the new drag car, ng900 style - The Saab Link Forums
Old 09-23-2009, 08:56 AM   #1
mike9000aero's Avatar
well im a 9000 guy and have put a lot of work into my 9000 but dont want to keep going though transmissions on my daily driver...soo i broke down and am going to buy this not sure of year or milage but i know its white a 2 door, 5 speed, turbo for 600 bucks runs and drives and needs only ball joints and body love...
this is going to be a track only car and not driven to the strip so, its getting gutted...
Plans are td04 6cm from a 9000 aero...large front mount walbro 255 just so i know i have plenty of fuel..what else...what makes these car stick to the ground on take off...i know next to nothing on 900's
only pic i have
[IMG][/IMG]
97 9000 cse stage x Holset hx35w 330whp 373lbft sold
09the VW GTI day stg 1
mike9000aero is offline
Old 09-23-2009, 09:06 AM   #2
Follow what Nick from Genuine has done with his 2.0 track car.
http://www.genuinesaab.com/cars/drag20.htm
Tboy is offline
Old 09-23-2009, 09:12 AM   #3
User
zingZACH's Avatar
Awww I love white ng 3 doors... I'd make it pretty instead They're pretty rare!
1988 900 Springtime in Sweden
zingZACH is offline
Old 09-23-2009, 09:19 AM   #4
JZW
Just the nira alone is 2300 bucks!
I would do what others have done to go fast, its not that complicated, slicks really, really, really helps, then a holset hx 35 would be a nice addition or even a similar powered turbo.
I have seen a ng900 pull 1.9 60' times with the 9k tdo4 and run in the mid 13's, but the gt3071wg with no cams or anything like that could get you into the low 13's to the high 12s as Mark Bellingham did.
You will need poly motor mounts for sure, good tires, some suspension parts help and then some practice launching. That will be a good car to start and its all about power to weight, so if you can get the weight down, you will be able to do much more with much less in the power department!
good luck,
John
JZW is offline
Old 09-23-2009, 09:29 AM   #5
hey john with an exhaust or should i say open custon down pipe and a large intercooler, and intake, td04 6cm2 could i drop your tune for my 9000 into this and run it or do i need a new tune all together?
Also plan is to completly strip this ca down if its not needed to run it wont be on the car...just a body with one cheap seat from pepboys or somthing...i will most likely keep the dash in there, probly build a sheet metal hood that comes off with hood pins and get rid of the hinges...same with hatch get rid of that and make a sheet metal hatch with hood pins and plexy glass, or at least take the glass out and use plexy glass
Old 09-23-2009, 09:44 AM   #6
jimbo's Avatar
Take out the glass and put some lexan..
jimbo is offline
Old 09-23-2009, 09:45 AM   #7
kingofkrunk's Avatar
the windshield has to stay glass .... but the rest can be plexi or lexan
kingofkrunk is offline
Old 09-23-2009, 09:46 AM   #8
Oh .... ps .... awesome! lol ..... id love to see you run next season ... where do you race?
Old 09-23-2009, 10:09 AM   #9
132417SAAB's Avatar
you will need a different tune because the ng900's have the 2.0 motor instead of the 2.3 in 9ks
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 09-23-2009, 04:43 PM   #10
what is differant? if i put a 2.3 in it wouldnt it run that engine with no ecu change?
Old 09-23-2009, 04:44 PM   #11
i kind of want to wind the piss out of this engine at 8000+ rpm that sounds fun....what the highest rev limit i can get out of trionic but it shits its self?
Old 09-23-2009, 04:57 PM   #12
A good point...
It's also worth remembering how many times he's needed to change transmissions and clutches...
Old 09-23-2009, 09:28 PM   #13
comtrang's Avatar
Originally Posted by mike saunders View Post
a good point...
It's also worth remembering how many times he's needed to change transmissions and clutches...and create prototype transmission mounts and control arms
fixed
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 09-23-2009, 09:53 PM   #14
christian900se's Avatar
Hahaha Branden... I think this is going to be a cool project, at least you have some of Nicks experience to run off of.
christian900se is offline
Old 09-24-2009, 03:36 AM   #15
True, there's a lot of expensive R+D going on with each pass, but it's still worth remembering that there's no magic bullet for the type of increased drivetrain wear you're going to see by launching at a track.
Nick and his crew have done a fantastic job coming up with ways of strengthening transmissions and bolstering floppy engine mounts, but there's no new clutch made of magic Viking panty silk that resists burning out when dropped at 3,000 RPM
Old 09-24-2009, 03:39 AM   #16
well thats kind of the idea behind this car is i can beat it hard and if it breaks not scramble to get it fixed....my 9000 is my DD also so blowing trans every weekend at the strip would get old
Old 09-24-2009, 03:46 AM   #17
It seems like people think that what Nick is doing is rocket science....It's not.
Mad Props to Nick and his crew. They are smart, good fabricators, and willing to break stuff. I think it also helps to have some spare parts on hand.
But this sort of thing is what ANY racing folk do. A friend and I are slowly making progress on his drag car. Its a Chevy Monza that in the end will have a big block stuffed in it. It's new territoiry for us for sure. The stock front end of the monza is not strong enough nor big enough for the big block, so it has all come off and we are working on a tube front end to match the tube rear half of the car already in it (previously had a small block). It's all custom, and we have no guides. Thats the fun of racing I think, building it!
If you don't want to break your car, don't race it. Thats how you know what to improve next, it's what just broke, and breaking stuff goes hand in hand with going fast (and costing money )
Tboy is offline
Old 09-24-2009, 06:24 AM   #18
Nick Taliaferro
GenuineSaab's Avatar
Build it.. See how fast you can go on the tdo4 the 2.0 is the way to go I am certain. Lets see how fast you can go on the gt30.. Not crazy big turbo but a reasonable street turbo. Just odd how nobody seems to be able to get close to those times but Robert Uhr and Marko with lots more go..
I have new clutches on the way, just not from spec. Just taking some time and I didnt want to wait.
Nicholas Taliaferro
GenuineSaab is offline
Old 09-24-2009, 09:01 AM   #19
well racing will have to happen next season...but i think with a decent tune, td04 and fully stipped interior it should run pretty good...this is going to be the biggest backyard do it your self build out there im sure...as i plan to have next to nothing in this car so its disposable lol...not that i want to strip it to race it to throw it away when it breaks but very budget minded as i am still always going to dump most my money into my 9000
Old 09-24-2009, 10:08 AM   #20
Magic Viking panty silk?
