Intake Options - The Saab Link Forums
Old 01-12-2004, 08:07 AM   #1
Intake Options
For B204L (2.0L T5 Turbo) alternatives:
Stock Airbox Snorkel Mod
Use stock airbox (and upgrade panel filter to K&N) but replace intake snorkel with funnel or large tubing. Panel filter inferior to cone.
Abbott Performance Induction Kit
ITG cone filter and intake tube. Air sucked from inside engine compartment.
Blaque Out's Intake Kit
?? Cone filter and intake tube. Replaces stock snorkel. Smoother intake path, but sucks air from inside engine compartment.
BSR Optiflow
JR Cone filter with plastic 'fence' to block hot engine air. Poor sealing and reliance on 'cold' air to go through maze behind headlight is not a true CAI.
Speedparts Intake
Similar to BSR part except cheaper and plastic fence replaced with metal.
Cone on turbo
Probably the best solution to eliminate restrictions, but takes air from hot tarmac and around exhaust manifold.
slaab is offline
Old 01-13-2004, 03:08 PM   #2
trexturk's Avatar
Send a message via AIM to trexturk
Don't forget about my SaabNation Cold Air Intake. The filter goes into the bumper and behind the fog light and recieves air from outside of car.
trexturk is offline
Old 01-13-2004, 03:42 PM   #3
WS
WS's Avatar
Send a message via AIM to WS
i got a BSR optiflow on my car. its a t7 though so i have a mass airflow sensor
2000 Saab 9-3 Viggen Sedan
-Silver
-20% Tint
-BSR Cat-Back and Intake
WS is offline
Old 01-13-2004, 04:55 PM   #4
Where can I get one?
slaab is offline
Old 01-13-2004, 06:12 PM   #5
trexturk's Avatar
http://home.comcast.net/~saabnation/index.html
trexturk is offline
Old 01-13-2004, 06:26 PM   #6
BurnsSide42's Avatar
How about either a How to, or the link to a place to get a Set-Up for an 87 9000T
Check out
for your repair needs
BurnsSide42 is offline
Old 01-13-2004, 10:03 PM   #7
Administrator
bollman's Avatar
Send a message via ICQ to bollman Send a message via AIM to bollman
Speedparts mounting instructions (in Swedish though but with pictures):
http://www.speedparts.se/arkiv/anvis...nv_xf-9000.pdf
bollman is offline
Old 01-14-2004, 03:47 AM   #8
(YAY 400th Post! :P )
Anyway - it seems that that one page doc showed me as much as i already knew.... is it missing more info? Seems lacking if going by the pics. Thanks tho.
Check out
Old 01-14-2004, 05:16 AM   #9
HNNLIC
Blaque's Avatar
Thanks for making this thread, it should really help out alot of people thinking about intakes.
Blaque is offline
Old 01-14-2004, 02:46 PM   #10
Administrator
bollman's Avatar
Rememeber though, that the air coming from the turbo reaches temperatures between 2-300 degrees F! So, by moving your intake to gain perhaps 10 degrees cooler air is quite indifferent to the gain from a more efficient intercooler!
If one is to make a great difference in intake temperature, water/alcohol injection is a much greater gain, although harder to implement.
This also reduces the risk of knock.
This is to be put in relation to the risk of getting unpleasant things into your engine. Putting a free-flow filter so far down as the fog-light is really dangerous and going through some water while boosting could fill your engine with water and thereby completley destroying it!
bollman is offline
Old 01-17-2004, 07:44 AM   #11
Can't see this one working to well.......
Big lump of sh1t on the end of it
murphwiz is offline
Old 01-17-2004, 08:30 AM   #12
HNNLIC
Blaque's Avatar
Blaque is offline
Old 01-22-2004, 09:54 AM   #13
Administrator
Boxerchip's Avatar
on the saab nation intake it says only for T-5.... but there is no reason it could not go on my t-7 car is there?
Boxerchip is offline
Old 01-22-2004, 11:12 AM   #14
trexturk's Avatar
Well your car has the MAF
Now: 04 Nogaro S4
Past: 99 Stage 4 9-3
trexturk is offline
Old 01-22-2004, 12:45 PM   #15
Administrator
Boxerchip's Avatar
yeah.... couldent i still put that on there?
Old 02-17-2004, 08:24 AM   #16
HNNLIC
Blaque's Avatar
You may have to cut some piping to make room for the MAF, but as soon as this guy makes it down to Iowa, I'll be making him one...so i can tell you exactly what you need.
Also. For those of you who are scared about sucking water in your intake, a way to get rid of that threat is to attach what's called a "Air Bypass Valve". No its not the BOV or BPV that you are normally used to...this one goes on your intake. Check it out: It basically allows for any water that may make its way up your intake to be absorbed or leak out by this bypass valve.
Blaque is offline
Old 02-17-2004, 09:07 AM   #17
im going to run a cai. simply make your own or buy froma company that sells them...im going to run the intake in conjuncion with the the air bypass valve from aem..eliminates the chance of water comming into intake..you will have nice cold air and no worries. just my $.02
http://www.aempower.com/product_intake.asp
NineThreeTurbo is offline
Old 02-17-2004, 09:08 AM   #18
sorry blaque/// i mised your above post....
Old 02-17-2004, 01:36 PM   #19
The bypass valve is not recommended for turbo engines. When on boost, a vacuum is created in the intake.
The bypass valve works by detecting a vacuum in the intake tract, either due to blockage or water and opens to allow unfiltered air in. The intake vacuum present in boosted cars will cause it to open when on boost, bypassing the filter and letting all the icky guck in your engine compartment into your engine.
From AEM's website: http://www.aempower.com/faq.asp?fid=21&tid=3
AEM does not recommend the use of the bypass valve on engines equipped with forced induction (turbo or superchargers). Additionally, using nitrous oxide in a placement before the bypass valve is dangerous due to fuel contamination of the foam spring/filter as well as degradation of the integrity of the plastic due to the extremely cold temperature of the nitrous oxide. Nitrous can be used downstream of the bypass valve.
slaab is offline
Old 02-17-2004, 02:34 PM   #20
HNNLIC
Blaque's Avatar
Well okay....scratch that idea lol.
Blaque is offline
