Fuel Injectors...Saturated or Peak & Hold? - The Saab Link Forums
Old 03-17-2010, 02:44 PM   #1
...which type comes stock on a '99 9-3 2.0?
i'm chasing a bad idle, horrible fuel mileage and no power on acceleration...
i have spare BMW and Mitsu Eclipse Turbo injectors and would like to install these if applicable!
Thanks !!
--Hayden--
'99 9'3 Coupe
'87 BMW E30 Track Rat
'92 Integra GS-R
Haydende is offline
Old 03-18-2010, 06:00 PM   #2
anyone ? ...
--Hayden--
'99 9'3 Coupe
'92 Integra GS-R
Haydende is offline
Old 03-18-2010, 06:09 PM   #3
Legit's Avatar
I doubt it's injectors. do you have a check engine light on?
2002 Viggen Convertible
Legit is offline
Old 03-18-2010, 06:10 PM   #4
saabkid37's Avatar
i bet its not your injectors
saabkid37 is offline
Old 03-18-2010, 07:15 PM   #5
watkins's Avatar
Send a message via AIM to watkins
It was my injectors. Or rather, injector three. I also had a lean condition CEL a few times.
watkins is offline
Old 03-18-2010, 08:08 PM   #6
yes, i have a check engine light... Generic OBDII says engine misfire...
i have very low power and a bad miss..
so far, i've swapped plugs and found # 1 to be not as 'burnt' as the others.. i replaced the red DIC with a new generic unit from Eeuroparts back in July last year...i have no known good DIC for a test
in the meantime, I've cleaned the IAC and Evap purge valve ..done a fresh oil change with Seafoam in both oil/gas..
...i haven't run the seafoam thru the vacuum line ..
the car runs bit smoother, but the miss and low power conditions are still present
i'm waiting on a compression check to determine a bit more...
if it comes down the injectors.. was thinking of swapping in these that I have .. but just needed to verify the type of injectors that are currently in the car ..
--Hayden--
'99 9'3 Coupe
'92 Integra GS-R
Haydende is offline
Old 03-18-2010, 08:52 PM   #7
Ero
I dunno if this helps, but screenshot from the WIS:
File Type: png Screen shot 2010-03-19 at 12.50.40 AM.png (14.9 KB, 22 views)
'01 9-3 SE wheeeee
Ero is offline
Old 03-19-2010, 02:16 AM   #8
saabkid37's Avatar
you have a bunch of other options before injectors.
it is very difficult to go by the plugs since the DI has a burn off cleaning cycle.
ect sensor (x2?)
DI
FPR
MAF
throttle body
possible flaky cps
off the top of my head those can all cause a missfire and rich conditon.
Old 03-19-2010, 03:36 PM   #9
Sleepy7666's Avatar
http://users.erols.com/srweiss/tableifc.htm
I lurk.
99 and 01 Saab 9-3
96 Escort LX
83 Yamaha XJ650 Maxim
Sleepy7666 is offline
Old 03-19-2010, 04:01 PM   #10
NeedForSwede's Avatar
IIRC, Saabs are high impedance. Don't quote me on that.
NeedForSwede is offline
Old 03-19-2010, 04:24 PM   #11
daveship's Avatar
correct. saturated/high impedence
daveship is offline
Old 03-19-2010, 05:08 PM   #12
not to hijack, but has anyone ever swapped over to low impedance on any projects on their saabs? I know they have their advantages compared to high impedance. Just curious.
Old 03-19-2010, 11:17 PM   #13
lowbudgethero's Avatar
i think the risks out weight the minor advantages, in terms of direct swap... if needed to then you would need to make sure the current stayed the same
lowbudgethero is offline
Old 03-22-2010, 12:21 PM   #14
Ya, it would be a PITA for sure...and probably pointless since trionic is based on high impedance. I just thought I'd ask for shits and giggles.
Tags
wife beater
