Viggen wont start after cam install. - The Saab Link Forums
Old 10-14-2009, 05:41 PM   #1
GreySPG's Avatar
lol um can't see how this would have happened? Have done plenty of swaps on a classic. So anyway. took cams out and put the t5 cams in the same way the t7s were installed. bolted sprockets up and put tensioner in. everything looked normal. buttoned the valve cover up, put di in and turned the motor over twice with out it plugged in. then i plugged it back in and it just turned over and wouldn't start. it was dark out so i didnt want to dig deeper and try to remove the di cassette or diagnosed the problem in the dark out in my parking lot. I do have a spare cassette. but any ideas on what could have gone wrong?
AeRoTK2
GreySPG is offline
Old 10-14-2009, 05:53 PM   #2
SPG-GASM's Avatar
Did you double check timing before puttin the valve cover back on?
Either your timing is way off or you forgot to plug something in.
Also were the cam bolts torqued down?
SPG-GASM is offline
Old 10-14-2009, 05:57 PM   #3
does it even crank or just simply dead?
x2 on the timing.
rafal is offline
Old 10-14-2009, 06:06 PM   #4
GreySPG's Avatar
no i did not check the timing before i put the valve cover back on. how do you check tdc in a vig?i figured it would be fine becasue of the way i put the cams back in.
AeRoTK2
GreySPG is offline
Old 10-14-2009, 06:30 PM   #5
saabkid37's Avatar
it doesnt need to be "way off". when i put my 9k motor back together years ago, the exhaust was advanced barely 1 full tooth and the car wouldnt idle without holding my foot on the gas.
turn the motor over until the hash marks on the cams are about straight up and ill bet you see that one is a tiny bit off.
saabkid37 is offline
Old 10-14-2009, 06:35 PM   #6
stig's Avatar
If the timing was off 1 tooth, I'm sure the car would start. Mine would start and drive around with both cams retarded 1 tooth. It ran like shit and stalled all the time, but it ran.
'96 Miata - Simplify and add lightness
'96 9000 Aero - Complicate and add torque steer
stig is offline
Old 10-14-2009, 06:41 PM   #7
take the calve cover off, and remove the sparkplugs.
use a 14mm ratchet on the exhaust cam, and rotate forward until the cam marks line up.
when they do, the dash on the crank should line up, too.
if not, just crank it over, again.
all 3 should line up.
if not, take it apart, and line 'er up again.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 10-14-2009, 06:59 PM   #8
<winks>
rafal is offline
Old 10-14-2009, 07:22 PM   #9
saabkid37's Avatar
yeah if both are moved the same amount in the same direction its fine because the overlap is the same.
if you misadjust one and not the other, it doesnt like it.
Old 10-14-2009, 07:51 PM   #10
GreySPG's Avatar
first thing besides pullin the di...and tryin it...i'll pull the valve cover off and check the timing by alligning the notches
AeRoTK2
GreySPG is offline
Old 10-14-2009, 08:34 PM   #11
DeLorean's Avatar
be sure you are not 180 degrees off. 2 crank rotations for every 1 cam rotation.
DeLorean is offline
Old 10-14-2009, 08:42 PM   #12
GreySPG's Avatar
but if i didnt turn the motor over with the sprockets off how can i be 180 out?
AeRoTK2
GreySPG is offline
Old 10-14-2009, 08:46 PM   #13
DeLorean's Avatar
If you didn't, that should not be the problem.
DeLorean is offline
Old 10-15-2009, 04:05 AM   #14
saabkid37's Avatar
eh, ive installed a set of cams 180 off before...on a non saab tho...its not all that dificult to do lol
Old 10-15-2009, 04:23 AM   #15
stig's Avatar
I had one off at one point, too. It didn't like it, but it ran better than with both off. (Yeah, that job turned into a fiasco )
stig is offline
Old 10-15-2009, 04:58 AM   #16
spgeebee88's Avatar
theres a hash mark on the balancer and the two marks on the cams
spgeebee88 is offline
Old 10-15-2009, 07:11 AM   #17
lms
Did you zip tye the sprockets, if so it's very hard to f this up. I bet you have an electrical issue that will be fixed when you plug something back in. Just a guess.
lms is offline
Old 10-15-2009, 07:19 AM   #18
WyldSaabMan's Avatar
Anytime I do anything that involves removing the timing chain (even if I zip tied the sprockets) I rotate the crank by hand a few revolutions and make sure all the marks still line up.
I don't want to risk having my valves meet my pistons.
99 Saab 9-3se Imola Red
90 Saab 900 SPG Talladega red
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
WyldSaabMan is offline
Old 10-15-2009, 07:53 AM   #19
GreySPG's Avatar
yup of course i screwed my self. timing is way off. Where is the hash mark on the balancer? i've never worked on these cars to find tdc on one. do i have to take the wheel off and remove the plasic to see the inside of the balancer pully.. or do i just look straight down at the pully and see a hash mark smiling at me. i'm searchin the forums now.
AeRoTK2
GreySPG is offline
Old 10-15-2009, 07:55 AM   #20
GreySPG's Avatar
i zip tied both to the sprockets. but i cut the one on the intake side becasue i was trying to release the ten becasue i my socket was i size to small....thats where everything got screwed up.
AeRoTK2
GreySPG is offline
