipping the unit. So both are from thesame compant.
That's why. XSBoost is known crap. Buy a used factory turbo off a Viggen or Aero, send it to Chadwick for a rebuild or to another reputable shop (Blouch or GPop) and I bet they will last longer than 4-5K. XSBoost is known for putting crappy parts in their rebuilds and hawking Chinese knockoffs.
8valvegrowl is offline
Old 06-11-2010, 05:33 AM   #5
the housings of the turbo are oem for sure
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
Old 06-11-2010, 05:37 AM   #6
a12
a12's Avatar
Yeah you either have an oiling problem or the parts in the turbo are junk parts.
a12 is offline
Old 06-11-2010, 06:38 AM   #7
JZW
Yea, something amiss there, I have been beating on my aero turbo at over 20psi for over 3 years now and its got 227k on it
John
JZW is offline
Old 06-11-2010, 11:27 AM   #8
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
Old 06-11-2010, 11:33 AM   #9
saabkid37's Avatar
It's because it's xsboost end of story
saabkid37 is offline
Old 06-11-2010, 12:39 PM   #10
mike9000aero's Avatar
Just put a hx35 on and be done. EBay 250 bucks used four
97 9000 cse stage x Holset hx35w 330whp 373lbft sold
09the VW GTI day stg 1
mike9000aero is offline
Old 06-11-2010, 02:47 PM   #11
Makeyousaab's Avatar
I noticed that when my PCV system was all f'd up and I left it that way I had to replace a turbo or two. Once I properly installed a catch can and actually ran it to the intake I have had better luck with my TDO4's lasting.
~Dave
Makeyousaab is offline
Old 06-11-2010, 07:26 PM   #12
My 9k aero has the original td04 on it and it has lasted all of it's 220k life. No issues whatsoever - had it off at 160k and it had absolutely no play. I'd look to make sure there are no issues with oil lines or look for a shop other than XSBoost.
2002BlackViggen is offline
Old 06-13-2010, 07:19 AM   #13
VWSAABVT's Avatar
stfu, thats your retarded solution to everything. You don't just "put" a holset on an NG or 9-3
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 06-13-2010, 02:59 PM   #14
yeah, im pretty sure you do just PUT one on.... you just by all the parts needed to do so.... and if you are smart enough to do a td04 swap you are smart enough to install a holset hx35 on it
its not that complicated considering you can find a manifold or a header for it to bolt right up
THEN you dont have a turbo shitting its self all the time, and you can tune it to not make so much power that you break shit every time you get on it...
i think its retarded to not have a bullet proof turbo...
lets see here 600 bucks to upgrade a td04 to make 300 wheel and it could die really easy some last a long time some die often
or about 1000 bucks to buy a holset and a header/manifold and BOLT it right up... get a little creative and make an oil line, build some piping and your done with it...
if you dont go with an upgrade and want to keep it stock i would suggest buying a brand new oem replacment td04, they run about 800 bucks or so and have a warrenty.. cant beat that if you are staying stock
you stfu
Old 06-13-2010, 05:35 PM   #15
NeedForSwede's Avatar
mike9k, do you run slim fans?
NeedForSwede is offline
Old 06-14-2010, 02:41 AM   #16
In a 9k its differant I'm sure a ng you would need that, but imusing a modified stock fan in my car now.
Old 06-14-2010, 10:10 AM   #17
Trollerator
abdukted1456's Avatar
No way, things made on the cheap in China are just as good as OEM, that can't have anything to do with it that they are from this same company. ***********
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 06-14-2010, 10:16 AM   #18
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
Old 06-14-2010, 10:25 AM   #19
mvadenais's Avatar
upgrading to a bigger turbo is not cheap eitherway, a manifold or header is not cheap, on a NG or 9-3 that is
88 900 SPG Black
95 9000 Aero Green
00 9-3 Viggen Silver
mvadenais is offline
Old 06-14-2010, 11:14 AM   #20
the turbos I received looks oem and just like the ones on my t7 9-3's. The second turbo i bought was from an independant party on the forums, who I guess bought if from the xsturbo boost company, but i did not know this until it arrived and with a xsturboboost buisness card inside the packaging.
Just because the CHRA and the compressor/exhaust housings have OEM markings on them doesn't mean they used OEM spec bearings, seals, and rings inside the turbo.
XSBoost is infamous for using crap internal parts or using incorrect parts (ie flatback plates on superback turbos, etc). End of story.
