Really low Dyno numbers - The Saab Link Forums
Old 09-26-2009, 02:21 PM   #1
krelly's Avatar
Well I dyno'd my Viggen today expecting a bit better results. Stage 3 Viggen with the following mods:
3 DP
2.5 saabsport
T5 cams
MP intercooler
MP BPV
intake
Cobra pipe
ECUproject tune
Numbers are very low, what would you expect to see numbers wise? guy was telling me how lean the car is running, could it be the mailbox tune?
Also we tightened things up checking for any leaks and noticed this near the cobra pipe. Its like a hose existed there and its now gone, not sure what it is or where it went to seeing it wasnt my car before and im no mechanic
99' Viggen Stage 3(sold)
06' VW GLI
krelly is offline
Old 09-26-2009, 02:28 PM   #2
christian900se's Avatar
Thats definately pretty low. For comparison, stock Viggens have dyno'ed between 210-235whp so I would certainly expect more from your setup. What is it boosting?
christian900se is offline
Old 09-26-2009, 02:42 PM   #3
Legit's Avatar
Things to do:
- Block off top silicone hose of BPC
- Check base boost
- Clean MAF
- Change plugs
- Reset ECU
Numbers should be about ~260whp /~300wtq
2002 Viggen Convertible
Legit is offline
Old 09-26-2009, 02:51 PM   #4
The missing hose, more info: http://www.saabcentral.com/forums/sh...d.php?t=106554
This is not the issue.
The tune wouldn't be the issue neither. Zach is running his Viggen with a same one and he's fine from what I remember.
Something must have happened recently. It was pulling two lengths on a 02 S4 month before you got it, with the same exact set up.
I have no idea what could that be. I would guess the wastegate set up, since it's the last thing I adjusted.
rafal is offline
Old 09-26-2009, 02:53 PM   #5
Is that not a hose missing off the BPC? Would that not be a large problem?
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 09-26-2009, 02:55 PM   #6
Legit's Avatar
Its just for the intake return. It can be blocked off to bypass the EVAP system and restore power
Legit is offline
Old 09-26-2009, 03:12 PM   #7
User
zingZACH's Avatar
It only restores power if there is a problem with the check valves. Blocking mine off does absolutely nothing for me.
And as Rafal said, my car pulls very hard with similar mods.
1988 900 Springtime in Sweden
zingZACH is offline
Old 09-26-2009, 03:15 PM   #8
In my car blocking off that hose made a huge difference. As far as I remember locating that valve is kind of a PITA so I wouldn't bother with that.
Zach, what happened to your wastegate? I thought you replaced it or something? Forge?
rafal is offline
Old 09-26-2009, 03:50 PM   #9
User
zingZACH's Avatar
Yeah, I have a forge wastegate.
zingZACH is offline
Old 09-26-2009, 04:21 PM   #10
WG wouldn't be making it run so lean....
Bad gas?
Old 09-26-2009, 04:42 PM   #11
krelly's Avatar
Nope i run 93 strictly through it. It pulls hard but the boost will SOMETIMES go to 16 pounds then taper off to like 12, then sometimes it will only boost to like 11 then come down to 8 or so. Theres no real consistency in it. My last Vigen with just an intake would full on break tires loose in 2nd, while this one doesn't really as much.
What would you guys check and replace first. In order you think it should be done?
06' VW GLI
krelly is offline
Old 09-26-2009, 05:17 PM   #12
Legit's Avatar
- Plug BPC hose
- Clean MAF
- Change Plugs (NGK BCPR7ES, gap to 1.0mm)
- Reset ECU
Legit is offline
Old 09-26-2009, 05:21 PM   #13
krelly's Avatar
Legit, you really are legit.
06' VW GLI
krelly is offline
Old 09-26-2009, 05:24 PM   #14
Legit's Avatar
All of what I said, plus make sure your vac lines are hooked up right and dont leak.
Also, thanks lol
Legit is offline
Old 09-26-2009, 07:30 PM   #15
mike9000aero's Avatar
vac lines
plugs
reset ecu
check base boost and waste gate since previous owner says he screwed with that last before you bought it
97 9000 cse stage x Holset hx35w 330whp 373lbft sold
09the VW GTI day stg 1
mike9000aero is offline
Old 09-26-2009, 08:42 PM   #16
User
zingZACH's Avatar
How about an O2 sensor? My car doesn't really break loose in 2nd all that often either though... Hmm, Now I want to know what my AFR is. It breaks loose once in a while, but not very often.
I am just curious now.
zingZACH is offline
Old 09-27-2009, 07:31 AM   #17
krelly's Avatar
Zach, what do you boost up to? Is it consistent? Mine doesn't seem very consistent, well i know it isn't since the boost gauge doesn't lie.
Something is causing it to be lean, what could it be? Sucks its pouring out today, i wanted to run around and replace a few things before the JETS game, doesn't look like thats happening.
06' VW GLI
krelly is offline
Old 09-27-2009, 07:38 AM   #18
mvadenais's Avatar
What software are you running?
88 900 SPG Black
95 9000 Aero Green
00 9-3 Viggen Silver
mvadenais is offline
Old 09-27-2009, 07:42 AM   #19
how lean is lean? actual a/f info
edit never mind saw the picture of the dyno....12.5 is spot on in my book i would not be to worried about 12.86 or anything
Old 09-27-2009, 07:51 AM   #20
mike d's Avatar
x2,, 12.86 is not in teh danger zone,,
especially at 190hp...
could it have simply been a bad dyno run? does the car feel low on power?
could a cam be one tooth off?
what is the vacuum at idle?
MikeDTuning.com
mike d is offline
