Clutch Done (Well Done) - The Saab Link Forums
Old 09-22-2009, 10:44 AM   #1
Nick Taliaferro
GenuineSaab's Avatar
So here is the carnage from tulsa..
http://genuinesaab.com/gallery/clutchboom The rest is there.. Pretty scary.. Thats a full depth crack in the pressure ring. Have to get the box pulled part to see what is going on inside. The case is cracked and the input shaft wore on the crank. Flywheel is bent!
Nicholas Taliaferro
GenuineSaab is offline
Old 09-22-2009, 10:46 AM   #2
kingofkrunk's Avatar
holy shit!!!! thats fucking crazy!
kingofkrunk is offline
Old 09-22-2009, 10:50 AM   #3
bobg450's Avatar
Done well
Wow- keep that up and they'll make you run a scattershield or blanket!
I've seen worse, but only on big block domestic iron!
Another argument for a beefed up automatic, high stall torque converter, and a tuned trans module.
Any reasons why that's not feasable?
"Wow, is it actually a reading comprehension problem you have, or just a small one with literacy?
" a TrollhattanBilism"
'00 VigVert- Nirvana
'00 9-3SE DD
2013 Silverado Z71 4WD
bobg450 is offline
Old 09-22-2009, 11:27 AM   #4
User
zingZACH's Avatar
Yeesh.
Reminds me of my friend's civic that had a clutch blow apart. Took out his fluidyne radiator, tranny, a chunk of his block and his hood .
1988 900 Springtime in Sweden
zingZACH is offline
Old 09-22-2009, 11:27 AM   #5
viggenkid's Avatar
i've seen this happen once before on steffan vappa's race sonett.
viggenkid is offline
Old 09-22-2009, 11:28 AM   #6
SAABOOST's Avatar
Wow a cracked PP and a pucked disc don't mix.
Does SPEC have any kind of customer support, like, say ARP?
SAABOOST is offline
Old 09-22-2009, 11:29 AM   #7
christian900se's Avatar
It's possible, I looked into it for my automatic stage 5 ng900 and it is way too expensive to justify the improvements. However, Nick probably has a much bigger budget than I do so that could always be a possibility if drag racing is the main priority.
christian900se is offline
Old 09-22-2009, 11:36 AM   #8
comtrang's Avatar
So what are you planning to replace it with? Another one or time to move up?
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 09-22-2009, 12:04 PM   #9
Nick Taliaferro
That wasn't a spec disk it was an old one from sweden. It was the best combo we had available. We will have some new custom clutches soon. They just weren't ready yet..
It didn't break under power it went BANG after the line in neutral at idle. He had clutch down from 1000ft. It did slip a bit in 3rd is why he aborted.
I am trading some machine work for a cage and a scatter shield was on the list for after this race.
Nicholas Taliaferro
Old 09-22-2009, 01:36 PM   #10
srp
srp's Avatar
Send a message via AIM to srp
Impressive! Were you running the spec flywheel? Looks like it in the pictures above.
srp is offline
Old 09-22-2009, 01:57 PM   #11
PaulH's Avatar
I bet that made a hell of a racket! Good to see nobody got hit with any of that shrapnel.
Paul
PaulH is offline
Old 09-22-2009, 02:11 PM   #12
Nick Taliaferro
It gets more interesting first gear was nearly welded to the shaft. It did pull the Output shaft bearing plate from the case up against first..
The oil pan had little round shavings in it but the thrust bearings look nice.
Confused and out of $$ for this mess.
Also they hit the wrong button on the video and steve started it as he was waiting for a tow off. Does make some nice noises.
Nicholas Taliaferro
Old 09-22-2009, 03:30 PM   #13
comtrang's Avatar
Didn't think it looked like my spec 6 puck. Hopefully you get the new ones in soon; I'm worried my two and a half year old one is gonna bite the dust as soon as I up the boost. I'm pretty easy on it and have under 15 passes at the drag strip.
In for updates on new clutches. Please.
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 09-28-2009, 07:05 PM   #14
JZW
Wow, that is really something. That one really came apart!
John
JZW is offline
Old 09-28-2009, 07:14 PM   #15
JK
JK's Avatar
Balls! You know you're doing something right when things break like that
always a SAAB guy at heart
JK is offline
Old 09-28-2009, 07:45 PM   #16
Wanna bet...
I can fouck things way worse, without doing sh!t right...
hihi
join me:
av_dumitrascu is offline
Old 09-29-2009, 02:55 AM   #17
stig's Avatar
Ho-ly shit.
'96 Miata - Simplify and add lightness
'96 9000 Aero - Complicate and add torque steer
stig is offline
