5 speed swap in '99 9-3 - The Saab Link Forums
Old 09-06-2009, 07:00 AM   #1
Two weeks into driving my B234R Stage III setup I really want to be able to row through the gears. I don't mind swapping parts and some fabrication, what do I have to get together for parts? Will an NG900 transmission work? What clutch would be recommended for my power level, and should I get an LSD while I'm at it?
ilovemybike is offline
Old 09-06-2009, 08:48 AM   #2
mike9000aero's Avatar
i think its a bolt in job...not sure, all you would need is all clutch and 5 speed related pieces to a 5 speed car
mike9000aero is offline
Old 09-06-2009, 09:49 AM   #3
JK
JK's Avatar
yeah, there shouldn't be any "fabrication" necessary.
always a SAAB guy at heart
JK is offline
Old 09-06-2009, 01:23 PM   #4
WyldSaabMan's Avatar
The hardest part may be making holes in the firewall for the clutch Hydraulics.
I am not sure if the automatic has those holes there or not.
Nick T. has a template on his website somewhere for which holes have to be made for the hydraulic clutch conversion. Using that template it shouldn't be very hard.
Although I hear it is much easier to make those holes without the engine in the car, but it is doable.
other than that, everything else should bolt up fairly easily.
A ng900 trans will work, but if it came with a cable clutch you will have to do away with the cable bits. Plus a 9-3 trans has a few upgrades to it, and it should have the upgraded shift linkage as well.
Make sure you buy a new slave cylinder, this is not a part you want to skimp on. A new one is cheap enough and will save you from dropping the trans when a used one fails prematurely.
A Spec stage2 disc and a Viggen Pressure plate should be good combo for what you have.
99 Saab 9-3se Imola Red
90 Saab 900 SPG Talladega red
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
WyldSaabMan is offline
Old 09-06-2009, 01:48 PM   #5
Smaart Aas Saabr's Avatar
The holes surely are there but plugged, like on my C900
For NG 900 type sure you need to punch a hole for hydraulics since they expected a cable there instead
what about ECU, does it control the tranny also?
Smaart Aas Saabr is offline
Old 09-06-2009, 01:55 PM   #6
Yea I kind of figured, I was just a bit unsure.
I knew the c900's have the holes....that's an easy one to swap!
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
Old 09-06-2009, 01:59 PM   #7
9000's have the holes also...really easy swap...plus its nice to be able to pull the engine through the top with no issues...
Old 09-06-2009, 03:39 PM   #8
Thanks guys. I don't mind dropping the subframe out again, I'm getting good at it actually. No fabrication though? I want more welding burns....
Old 09-06-2009, 03:44 PM   #9
christian900se's Avatar
Every automatic ng900 has all the provisions for a manual tranny. If you search on here, someone just successfully documented the swap and needed minimal parts past the transmission and related components.
Definately don't skimp. One thing I have learned is to do it right the first time, always works out better.
christian900se is offline
Old 09-06-2009, 03:49 PM   #10
viggenkid's Avatar
x2
get a 9-3 transmission and have an LSD put in while it is out. and yeah the viggen clutch should be a good choice for your power levels.
viggenkid is offline
Old 09-06-2009, 07:36 PM   #11
dave del's Avatar
i'm most likely going through with the swap too. only thing that has me worried is the whole nss thing and getting the car to start properly.
01' 9-3 jzw stage 4 track car
slammed 87' c900
24v 87' e30
dave del is offline
Old 09-09-2009, 01:57 PM   #12
Death disaster and a new reason to drop the cradle.
So I took my car to Virginia for the long weekend, beat an Rx8, WRX, Mazda speed 3, Jetta IV Vr6 and a few other cars on the highway, but blew it up on the way back. Yes indeed, nine hours from home with a oil spewing flaming hole in the side of the block. Luckily I had some primo fiji water to douse the OPEC flames. Negotiations are being made with the junkyard and hopefully I will be back boosting and blowing up stuff soon. I suppose I shouldn't be beating on this car but why make power if you don't use it?
Old 09-09-2009, 04:45 PM   #13
wow that sucks.
Good luck with repairs.
A hole you say? Do you have pictures?
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 09-09-2009, 04:54 PM   #14
User
zingZACH's Avatar
How did you manage that one?!
1988 900 Springtime in Sweden
zingZACH is offline
Old 09-12-2009, 07:45 AM   #15
99 9-3 B234R Stage III T5 Suite
http://photos-a.ak.fbcdn.net/hphotos-ak-snc1/hs268.snc1/9518_513581038811_149000144_30600048_4494434_n.jpg
Dreaming of RWD SAAB
Old 09-12-2009, 06:17 PM   #16
So I test drove a cobalt SS for a state inspection and couldn't help but notice that it had an LSD in its 5 speed. Has anyone swapped those into an OG9-3? I like the idea of an LSD and not having to tear into the case and shell out the big bucks too.
Old 09-12-2009, 06:20 PM   #17
User
zingZACH's Avatar
tre suck.
zingZACH is offline
