custom vig exhaust second o2 sensor???? - The Saab Link Forums
Old 09-28-2009, 12:04 PM   #1
GreySPG's Avatar
hey i'm plannin on building a 3" dp and no cat then just transition into the stock exhaust before the axle..since this is my daily driver and i have 2 days i'm just doin that. Will the second o2 sensor cause the car not to run correctly if i have no cat? or even if i remove the second o2 sensor? thanks
-Brian
AeRoTK2
GreySPG is offline
Old 09-28-2009, 12:14 PM   #2
Wagon Shaggin'
Saabeh's Avatar
You will have a check engine light. That second o2 is there to make sure the cat is operational. Removing it would not be the best idea.
Saabeh is offline
Old 09-28-2009, 12:19 PM   #3
turbojohnny's Avatar
this has been covered before, i think t7 suite can remedy the problem, but a search would probably be very helpful.
turbojohnny is offline
Old 09-28-2009, 01:06 PM   #4
christian900se's Avatar
I think that is T5suite only for now, it is definately not the best of ideas to forget about the downstream o2 sensor.
On that note, will it make the car fail emissions if you turned off the rear o2 sensor?
christian900se is offline
Old 09-28-2009, 01:09 PM   #5
Wagon Shaggin'
Saabeh's Avatar
Yes it will. A CEL on an OBD2 car is fail.
Saabeh is offline
Old 09-28-2009, 02:02 PM   #6
User
zingZACH's Avatar
Well I know that T7Suite can disable the rear o2...
1988 900 Springtime in Sweden
zingZACH is offline
Old 09-28-2009, 02:27 PM   #7
GreySPG's Avatar
i dont care about emissions, just functionality. i dont have access to t7 suite. So i can put the o2 sensor in and pop a cell but the car would run fine?
AeRoTK2
GreySPG is offline
Old 09-28-2009, 03:19 PM   #8
GreySPG's Avatar
so then if i keep the second o2 sensor what will happen besides check engine light?
AeRoTK2
GreySPG is offline
Old 09-28-2009, 03:42 PM   #9
Best bet is to use a cat. You're not going to lose much power, if any, and you're saving the earth one drive at a time. Use a cheap Catco cat and you're set.
When you do that...or instead of doing that...weld in an 02 bung after the cat, then screw in an O2 sensor extender (also called a "spark plug anti-fouler") That might remove the CEL.
Old 09-28-2009, 03:47 PM   #10
-Brian
Wait...what?
Old 09-28-2009, 03:49 PM   #11
GreySPG's Avatar
hmmmm excellent. looks just like a bunch of male/female plugs then screw on the o2 sensor.
AeRoTK2
GreySPG is offline
Old 09-28-2009, 03:50 PM   #12
GreySPG's Avatar
i'm goin 3" into the stock exhaust before the rear axle. getting rid of both cats and the one muffler.
AeRoTK2
GreySPG is offline
Old 09-28-2009, 03:51 PM   #13
GreySPG's Avatar
and your saying to extend the sec o2 sensor out to prevent the engine light to come on
AeRoTK2
GreySPG is offline
Old 09-28-2009, 03:52 PM   #14
Yep....the anti-fouler should help with that....
Is the stock Viggen system 2.5"??
Old 09-28-2009, 03:55 PM   #15
GreySPG's Avatar
yeah its 2.5
AeRoTK2
GreySPG is offline
Old 09-28-2009, 03:56 PM   #16
GreySPG's Avatar
jsut gotta find one of those antifouler. ..... btw mike.... florida is great.
AeRoTK2
GreySPG is offline
Old 09-28-2009, 03:59 PM   #17
OK.....I forgot that the Vig had the larger pipes as a standard item, so necking down from 3" to 2.5 should be totally fine, especially that far back.
I'd leave one cat there to prevent T7 from going batshit crazy -- and in case New Hampster decides to start doing visual checks -- but use the extender...
That's going to be a nice sounding system....Are you deleting both the center resonator and the back box, or necking down just before the back box?
EDIT: You're in Florida now? I think they got rid of inspections....
Old 09-28-2009, 04:00 PM   #18
GreySPG's Avatar
yeah I put 06 aero sport combi rims on the vig...tinted windows, lowered, rear sway bar, and this simple project along with ss brake lines. 3 bucks for a simple o2 extender saves alot of hassle. thanks buddy
AeRoTK2
GreySPG is offline
Old 09-28-2009, 04:12 PM   #19
GreySPG's Avatar
yesssir. right above clearwater. i'm takin the first muffler out. and transitioning down to the stock pipe before the two bends when then go over the axle
AeRoTK2
GreySPG is offline
Old 09-28-2009, 04:23 PM   #20
Bullseye's Avatar
I got one at autozone. It does work, but you might get nabbed for no cat at state inspection. PA inspection mechanics are supposed to do a visual inspection of the exhaust. So, I opted to get GS's DP.
"If guns cause crime, all of mine are defective." T. Nugent
Bullseye is offline
