Genuine Saab control arm questions - The Saab Link Forums
Old 09-03-2009, 12:44 PM   #1
9-3sleeper's Avatar
Exclamation Genuine Saab control arm questions
Hey all,
I recently had an incident where I hit a large pothole that sent me up into a curb. Needless to say I shredded my tire and bent my lower control arm. I took it to an alignment shop today and they also found that the ball joint on that side is about ready to fall out and the one on the other side isn't very tight either.
I'm planning on buying the GS upgraded bushings and control arm kit to fix this but I don't know how difficult of an install it is and if it requires special tools. I'd like to try to install myself but I don't want to get into something and find out that I don't have the tools to finish it.
Does anybody know what I'd need?
Thanks in advance,
Ben
9-3sleeper is offline
Old 09-03-2009, 12:49 PM   #2
http://photo.platonoff.com/Auto/2007...0_Control_Arm/
rafal is offline
Old 09-03-2009, 01:17 PM   #3
9-3sleeper's Avatar
thank you man, that's a huge help. When you remove everything does the wheel assembly need to be supported or does the strut still hold it up?
Old 09-03-2009, 01:18 PM   #4
adidas_007's Avatar
You may need a torx bit to remove the bolt that holds the control arm & stanchion arms together not pictured above, I can't remember what size.
This is the bolt that I am refering to which has been replaced in the diagram above.
http://www.eeuroparts.com/Main/PartD...spx?id=4645156
2010 9-5 Aero
2004 9-5 Aero 5pd Stg 3 Wagon, 1 of 18 Made
1990 900 Convertible
2007 Cbr600
adidas_007 is offline
Old 09-03-2009, 01:19 PM   #5
adidas_007's Avatar
It will hold
2010 9-5 Aero
2007 Cbr600
Old 09-03-2009, 01:27 PM   #6
Also, ask Nick T at Genuine when you buy the bushings and Arms, if he can press out the stockers and apply the poly ones. Pressing out the stock ones is the hardest part.
You don't even need a ball joint separator, since the old ones are trash you can use a pickle for and just demolish them.
Once you have the things tightend up down there, when you steer to avoid those potholes, the car will actually go where you point it!
Old 09-03-2009, 01:46 PM   #7
Bullseye's Avatar
Yes. Pressing out the stock ones is no fun without a press.
"If guns cause crime, all of mine are defective." T. Nugent
Bullseye is offline
Old 09-03-2009, 02:30 PM   #8
Sleepy7666's Avatar
Harbor Freight Special... to the rescue... Gear puller /thread
T55 is the torx size... also Harbor Freight Special
and Pickle Fork is not needed... Soft rubber mallet.
I lurk.
99 and 01 Saab 9-3
96 Escort LX
83 Yamaha XJ650 Maxim
Sleepy7666 is offline
Old 09-03-2009, 03:12 PM   #9
adidas_007's Avatar
Originally Posted by sleepy7666 View Post
Soft rubber mallet.
na... Dead blow hammer, no recoil
2010 9-5 Aero
2007 Cbr600
Old 09-03-2009, 08:06 PM   #10
NahumCC's Avatar
If you hit something hard enough to do that kind of damage I would pull the cover off the top of the strut mounts and inspect them too. If the strut mounts have given out it is possible that the strut assembly may just fall out. This is something I'm facing when I go to change out my strut mount here soon. Mine is trash and all over the place.
2013 FR-S
NahumCC is offline
Old 09-12-2009, 02:32 PM   #11
So I just glanced at my control arm and noticed it doesn't have a screw in the outer bushing... probably a bad thing?!
SaabMania9000 is offline
Old 09-14-2009, 04:34 AM   #12
bobg450's Avatar
Huh?
I'd say so. Don't drive it even if the upper half of te bolt is still in there. That control arm pulls the body when the drivetrain tries to leave the body behind!!
"Wow, is it actually a reading comprehension problem you have, or just a small one with literacy?
" a TrollhattanBilism"
'00 VigVert- Nirvana
'00 9-3SE DD
2013 Silverado Z71 4WD
bobg450 is offline
Old 02-27-2010, 07:42 AM   #13
Does anyone have any tips as to how to make the "upgraded bolts" that i got from genuinesaab.com to fit through the lower opening of the Stanchion Arm?
pahkaju is offline
Old 03-08-2010, 01:00 PM   #14
You need to press out or bang out that lower star nut (it is serrated like a star so it doesn't move. Use lots of PB Blaster. It will either be hard or easy, no in between. Good luck.
Slaaby Seconds is offline
Old 03-08-2010, 01:08 PM   #15
Nick Taliaferro
GenuineSaab's Avatar
http://www.genuinesaab.com/psi/files...gradeBolts.pdf
On the product page http://www.genuinesaab.com/catalog/p...products_id=33
Nicholas Taliaferro
GenuineSaab is offline
Old 03-08-2010, 06:37 PM   #16
lowbudgethero's Avatar
it wasn't easy, there was some downtime with the car... however it wasn't the worst thing in the world the second side is always a lot easier than the first one
lowbudgethero is offline
