What wideband do you like? - The Saab Link Forums
Old 12-10-2009, 12:48 PM   #1
NeedForSwede's Avatar
So I've been thinking of picking up a wideband for my viggen. I used an AEM UEGO on my turbo accord and that did pretty good at doing it's job for $230, but I have heard that some people do not like them because they can't be recalibrated, their datalogging is not well sorted, and other reason I can't remember. Innovate widebands are around the same price and PLX supposedly makes a very good product. What do you guys use and why? I tried searching but all I found was either an install or a FS thread.
NeedForSwede is offline
Old 12-10-2009, 04:56 PM   #2
comtrang's Avatar
I like my AEM BECAUSE it doesn't need to be calibrated. For datalogging, there's a 0-5v that can be tied into the ECU. I think I read good things about PLX as well but no first hand experience.
Another minor thing I liked about the AEM over the Innovate I had for a few weeks, is that it's one simple cable One end to the sensor, one to the gauge and you're good to go.
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 12-10-2009, 05:12 PM   #3
kingofkrunk's Avatar
innovate ... lc-1 ... /thread :P
kingofkrunk is offline
Old 12-10-2009, 06:41 PM   #4
Green9kAERO's Avatar
i have the LC1 but i like the AEM gauge WAY better.... but my LC1 works great so i cant really complain
Green9kAERO is offline
Old 12-10-2009, 07:33 PM   #5
One thing I wasn't sure of was the "controller" that came with the innovate wbo2's. Like you guys, I'm only familiar with the very straightforward AEM setup which obviously doesn't have one.
Old 12-11-2009, 07:23 AM   #6
comtrang's Avatar
Yeah, very straightforward. When I was pressed for time to get my car finished, it's nice to have the little things like that to speed up the process even by just a few minutes
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 12-11-2009, 09:00 AM   #7
mike9000aero's Avatar
the lc1 is straight forward if you ask me...it was very simple to install and calabrate
97 9000 cse stage x Holset hx35w 330whp 373lbft sold
09the VW GTI day stg 1
mike9000aero is offline
Old 12-11-2009, 09:36 AM   #8
DrewP's Avatar
I bought the PLX with the display because at last I read the Innovate controllers were still frying sensors at an alarming rate. There is lots to read up about it on the Innovate forums. We used an Innovate for the FSAE car at school for two years, and fried two sensors this way, and dealing with Innovate about it was a nightmare.
The PLX, AEM, and Innovate all use the same Bosch sensor, the difference is in the controller.
While calibrating the Innovate is easy, it's a pain unless you have your laptop with you every time you start the car in different conditions. The PLX self-calibrates at each startup, and the PLX has a knob right on the front to set the calibration for different fuels, gasoline, E85, straight ethanol, diesel, and one programmable one.
The response time is very fast, you get repeater outputs right out of the back of the controller for 0-1v, 0-5v, and one programmable, and wiring it isn't any harder or easier than any of the other ones.
Give the controller switched +12, ground, and plug in the sensor and go. If you can't handle that, you shouldn't be messing with the implications of having a wideband anyway.
My only complaint about the PLX with the display, is it is a numerical-only display, which is a pain for the driver to use as a safety check when road testing, and color coded band or bar graph would be infinitely more useful, and wouldn't be hard to rig up, but is worth mentioning that if you buy the 'Tuner Edition' controller with the display and want to be able to monitor it while driving, be ready to buy a bar- or round color display guage as well.
The display will also only read (in gasoline setting) down to 10:1, and up to 20:1, I think the Innovate software will display richer than that when set to gasoline.
My PLX matched the onboard tailpipe system on the dyno last weekend nearly exactly the whole run, just by eye though, I didn't log the output as well.
Best,
Drew
DrewP is offline
Old 12-11-2009, 09:37 AM   #9
do you calibrate it through the "controller?" What does that thing actually do?
Old 12-11-2009, 09:57 AM   #10
quick4door's Avatar
i use an innovative PLX device in my turbo wrangler
quick4door is offline
Old 12-11-2009, 10:08 AM   #11
lms
I like the lm-1 which I have had for about 4 years now (used it on 5 cars now), but you have to buy an rpm tranducer if you want to log data at certain rpm's. Not a big issue, but an extra cost.
lms is offline
Old 12-11-2009, 08:25 PM   #12
Right now I can get a UEGO for like $201 shipped and an Innovate for $230...decisions decisions
Old 12-11-2009, 09:07 PM   #13
srp
srp's Avatar
Send a message via AIM to srp
I bought the Innovate LC1 + XD16 guage kit off of ebay for $270 I believe. The XD 16 guage rocks. And you can use the button on it to start calibrate mode.
srp is offline
Old 12-11-2009, 11:56 PM   #14
comtrang's Avatar
Best,
Drew
Are you referring to the Innovate or the PLX on that part?
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 12-15-2009, 09:17 PM   #15
I think he is. I'll probably just end up getting another AEM since it remains to be the cheapest one on the market and gives me the info I want.
Old 12-16-2009, 05:25 AM   #16
codesplice's Avatar
Same here. Well, except I bought mine from Innovate. Anyhoo, been quite pleased with it. The whole package, that is - the Gauge and the Controller.
Haven't fried any sensors either.
2001 9-3 - Nordic Stage 3
2007 9-5 2.3T Wagon
codesplice is offline
Old 12-16-2009, 10:01 AM   #17
DrewP's Avatar
The PLX.
Best,
Drew
DrewP is offline
Old 12-19-2009, 02:17 PM   #18
the lc1 is easy to install and calibrate, if you follow the directions. i like the look of the gauge too its cleaner looking i think
99 lb viggen
dcr99vig is offline
Old 12-19-2009, 02:34 PM   #19
christian900se's Avatar
The PLX would be the gauge I would go with if and when I get a wideband. The customization that is possible is really appealing in my mind and for the advantages in flexibility for its calibration like Drew mentioned.
christian900se is offline
Old 01-19-2010, 02:25 PM   #20
So I thought this might be worth posting. It's the cheapest deal I've found for for an Innovate LC-1 with some gauge to display AFR's...other than 14point7.com.
http://www.xenocron.com/apu1-autopro...6a9bbb8eb2899e
