gt3076 .86 turbo-lag? - The Saab Link Forums
Old 11-17-2009, 12:36 PM   #1
I got this great offer on a gt3076 .86wg right now. Considering the price, i should buy it right now. But it's quite a big turbo (for me at least), since i didn't have any plans for more than 350hp+.
So i'm asking you guys. How will the drivability be with this turbo on a 2.0 vs. 2.3? At what rpm will the boost reach 1bar and 1.5bar? And what can be done to minimize turbo-lag?
before i got this offer i was considering the gt3071 .64wg witch i think is a better turbo for this application. But the offer i got is about 1/4 of the new price.
What do you guys think?
Talker is offline
Old 11-17-2009, 12:58 PM   #2
Buy it, then swap the housing with someone wanting to go bigger....
Win-Win..
Old 11-17-2009, 01:22 PM   #3
liketheword's Avatar
Win-Win..
Quality advice.
Vitamin SAAB
liketheword is offline
Old 11-17-2009, 01:30 PM   #4
How used is the turbo?
Old 11-17-2009, 02:30 PM   #5
Not much. I can still see a white writing on one of the blades on the exhaust side.
But how much. I dont know... Barely used.
Of course i could swap the housing(expensive to buy?) with someone.
Is there anyone who has any facts about spoolup-time with this or related turbos in 2.0 and 2.3 saab engines?
Talker is offline
Old 11-17-2009, 02:43 PM   #6
Deez Nutz
Palmer's Avatar
My 2.3/gt3071 .64 was fully spooled by about 4300 rpms.
I could get about 10PSI around 3200 or so.
S55/LC100/KL
Palmer is offline
Old 11-17-2009, 04:04 PM   #7
a12
a12's Avatar
It'll start ramping up quickly around 5000 rpm on the 2.0, maybe a little sooner on the 2.3.
a12 is offline
Old 11-17-2009, 09:10 PM   #8
That late?? Oh my..
So what do i need to change to get a quicker spool? I'm no turbo expert at all.
Talker is offline
Old 11-17-2009, 09:19 PM   #9
bsuarmy's Avatar
Swap housings is probably your best bet. There are some people with setups that can really utilize that late spool up/power, unless you are planning on going that route as well.
bsuarmy is offline
Old 11-17-2009, 09:33 PM   #10
Well. I was thinking of 350hp. And maybe upto 400. But dunno yet.
This turbo is capable of 520hp at least, but the internal wastegate is quite a bottleneck. So now it capable of 400+++
Talker is offline
Old 11-17-2009, 10:07 PM   #11
bsuarmy's Avatar
What model car do you have? Year and such.
bsuarmy is offline
Old 11-18-2009, 07:51 AM   #12
JZW
That late?? Oh my..
I had the gt3071wg .64ar and then got the .86ar and my turbo spooled up a good 800rpm later with that housing. I was close to 5k by full boost !
John
JZW is offline
Old 11-18-2009, 08:50 AM   #13
John
Are you talking about GT3071 ar .64 vs. GT3071 ar 0.86 or 3071 ar 64 vs 3076 ar0.86?
If i recall correctly the 3071 0.86 housing you had was toast and would not pay too much attention to what was obtained with it.
to orig poster, in my old post there are plenty of logs but here is a quick one (use search for more)
http://www.stcf.net/viggen/housing/boost64_86_21.gif
all other HW the same, only housing changed. Car 2.3 and equipped with Enem9.6 lift cams at time when log was taken. The 3076 0.86 in terms of spool will be further up than the 3071 ar 0.86 and think its a bit overkill for you bhp needs.
Vigge is offline
Old 11-18-2009, 11:58 AM   #14
The current owner uses this turbo on a 2.0, and reaches 1.8bar much earlier than 5000rpm. 4000 maybe.
I know its a bit overkill. But i need a new turbo anyway. And the price was right. And who knows... Maybe i'm going full in.
But if i changed from ar .86 to ar.64? Would the spool be better then? Or are additional changes needed?
Talker is offline
Old 11-18-2009, 12:00 PM   #15
Spool would definitely be better, but you'd have more top end with the bigger housing....
Old 11-18-2009, 12:34 PM   #16
comtrang's Avatar
Yep so of your goal is right around 350-400hp, there's absolutely no reason to use the .86 housing. .64 housing meets your lag and spool goals it seems. If you're getting such a good deal on it anyways then it won't hurt to spend a little more on a new housing.
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 11-18-2009, 12:52 PM   #17
christian900se's Avatar
Yeah but then it comes down to how long you have top end before needing to shift and spool up all over again.
christian900se is offline
Old 11-18-2009, 01:12 PM   #18
Adrenaline406's Avatar
run anti-lag, i dont care if its a street car.
Realistically, I think someone on here or somewhere will want to pick up that bigger housing, I'll bet it could be sold/traded.
Other than smaller housing and anti-lag (completely unrealistic) what are other ways to reduce lag? Port matching and timing right? anything else?
Adrenaline406 is offline
Old 11-18-2009, 04:07 PM   #19
A good point...
The 3076/.86 might be a better match for the 2.3 instead of the 2.0. My 3071/.64 spools up a bit too fast for my tastes, but the cams should help...
Old 11-18-2009, 09:20 PM   #20
A good point...
Oh. Maybe i didn't say.. i'm gonna convert to 2.3. How come it spools too fast? Why do you think so?
Talker is offline
