How much boost can i run? - The Saab Link Forums
Old 09-30-2009, 07:31 AM   #1
01redvig's Avatar
Send a message via AIM to 01redvig
i want to buy a boost cotroler so i can tweek how much boost im giving to the car, BUT i dont want to over boost the car and pop the engin!
give me an idea so i can do this with smarts
-DOLLIVER-
01redvig is offline
Old 09-30-2009, 07:36 AM   #2
Take some time to learn about the car, and why a boost controller might be a bad idea...
Take some more time to discover some of the key maintenance issues you'll need to address before turning up the boost.
Then take some more time to learn about T7Suite and the mods you want for safe, optimum performance.
Then....
Have fun.
Old 09-30-2009, 07:39 AM   #3
nowhereman's Avatar
Then....
Have fun.
x2
best way to do it for longevity. esp with t7
2008 9-3 SS: Stg 1
nowhereman is offline
Old 09-30-2009, 07:40 AM   #4
mcrowley's Avatar
If my memory serves me correctly your car is already tuned...
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 09-30-2009, 07:44 AM   #5
We really want to see that car go fast...but safely and reliably. That's the key thing. There are loads of guys who did some quick modding that yielded good results initially, but didn't follow through on some key maintenance stuff and....BOOM.
There are lots of folks here who will help you avoid those errors and lead you through the minefield....
EDIT: Just saw the previous post and looked at the OP's profile....Boost controller with a tuned ECU is a HUGE no-no. Do you have a fuller list of what mods were done to your car?????
Old 09-30-2009, 08:33 AM   #6
01redvig's Avatar
upgraded intercooler,upgraded Bpv, stage 3ecu (sqr), full 3in exhaust including downpipe, air.intake and thats about it for performance mods but i feel like im at the end of m rope for performance without steping up the turbo or something
-DOLLIVER-
01redvig is offline
Old 09-30-2009, 08:39 AM   #7
Aside from T5 cams, cobra pipe and a retune, , it's time for forged pistons and a bigger turbo. After just buying the car, I doubt you have the $3-6k to delve into that.
Jameson is offline
Old 09-30-2009, 09:10 AM   #8
9000Andrew's Avatar
Send a message via AIM to 9000Andrew
Dude, your car is probably faster than 90% of most Saabs on here. A stage 3 Viggen should destroy most cars on the road also.
While it's tough to tell someone to stop dumping money into their car, you may just have to accept the fact that there's not much more you can get out of the car without a serious investment. Like Jameson says, are you prepared to spend multiple thousands? Even if you were, would the possibility of breakdown and long term durability concerns be worth it? I think that sometimes we forget that we own 4 cylinder front wheel drive cars. At a certain point, going any bigger in terms of performance is just a recipe for disaster. At stage 3, you're at a happy median where you should have great power along with a reasonable assurance that your car will last long-term.
Boost is an addiction!
2006 9-3 Aero 6mt
2005 9-3 Aero auto (wife's ride!)
9000Andrew is offline
Old 09-30-2009, 09:23 AM   #9
Not to mention, if this is a daily driver, BIG power and FWD just equals silly amount of wheelspin.
Also, stock power has a way of busting crush sleeves and taking out 2nd gear too. Ask me how I know. Thats another $4-6k to make right. Oh yeah, just add an LSD....that does not cure much....again, ask me how I know.
I think Stage 4 with ALL supporting handling and brake mods is about as good as it gets for this platform. If the car is not mostly street driven ok, then strip it, LSD and cage it, and say screw it and throw tons of power at it.
Jameson is offline
Old 09-30-2009, 12:11 PM   #10
Double ditto to all of the above.
You're right at the edge of the safety envelope without getting new pistons. Although there are guys who have run a bigger turbo (18T) on stock interrnals, nearly everyone I know will tell you that it's definitely not recommended with a B235 engine.
Drive the car for a bit and see what you think....
Old 09-30-2009, 02:40 PM   #11
NeedForSwede's Avatar
So i've heard t-7 bottom ends are weaker than t-5 bottom ends. What are the main differences? I'm guessing the rods are still pretty strong if you guys haven't suggested to the OP to replace those. Are the pistons aluminum on these cars?
NeedForSwede is offline
Old 09-30-2009, 02:59 PM   #12
It's the pistons. Most everything else can stand up to BIG power.
Jameson is offline
Old 09-30-2009, 04:02 PM   #13
comtrang's Avatar
You kinda said it yourself, if your goal really is to get more power. No reason to push the turbo more with a boost controller if there's nothing to be gained from it.
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 09-30-2009, 04:14 PM   #14
IIRC, the T7 pistons are cast aluminum (hypereutectic?) but are very light to reduce reciprocating mass. There's a shallow depth between the top of the piston and the first ring land, so they're not very forgiving of running lean. In more than a few cases, folks have leaned out the car via improper tuning, over-revving ("money shifting"), or even a bad MAF with a totally stock car. Piston cracks at high revs, gets caught in the bore, rod snaps, and then there's an extra hole in the engine block....
But with good maintenance, stock T7 blocks are fine up to 300hp (Stage 3+ ish)
Old 09-30-2009, 05:01 PM   #15
132417SAAB's Avatar
if you really want to ramp up the power talk to mike d. He has a rebuilt b234. Thats the 2.3 motor found in 9000's. This motor 100% stock will handle 400 whp and 6k all day long.
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 09-30-2009, 06:31 PM   #16
Paul Campagna's Avatar
Stage 3 Viggen and you want more? Wow.
You should be able to walk away from most cars on the road, but if you want to hang with 400+hp cars, Front wheel drive is the biggest issue IMO. It's just not the best platform for big power...
Definitely listen to people on this board too. It will save you lots of headaches.
Paul Campagna is offline
Old 09-30-2009, 07:06 PM   #17
christian900se's Avatar
I have to say, if my car had any more power than the 285whp (automatic ng900) it has now, there would be a number of situations where it will really be almost undriveable. It gets scary in the rain, especially if you really need to accelerate (i.e. onto the Merritt Parkway).
You can probably get a more aggressive tune, but you have a Viggen for godsake. You can't afford the couple hundred it takes for a tune?
christian900se is offline
Old 09-30-2009, 08:03 PM   #18
Wagon Shaggin'
Saabeh's Avatar
Stop telling the guy not to upgrade more, he asked a question and didn't need to get told.
Saabeh is offline
Old 09-30-2009, 08:07 PM   #19
T5 cams, 6cm2 exhaust housing, cobra pipe...then be done with it. The cams made a huge difference on my un-tuned 9-3 (with stage 4 supporting hw). The two combined should give you quite a bit more top end, and read the reviews of the big intake pipe on GS's website. Maybe not awesome for hp gains but decent sound and spoolup. Otherwise like they say get pistons, injectors, and have your TD04 built up!
2000 9-3 h.o.t.
J93O is offline
Old 10-01-2009, 05:32 AM   #20
nowhereman's Avatar
do what you want man but like most people said at this point it is going to cost you $thousands to get a few more HP and remove some of the reliability.
also how can you not be happy with a stg 3 viggen? like really?
2008 9-3 SS: Stg 1
