need new pads, rotors - The Saab Link Forums
Old 11-10-2009, 09:48 PM   #1
I need new pads and rotors for my 2000 9-3. I can be a vary spirited driver and have done autocross a few times. Im thinking of just keeping the bakes stock, but I have seen some slotted rotors for cheap, the only thing is I don't want my pads to wear out faster...What setups would you recommend and is the redeeming factor of the slotted rotors perhaps cost affective if one is a spirited driver?
Vee put vindshield vipers on aur headlights becaush ve are from Shveeden and it rainesh and shnowhs a laut en Sveeden!
jaross is offline
Old 11-11-2009, 10:49 AM   #2
Find a set of Viggen or 9-5 Aero front caliper brackets. Im sure the pads and calipers are the same. The Viggen rotors are only slotted in one direction, so one is backward. If you get them from Nick, you can get them slotted correctly. I'm very happy with the way the Viggen brake setup works. There are other options, but they are more $$. I got the low dust pads, but they sacrifice some stopping power. Avoid the knock off drilled and slotted rotors. They look cheesy IMHO and can crack easier if pushed hard.
2004 Silverado 2500HD Crew cab LT 6.0 LQ4, K+N intake, Magnaflow dual exhaust. Diablosport tuner.
2000 Viggen Vert *Gone - buy/enjoy my parts!
2010 Corolla S I dig it.
Marksy is offline
Old 11-11-2009, 11:20 AM   #3
Marks9-3's Avatar
Get a set of rotors from Nick at genuine. He x-drills/slots brembo rotors. Also I loved the Redstuff pads, they are a little more grippy when heated up than the GreenStuff.
Marks9-3 is offline
Old 11-11-2009, 11:44 AM   #4
Rudedog's Avatar
I agree with Marksy on getting a hold of the Aero front caliper carrier. Allows for bigger rotors. I also did that with the rears on my '97 Talladega. I can't speak to the pads. I put Hawks on the front and satisfied on the rears. Great pads, but if you are going to autoX I think Marks900SE has a good set up with Nicks rotors and redstuff pads.
RG Rude
WASSAAB member
1997 900SE Talladega (SQR stage 4)
2006 9-3SS Aero
Rudedog is offline
Old 11-11-2009, 12:02 PM   #5
JK
JK's Avatar
Hawk makes a bunch of different pad types, which did you have?
As some general advice, I will suggest NOT getting Greenstuff, don't even consider them. They are the worst brake pad that I've never thrown away. Not even sure why I've left them on the car so long, they are very underwhelming. Redstuff have been great though. Odd.
always a SAAB guy at heart
JK is offline
Old 11-11-2009, 12:03 PM   #6
Agree with what everyone said, for spirited driving and limited autocross I think the Viggen/Aero setup is pretty good. Rotors and pads from Nick are the way to go. An alternative, which I just got and am pretty happy with, are the Premium series rotors from R1 Concepts. A bit cheaper but are nice none the less. Painted hats are nice to prevent that ugly rust corrosion. Fronts are great, the rears are too however have a bit more surface area than the ones I had previously. There is a small area right where the pad isnt in contact with the rotor (just outside where it bolts to the hub) so there is a small ring of rust. . Just cosmetic but I am anal so notice it all the time. Either way both, are nice products.
-Ryan
99' Viggen
LB Viggen is offline
Old 11-11-2009, 12:23 PM   #7
Champ's Avatar
After running these discs on the lemons car, these will be my next disc purchase for basically any car I own down the road:
http://www.frozenrotors.com/store/1489%20FZR
You probably can't go wrong with EBC Red Stuffs
Champ is offline
Old 11-11-2009, 12:25 PM   #8
Castor Troy's Avatar
this.
Castor Troy is offline
Old 11-11-2009, 12:29 PM   #9
Champ's Avatar
And they really aren't that much more than the OEM rotor, and $25more each than Nick's slotted rotors.
Champ is offline
Old 11-11-2009, 01:20 PM   #10
Rudedog's Avatar
How do they feel on the road? Do they just handle/dissipate heat better than stock? Although I don't mean to discount the importance of that.
RG Rude
WASSAAB member
2006 9-3SS Aero
Rudedog is offline
Old 11-11-2009, 02:59 PM   #11
Champ's Avatar
There's a 95% chance you won't notice a difference during daily driving. On the track they just don't give up, and the life is amazing.
Champ is offline
Old 11-11-2009, 04:00 PM   #12
JK
JK's Avatar
The Frozen Rotors from last year's Lemons car (where I believe we put over 1000 track miles on the car) still look like new aside from some surface rust on the hats from sitting for a while before I parted the car out.
JK is offline
Old 11-11-2009, 05:03 PM   #13
LostAbbott's Avatar
I have EBC rotors that are slotted and dimpled on my Viggen with hawk hps pads and they both have held up great for the past two years.
LostAbbott is offline
Old 11-11-2009, 06:08 PM   #14
christian900se's Avatar
I will put a vote in for EBC redstuff pads. I have the EBC rotors (dimpled and slotted) and would probably have just gotten Nick's rotors or these frozen rotors if I have known better at the time.
christian900se is offline
Old 11-11-2009, 06:10 PM   #15
Rudedog's Avatar
Originally Posted by jk View Post
hawk makes a bunch of different pad types, which did you have?
As some general advice, i will suggest not getting greenstuff, don't even consider them. They are the worst brake pad that i've never thrown away. Not even sure why i've left them on the car so long, they are very underwhelming. Redstuff have been great though. Odd.
hps
RG Rude
WASSAAB member
2006 9-3SS Aero
Rudedog is offline
Old 11-11-2009, 06:59 PM   #16
hps
I think JK might have meant the type of HPS pad since there are several compounds depending on the intended use.
Old 11-11-2009, 07:20 PM   #17
Rudedog's Avatar
HPS is correct. Then there is HP plus and Performance Ceramic.
RG Rude
WASSAAB member
2006 9-3SS Aero
Rudedog is offline
Old 11-13-2009, 02:02 PM   #18
turboSAABman9000's Avatar
I am planning on getting the slotted brembo's and hawk pads from GS for my brake job.
turboSAABman9000 is offline
Old 11-13-2009, 09:10 PM   #19
another vote for Hawk HPS....
crazy stopping power and nice progressive action...
