stage 5 issues - The Saab Link Forums
Old 09-30-2009, 01:15 PM   #1
saabskijc's Avatar
stage 5 issues
Ok guys so I recently did a stage 5 build and have not got my car running good since I
ts a stage 5 jzw tune and I really don't think anythings wrong with the tune john and I have been going back and forth for a while now and he is really good about answering my questions. But I really was just wondering everyones take on things.. ok here's the issues john says boost request is for 26psi and I'm only holding 10psi in second and 18psi in 3rd 20in 4th I know very weird bpc has been switched out 4 times with other working ones same results at 3rd and 4th gear wot when it hits 18 or 20 psi I hear a flutter sound I'm not sure what it is I have checked everywhere for boostleaks no luck finding any tightened up my couplings and hoses I just don't even know what to replace or fix to get this problem sorted out I'm in the process of putting in my wideband 02 so I can monitor my air fuel
Please guys help me out thanks josh
saabskijc is offline
Old 09-30-2009, 01:30 PM   #2
What turbo is on your car?
EDIT: What supporting mods for stage 5 are on your car?
Old 09-30-2009, 01:35 PM   #3
saabskijc's Avatar
oh sorry
TD04-18t
ETS intercooler
3" JT exhaust
open air intake
and i forgot to mention before base boost set to 10 same results when set to 6
Old 09-30-2009, 01:36 PM   #4
saabkid37's Avatar
Originally Posted by saabskijc View Post
i hear a flutter sound i'm not sure what it is i have checked everywhere for boostleaks no luck finding any tightened up my couplings and hoses
bpv
saabkid37 is offline
Old 09-30-2009, 01:38 PM   #5
saabskijc's Avatar
forge bov i tried going back to stock and made the same exact noise it sounds like its comming from the right side of the engine bay(passenger side)
Old 09-30-2009, 01:41 PM   #6
VWSAABVT's Avatar
Mine flutters too at Wot, changed bpcs while dynoing and that added some power but I still got the fluttering, my base boost is set to 9 psi.
Do you have injectors or fpr also to go with the tune?
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 09-30-2009, 01:53 PM   #7
mike9000aero's Avatar
what RPM are you hearing this fludder and at what boost
97 9000 cse stage x Holset hx35w 330whp 373lbft sold
09the VW GTI day stg 1
mike9000aero is offline
Old 09-30-2009, 02:00 PM   #8
saabskijc's Avatar
The fluttering is always heard at whatever the highest boost I can reach rpms varry I forgot injectors I have green giants and 3.5 fpr
Old 09-30-2009, 02:03 PM   #9
SPG-GASM's Avatar
Ck your wastegate. Sounds like its opening up too soon.
SPG-GASM is offline
Old 09-30-2009, 03:17 PM   #10
Do you get the fluttering sound on mid boost too, like when shifting from 2nd to 3rd with an easy acceleration?
Or is the flutter limited to WOT pulls?
...and I agree with checking the WG. That should help recapture more boost, but not sure that's related to the sound...
Old 09-30-2009, 03:35 PM   #11
saabskijc's Avatar
It is limited to wot I have disconected the wastegate and it boosted to 25+ in a second how else would I check the wastegate
Old 09-30-2009, 03:48 PM   #12
Is anyone else thinking compressor surge?
Have you lubed the Forge recently?
Old 09-30-2009, 04:06 PM   #13
comtrang's Avatar
My friend's WRX is making a similar sound and his boost doesn't hold rock solid so he's trying out a different WGA. Compressor surge is what I thought when I first read it, though.
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 09-30-2009, 04:07 PM   #14
comtrang's Avatar
What's your base boost at?
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 09-30-2009, 04:09 PM   #15
VWSAABVT's Avatar
oh sorry
TD04-18t
ETS intercooler
3" JT exhaust
open air intake
right here
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 09-30-2009, 04:19 PM   #16
Maybe a stronger actuator or helper spring might be the ticket....
Old 09-30-2009, 04:31 PM   #17
VWSAABVT's Avatar
Mine didn't do this at lower boost levels only at higher ones that were achieved after I put a helper spring on.
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 09-30-2009, 04:43 PM   #18
If the WG is opening too early, or erratically it would cause that fluctuating boost...but the noise is funky. If the boost is exceeding the BOV, then that would contribute to comp surge.....
Another bit of funkiness is the Forge, which can sometimes make that fuuh-fuuh-fuuh sound at low boost levels...which could mean the BOV spring is too light.
Old 09-30-2009, 04:53 PM   #19
VWSAABVT's Avatar
I tried my car with the forge and an rfl and have the same sound with both bovs
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 09-30-2009, 05:27 PM   #20
saabskijc's Avatar
ok so I do have a helper spring that's how I achieved the 10psi base boost, I cleaned my bov right when this started I originally thought it could be wastegate flutter I don't know how I could rule that out without buying a new wastegate
