Dyno results......... - The Saab Link Forums
Old 12-01-2009, 07:11 AM   #1
Moosepuck's Avatar
Thought I'd share here as well......
Here it is, looks like the AFR is pretty good, I see a couple more PSI on the road, but I'm pretty pleased overall with the nice, wide powerband.....
Thanks to JZW for all his help, (let me know if you see any other changes you want to make)......
06 W211 E55 AMG (his)
08 9-3, Aero vert, 2.8t(hers)
Gone but not forgotten: several NG' and C's
Moosepuck is offline
Old 12-01-2009, 07:47 AM   #2
saabkid37's Avatar
13:1 af? tad lean for my blood.
i bet you could go dow to aout 12:1 and put more timing in.
boost holds solid though....how much more do you see on the road?
saabkid37 is offline
Old 12-01-2009, 08:06 AM   #3
JZW
Remember that is at the tailpipe, wide band right after turbo shows 12.5/1
John
JZW is offline
Old 12-01-2009, 03:15 PM   #4
nice run moose!
my car's on the rack as we speak. .64 exh housing going in, with the 60lb injectors. and a new JZW tune....wish me luck. nice stickers BTW. i'll keep y'all posted. =)
wasaaabi is offline
Old 12-01-2009, 03:55 PM   #5
comtrang's Avatar
Very nice!
And I like how thorough it is, with boost and AFR. You should add it to the thread in the proof section!
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 12-01-2009, 09:51 PM   #6
lowbudgethero's Avatar
that is such a flat power band over 300hp from 4250 to 7K
lowbudgethero is offline
Old 12-01-2009, 10:01 PM   #7
hey lowbudget...i dont' think i ever had the chance to get back to ya. sorry. but yeah, still got it. how u doin?
wasaaabi is offline
Old 12-02-2009, 03:44 AM   #8
lms
Very nice indeed!
John, what have you done to your new viggen?
lms is offline
Old 12-02-2009, 05:03 AM   #9
Moosepuck's Avatar
Thanks everyone... I'm very happy with the way she drives..... I don't think I want anything bigger that would cut down on my low end... I am helping someone else with a Holset VGT install on his 9-5, if that works out on his, it might just be the best of low and top end...should be interesting......
Old 12-02-2009, 07:14 AM   #10
JZW
Originally Posted by lms View Post
Very nice indeed!
Nice runs Moose, I bet that thang is a blast to drive on the streets! Still comes on fairly quick, yet pulls harder and longer than the 3071wg. If you had cams, that would put you over 400whp, but would also rob some bottome end. Its always a trade-off, bottom vs top and where do you want the power to be in rpm and how much do you want.
Ims, I kept the viggen stock for 3 days I was very impressed with it in stock form. I did put in t5 cams and the 6cm2 turbine housing from a 9k aero and with the light Woessner pistons and the lightly lightened stock flywheel, the car is very fast. I am surprised! Its an 02 model and they were rated at 230bhp and they have leaned out the fuelling map to get that extra power and it goes very well indeed.
I have now tune it for stg 1 and set up the knock counters in the sid function so I can see the knocking counts on each cylinder and then reduced the timing so I only get about 1 knock count per pull. It was about 3-4 knock counts per pull in stock form and made about 1140 airmass. I have it making about 1220 airmass now and raised the first and second gear torque limits. Its a fairly quick car now.
Next will be a stg 3-4 with the ets ic and 3" JT exhaust. The last step will be stg 5 e-85 flex fuel.
John
JZW is offline
Old 12-02-2009, 07:19 AM   #11
Damn I just ended up buying another t25 and putting that in, an intersting experience
Old 12-02-2009, 08:30 AM   #12
saabkid37's Avatar
John
depends on if he has a cat or not i would think.
would there be any advantage to running it down to 12:1 and putting in more timing? i would think that might help the power hold a tad longer since i doubt there is a bottle neck in the system, unless the exhaust wheel is really that small.
Old 12-02-2009, 10:03 AM   #13
Nick Taliaferro
GenuineSaab's Avatar
Since my dyno is equipped with dual widebands I have been playing lots with this before and after thing. At light load obviously the signals will lag quite a bit but once the load (airflow) comes up they are always the same, just the time alignment is offset. Remember the cat can only work near stoic..
Nicholas Taliaferro
GenuineSaab is offline
Old 12-02-2009, 02:31 PM   #14
That's a really nice, flat curve.
A little later boost onset than a GT3071/64 but holds the peak for a bit longer.
Awesome job....you may want to richen it up a bit between 4250 and 5250 just for safety's sake, but you're probably fine through the winter.
Old 12-02-2009, 03:48 PM   #15
Moosepuck's Avatar
Thanks Mike..... it will be drinking slightly more fuel this weekend..... hopefully then I can just leave everything alone for awhile and just enjoy it..........
Old 12-06-2009, 06:52 AM   #16
JZW
Yea, I said the same thing, lets richen it up a little bit between 4k-5k or so and already have an updated fuel map for him. I was surprised at how fast it spools, good option for someone with a 9k and t3 manifold that wants quick spool.
John
JZW is offline
