mechanical vs electric boost gauge - The Saab Link Forums
Old 09-21-2009, 06:45 PM   #1
saabskijc's Avatar
im in the process of ordering a new boost gauge for my car to match my wideband from prosport gauges its only like 15 more dollars for the one with the electric sender i have heard a dispute before of which one is better any input on this guys?
saabskijc is offline
Old 09-21-2009, 06:55 PM   #2
watkins's Avatar
Send a message via AIM to watkins
Boost is the one time where there is absolutely no advantage whatsoever for having an electrical gauge. Of the half dozen Ive installed, none has been electrical.
watkins is offline
Old 09-21-2009, 07:00 PM   #3
saabskijc's Avatar
also anyone have anything bad to say about prosport gauges??
Ps should i go with electric for oil pressure? i know some people worry about leaking in the cabin but im confident if i tighten it all together that shouldnt happen?
Old 09-21-2009, 07:19 PM   #4
watkins's Avatar
This I would do. I lost all 4 quarts of oil from my engine into the cabin of my convertible when a compression fitting decided to fail.
My plan is an oil filter sandwich plate and an electric gauge
watkins is offline
Old 09-21-2009, 07:45 PM   #5
saabskijc's Avatar
I bet it smelt like a gokart track for months good thing I love that smell jk ya I wouldn't want that pro sports electric gauges aren't much more then their mechanical so I'm probably gonna go ahead and get electric oil pressure mechanical boost and I have one more blank spot for a gauge soo what should I get is oil temp that important if I already have pressure any other gauges I should worry about got the wideband covered? Might end up throwing a volts gauge in there
Old 09-21-2009, 08:06 PM   #6
watkins's Avatar
Nope no smell. It all ended up between the subflooring and the body and drained right out the plugs
watkins is offline
Old 09-21-2009, 08:11 PM   #7
NahumCC's Avatar
Wish I could give you some feed back on the prosports overall.
My sender just arrived back with them to be checked to see if it was bad .
2013 FR-S
NahumCC is offline
Old 09-21-2009, 08:18 PM   #8
1995BlueBeast's Avatar
How many gauges are in your car? And what are u using to hold them? I have 4 gauges right now in my NG900: Boost, A/F, Oil Temp, and Volts. I have the Elkparts dual a pillar pod and I had to custom make a gauge holder next to the cigarette lighter for the other two, but im interested in what you did seeing as I want to put a few more gauges in my car and I'm running out of room.
BTW, I had a friend use prosport gauges and he seems to like them very much and they havent given him any trouble yet. I was thinking on switching over from Autometer, but i like them too much.
1995BlueBeast is offline
Old 09-21-2009, 08:18 PM   #9
Drew in Houston's Avatar
I would only do electrical. At a minimum a peak recall feature is really handy to have. Plus, they're generally self calibrating, meaning that whatever atmospheric pressure you're at when you go through the start up sequence will be the zero so you won't have any type of offset.
Drew in Houston is offline
Old 09-21-2009, 08:21 PM   #10
NahumCC's Avatar
So I'm not the only one .
Currently in the car: Prosport Volt and Boost, Autometer oil pressure
Waiting to go in the car: Prosport Oil pressure and temp, water temp, fuel pressure, EGT.
2013 FR-S
NahumCC is offline
Old 09-22-2009, 08:57 AM   #11
saabskijc's Avatar
i just got my elk parts dual pod in the mail also have the dual pod by sleet to go next to the cigarette lighter both look to be really good quality right nwo my boost gague is in my light switch but will be swapping that into the pillar and light switch back when i get the new gauge in pretty excitied i feel it will change the look of the cars interior quite abit
Old 09-22-2009, 08:58 AM   #12
saabskijc's Avatar
also if you order gauges from prosport you can use the coupon code fastspecv or crooked to get 10% off just a heads up
and also im going with a blue boost gauge to match my inovative wideband but for the oil press and volts down by the cigarette lighter should i go with green to match the interior or blue to match the rest of the gauges?
Old 09-22-2009, 09:45 AM   #13
NahumCC's Avatar
BTW, if you have a gauge in your headlight socket you won't be able to put the switch back in the socket and expect it to stay put. When you cut out that lip to put in a 52mm gauge you remove the part that holds the headlight switch. You'll need a new dash to replace it with.
If you have the base black dash in your I have a brand new one that I've been trying to sell. You can PM if you have an interest.
2013 FR-S
NahumCC is offline
Old 09-22-2009, 10:01 AM   #14
My lower gauges next to the cigarette lighter are green and they look great which led me to switch my other gauges to the same green color. I'm also looking into putting a three gauge pod on my dash for more gauges, i just dont know how they will look, but if you have any other ideas Id love to hear them.
Old 09-22-2009, 10:02 AM   #15
BTW NahumCC: I want to put the same type of gauges in my car too just all Auto Meter Pro Sports in a nice green which matches the dash lights nicely.
Old 09-22-2009, 11:58 AM   #16
watkins's Avatar
Not so if youre clever.
watkins is offline
Old 09-22-2009, 12:17 PM   #17
I still say I wouldn't buy prosports again, since I can't dim that dang things and I do a lot of night driving with deer.
The big advantage for me with electrical is that I just put the sender over by the throttle body and ran the wires to join up with oil presser wires. Vacuum hoses for a gauge are just more hoses for leaks.
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 09-22-2009, 01:53 PM   #18
watkins's Avatar
You can dim any gauge you want. Just buy a rheostat.
My Glowshift boost gauge is a searchlight right out of the box. An in-line dimmer brought it down to factory dash levels and it now dims quite well with the dash illumination dimmer.
watkins is offline
Old 09-22-2009, 02:26 PM   #19
saabskijc's Avatar
i guess ill just run a switch to the power so i can shut them off if need be and ya i know my headlight switch wont just fit in ive got a viggen dash lined up ill probably be sellling mine with the carbon fiber overlay
just made my order for mechanical boost gauge im guessing i should be able to dim that one because ill just dim the power supply? and it wont affect how the gauge works and i also ordered oil press electric and voltmeter
Old 09-22-2009, 03:30 PM   #20
User
zingZACH's Avatar
I've always gone with mechanical boost gauges. From my experience, mechanical gauges generally gives you faster, more accurate readings.
However, with oil pressure I would go for an electrical so you don't have to worry about leaking oil into your cabin.
1988 900 Springtime in Sweden
zingZACH is offline
