Dyno fun - The Saab Link Forums
Old 09-26-2009, 06:04 AM   #1
Dyno fun
Had the hobby car on rollers today, here is a teaser
http://www.stcf.net/ProjectX/xdyno.wmv
Guess the figures
Vigge is offline
Old 09-26-2009, 06:23 AM   #2
537.6
Old 09-26-2009, 08:11 AM   #3
666bhp/690Nm
601 uncorr whp
http://www.stcf.net/ProjectX/run3.jpg
Vigge is offline
Old 09-26-2009, 08:16 AM   #4
Drew in Houston's Avatar
Hah ha, nice. That made me giggle looking at it.
...and no parts on the floor?!
It'd be nice if you put a quick build list here with the dyno info.
Drew in Houston is offline
Old 09-26-2009, 08:32 AM   #5
No parts on the floor and would have been very surprised if there where since the engine has been spanked with that power alot. Two other runs where also drive on dyno 648bhp and 661bhp with some tweeking of parameters in between.
Motor specs in shortness
standard B204 bottom engine
T5 head gasket
orignal head bolts
Mildy ported head with orig size valves, stiffer springs (volvo) and Enem 10.4cams, adjustable cam gears.
Holset HX40super with #18 turbine housing in x-manifold
3.5" DP/exhuast, 60mm EWG
Tatech ECU
W/M stage I kit
Vigge is offline
Old 09-26-2009, 10:09 AM   #6
Svenska94Aero's Avatar
Send a message via AIM to Svenska94Aero
Number of the beast indeed! Well done!
1973 99 EMS - Big plans
1990 900 SPG - Go-kart with a Holset
1995 9000 CS - PITA
Svenska94Aero is offline
Old 09-26-2009, 10:18 AM   #7
comtrang's Avatar
GREAT numbers! You're using a 10% loss, isn't it closer to 12%?
Makes me feel better about my own stock headbolts. How many miles is on the motor, or is it different between the head and block? It's nice to see that you "only" have cams, w/m, larger compressor side/turbine housing, and .5" more downpipe than me
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 09-26-2009, 10:24 AM   #8
comtrang's Avatar
PS
I'm mad your project car still looks better on the outside than my daily driver.
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 09-26-2009, 10:41 AM   #9
Legit's Avatar
Oh my.
2002 Viggen Convertible
Legit is offline
Old 09-26-2009, 10:51 AM   #10
Factors from are from dyno downrun.
The motor is rougly 30k km driven now, but use is as you know which would count up for much much more of "normal" style miles with occasional spanking. Up till now has been driven through 5 standing mile events (several runs in each) and the hundreds of long test runs.
Vigge is offline
Old 09-26-2009, 11:02 AM   #11
132417SAAB's Avatar
info on valve springs?
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 09-26-2009, 11:14 AM   #12
as written above
"Mildy ported head with orig size valves, stiffer springs (volvo) and Enem 10.4cams,"
Vigge is offline
Old 09-26-2009, 02:00 PM   #13
comtrang's Avatar
There's a ton of info on valve springs in my Holset thread and I copied all of it into a new one.
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 09-26-2009, 02:16 PM   #14
Originally Posted by Vigge View Post
666bhp/690Nm
601 uncorr whp
That's awesome!
Nice work!...
Old 09-26-2009, 10:17 PM   #15
User
zingZACH's Avatar
Unreal..... so happy you are still on the stock bottom end
Very impressive.
1988 900 Springtime in Sweden
zingZACH is offline
Old 09-27-2009, 04:07 PM   #16
mvadenais's Avatar
real nice numbers. Great work
88 900 SPG Black
95 9000 Aero Green
00 9-3 Viggen Silver
mvadenais is offline
Old 09-27-2009, 04:43 PM   #17
Nice curves
Must be a whole lotta fun between 3-6k RPMs. I can almost seek your cheeks being pulled back like the old centrifuge tests of the 1950-60s.
The heads aren't the ones you posted pic's on a while back are they? They seemed to be a bit more than 'mildy ported'.
Keep up the great work - gives all something to target.
hstanton is offline
Old 09-27-2009, 07:18 PM   #18
comtrang's Avatar
Yep I'm aware. Everytime I go to floor it I feel guilty but then that "Vigge-does-it-at-every-chance" feeling comes in and the guilt is gone. Just predicting when all my stocks stuffs are gonna bite the dust.
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 09-27-2009, 07:49 PM   #19
christian900se's Avatar
Incredible work, it almost seems like the car is not as powerful as the video shows because of the super smooth power delivery.
christian900se is offline
Old 09-28-2009, 08:11 PM   #20
JZW
666bhp/690Nm
601 uncorr whp
Looks pretty good, does seem like the registry is kind of small. Its strange to see the torque curve as high as the hp with the nm torque numbers, I like seeing the flat torque curve much better.
I got my bosh fuel pump going and it made a world of difference. If I still have a transmission after this weeks drag race, will have to get back on the dyno and see how mine is doing.
John
JZW is offline
