Second time to the track - The Saab Link Forums
Old 09-30-2009, 09:20 PM   #1
JZW
Went out today, only got 3 runs, very busy since its the next to last test and tune. Got a trap speed of 125.59mph, but could not get a good second gear shift all night. I put on a solid rear mount, but it just will not shift if I speed shift it, goes fine at normal speed. The synchro must be shot.
I really felt like an 11 was in the car if I only could get one good first to second shift, but it was not in the cards this season.
Best was 12.631 at 122.63mph with a 1.8 60' and a double clutch on second gear, if I could have made that shift, I feel like an 11 would have been possible.... Dangit! Season over, no good synchro!
Here are the two best slips from tonight.
John
JZW is offline
Old 09-30-2009, 09:22 PM   #2
User
zingZACH's Avatar
Nice trap speeds at least And 91mph for the STi? That's terrible!
1988 900 Springtime in Sweden
zingZACH is offline
Old 09-30-2009, 09:40 PM   #3
JZW
Yea, I was bummed that I could not get one clean second gear shift
I just wish it was the start of the season, not the end.
John
JZW is offline
Old 09-30-2009, 10:06 PM   #4
You still beat the AWD in the 60' time! Nice launch.
2000 9-3 h.o.t.
J93O is offline
Old 10-01-2009, 06:35 AM   #5
Nick Taliaferro
GenuineSaab's Avatar
What slicks are you running? 8.5x 24 like me?
That 1.87 is starting to be an ok 60'
Looks like you are giving up quite a bit in the 330. But hard to tell without some logging, video or car based.
Nicholas Taliaferro
GenuineSaab is offline
Old 10-01-2009, 07:15 AM   #6
JZW
Yea, cannot get a good second gear shift, it just crunched and would not go every time, had to shift, hit the wall, stop, double clutch, try again, then hit the gas. It really sucked.
With a heavy vert a mile high with a missed shift, it was not too bad in my opinion, have to tear the tranny down and replace the synchros and what ever else looks worn, but not being able to shift is a big issue for 1/4 mile.
John
JZW is offline
Old 10-01-2009, 07:23 AM   #7
How many trannies is that now?
Three? Four?
You need to start a nursing home for old trannies...
Old 10-01-2009, 08:00 AM   #8
jimbo's Avatar
John, have you done anything to upgrade or prolong the trans you have in your car?
what type of fluid are you using?
Thanks
jimbo is offline
Old 10-01-2009, 08:30 AM   #9
JZW
Three? Four?
This is the same 2000 93 tranny I have been running for about 2 years now with gt3076, Holset, still works perfect on the street, just cannot speed shift it from first to second. We tore it down two months back and put in new input shaft bearings and LSD and new updated crush sleave.
I think for street use, this tranny would last for years.
John
JZW is offline
Old 10-01-2009, 08:31 AM   #10
JZW
Thanks
THe LSD is a huge help for these trannies and I did replace the main input and diff bearings when we put in the LSD. We put in the best looking synchros from the core I had to make a 4.45 box, but was not able to run that final drive because I was sent the wrong ring gear to match the LSD.
I run the newer grey bottle saab manual fluid.
John
JZW is offline
Old 10-01-2009, 08:33 AM   #11
John
wait...
How many times have you actually gone into it?
Old 10-01-2009, 08:38 AM   #12
Nick Taliaferro
You do realize that your "heavy vert is 3190lbs and the 3door vig is 3130 from SAAB specs not madeup numbers.
My car with the sub box and a 3/8 tank of fuel weighs 3160 without driver. We normally keep 1/2 tank or more to ensure fuel pickup. In the drag car we run nearly a full tank. But thats another mess. Mine on the scales. http://genuinesaab.com/gallery/VigSuspension
Run the stock 0063 fluid. If you run to heavy clutch disk or can't disengage it properly quick enough you will have the same issues. You can remove some of the dashpot function and play with iac control to get the motor to drop revs quicker. I didnt do much of this in my Viggen with the 2871
Is there a rubber COF for altitude..
Nicholas Taliaferro
Old 10-01-2009, 08:39 AM   #13
JZW
My current tranny has only been into once for the LSD install.
Now, since I started about 4 years ago, I have been through about 4-5 trannies total, but this last 93 tranny has held up much better than the ng900 trannies I had before.
I think a good 93 tranny would last a good while and this one would keep going for a while if I was not drag racing it.
I have some more plans for a "beefed up" 5 speed with some tricks to help longevity. Will be testing them this winter and if they hold up to the abuse, will be selling them to other people. Need to get one in my race car and Steve's cse and my aero and see how they hold up to some mild track and strong street tunes.
John
JZW is offline
Old 10-01-2009, 08:47 AM   #14
JZW
Yea, I had you at sea level
Here is the CF for sc/turbo cars to sea-level, CF in half.
My time would be 12.25 at 126.06mph
http://www.nhra.net/tech_specs/altitude.html
PS> Don't forget my heavy mild steel roll bar I had to put in at another 120 #
JZW is offline
Old 10-01-2009, 08:52 AM   #15
crazysteve's Avatar
John just cram it into second...drive the car like its not yours thats what I do.......
Oh ya they are not mine
crazysteve is offline
Old 10-01-2009, 08:58 AM   #16
JZW
I tried everything to get it to go into second and the harder I tried to cram it, the worse it would hit a wall
JZW is offline
Old 10-01-2009, 09:18 AM   #17
Nick Taliaferro
I get to run a altitude cf too.. We are close to 2k feet this is my street car
who cares.. quit making excuses and figure out how to go fast..
PS roll bar tube is about 2lbs per ft.. so how many feet are in that cage? ~30ft.. nascar spec with multiple door bars??
Congrats on at least running the car.
Nicholas Taliaferro
Old 10-01-2009, 09:27 AM   #18
dip
dip's Avatar
Send a message via Skype™ to dip
2lbs per ft sounds about right. My old bar took 25 feet of tubing and the total weight was 60 lbs.
dip is offline
Old 10-01-2009, 12:19 PM   #19
JZW
Pretty thick mild steel, door bar, cross bar for road racing support and or seat-belt harness. I did not weight it, but the cage builder said it would be around 120# for the entire piece and 60# for crome moley, which I wanted, but then found out the builder could not make the bend of the main hoop tight enough and we had to go with mild steel. Estimated weight of the crome moley was 60#, mild steel was almost twice as heavy, but half the cost.
My car is 3250# with me in it now.
John
JZW is offline
Old 10-01-2009, 12:22 PM   #20
JZW
You are fighting hard here. I did not go off of density altitude, which can be over 11,000' in the middle of the summer. Is your track on the NHRA list? What was name, lets look it up and see what it gives in CF.
As you know, I did not post or claim any CF, would like to run into the 11's at least with no cf. Would also like to trailer it down to Tulsa or somewhere and try it there and feel that nice gooey air you boys get to play with all the time.
John
JZW is offline
