Viggen 99 vs 00-02 - The Saab Link Forums
Old 08-23-2009, 02:49 PM   #1
Viggen 99 vs 00-02
Hey i was just curious to see if there was any difference in the any of the viggens? Was the 1999 a bit stronger cuz it had some of the t5 internals or is that not true. Any insight ont eh 1999- vs say a 2002 model would be great thanks!
rkm93 is offline
Old 08-23-2009, 03:01 PM   #2
Nick Taliaferro
GenuineSaab's Avatar
2000- had quite a few updates
Cobrapipe, injectors/inletmanifold
Rods and pistons are different.
2001- came with tcs.
Just for a start.
Nicholas Taliaferro
GenuineSaab is offline
Old 08-23-2009, 03:03 PM   #3
No, the 99' had no T5 parts.
I personally do not like TCS, just another thing to break and never had a use for it.
99's are said to be down 5hp over the later years but with dyno's that 5hp varies from car to car and means nothing.
Jameson is offline
Old 08-23-2009, 03:41 PM   #4
Paul Campagna's Avatar
OK i like this thread. I got a 2001 and test drove some 99's. Might be poorly tuned or just more humidity when i drove the 99's, but the 99's just didn't get up and go like the 2001.
Traction control can be shut off very easily when you want to spin the tires (above 45 i think it automatically cme on wether it's switched off or not) but it already controlled some high speed hydroplaning with shot tires.
i'm curious if i have to drive it in the snow what it'd be like, but i don't want to...
I' d like to know more stuff on the different years too, so this is getting subscribed to.
Paul Campagna is offline
Old 08-23-2009, 03:44 PM   #5
You can't compare it now. Every Viggen is different, especially now when after 8-10 years, one can have a small boost leak or have a check valve that is faulty.
rafal is offline
Old 08-23-2009, 04:04 PM   #6
viggenkid's Avatar
LB adds 500whp
viggenkid is offline
Old 08-23-2009, 04:05 PM   #7
Umm....
This.
I have seen Viggens all over the place in terms of health and performance and the year did not matter at all. If anything, the 99's are likely to be the oldest/highest mileage and needing some work. But I have seen dyno's of every kind of Viggen and there is no direct link between certain years making more power than others.
Jameson is offline
Old 08-23-2009, 04:57 PM   #8
Both Viggens i drove were lower mileage & supposedly stock. I know there are lots of things to consider for cause one running better than the other. I bought the one that ran best for sure. the less i have to diagnose a car the better when buying.
Surprisingly i got the 2001 cheaper than the others were asking, probably cause of the lower miles. They were not in as good as shape though and no PVC updates....
When did onstar get put in? - You can;t use it cause it's analog, but that is a difference...
Old 08-23-2009, 05:05 PM   #9
Legit's Avatar
intake pipe, downpipe, injectors, pistons, ecu I think
2002 Viggen Convertible
Legit is offline
Old 08-23-2009, 06:33 PM   #10
Champ's Avatar
2000 wuz the best year.
Champ is offline
Old 08-23-2009, 06:42 PM   #11
gm
gm's Avatar
I didn't was tcs so 01+ was out plus they were out of my pricerange at the time
I also wanted a 5dr so 2K was what I ended up with
some state pistons are weaker in the 99's & I think 01+ is the best....
I think it was a 02 vert that had the most power in stock form that I have seen, if I recall it was around 235 whp & 290+wtq vs my 2K was 213 whp & 268 wtq
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 08-23-2009, 06:57 PM   #12
Bullseye's Avatar
Those 2000's do look awful pretty in the rear view mirror.
"If guns cause crime, all of mine are defective." T. Nugent
Bullseye is offline
Old 08-23-2009, 07:35 PM   #13
Low miles does not make you immune to vacuum leaks. Ask me how I know :P
I have learned more and more with this car that LOW mileage just means YOU get to be the asshole who replaces everything
Jameson is offline
Old 08-24-2009, 05:27 AM   #14
The '99 have the weaker pistons, but if you're going for major power (350+ hp) you would need to upgrade to forged pistons anyways. I agree with Jameson, I've seen these all over the board when it comes to power with no connection to year. My '02 has OnStar - not sure if that's the only thing new/different for '02.
2002BlackViggen is offline
Old 08-24-2009, 05:37 AM   #15
christian900se's Avatar
YES!!! My car has had more problems with 33,000 miles than my mechanics 240k mile 9000CSE. It sucks for sure, all sorts of money spent on stuff that should be lasting tens of thousands more miles.
christian900se is offline
Old 08-24-2009, 05:37 AM   #16
Elmo's Avatar
Send a message via AIM to Elmo
i'm not sure about that. when my '01 viggen hits 45 mph half way through second gear it breaks loose with TCS off i would think if TCS automatically came on it wouldn't let that happen
Elmo is offline
Old 08-24-2009, 05:40 AM   #17
Pistons are weak in all Viggens. Some maybe weaker than others, but pistons are needed at the 300whp mark, though there have been cars that ran more and were fine. There have also been plenty grenaded at stock power levels. Nick explained to me one time my car was safer on Nordic than it was stock, more built in protection.
Jameson is offline
Old 08-26-2009, 07:46 PM   #18
One selling point for me on the 01 and 02 WAS the TCS and that allowed me to run a flex fuel E85 prog that Nick brewed up for me....E85 is 'cheat gas' and I'm hooked. Thanks Nick!
my 2 cents,
Greg
HawaiianSAAB is offline
Old 08-27-2009, 05:33 PM   #19
I actually think more miles the better sometimes, just for that reason. Especially with saabs...
I thought i read that in the owners manual? Maybe it was an article on it when it first came out. I'll look in the owners manual tomorrow....
