Deleting Balancer Shafts - The Saab Link Forums
Old 08-18-2009, 10:24 AM   #1
skinny's Avatar
I've seen this mentioned a couple of times on here and on the GS website regarding their drag car. What are the advantages of deleting the shafts? How do you delete them etc etc
Need MOAR imput!
skinny is offline
Old 08-18-2009, 10:28 AM   #2
Castor Troy's Avatar
you delete them because the drag they cause steals horsepower.
the disadvantage of this is heavy vibration. the 2.3 is more affected by this than 2.0.
you delete them by removing the chain, and replacing the tensioner with the piece that nick sells
Castor Troy is offline
Old 08-18-2009, 10:29 AM   #3
Some searching around will yield results.
I deleted mine a few months back while I had the engine out. You "can" delete them with the engine in but it is a PITA, small space and trying to cut a chain does not go well.
As far as impressions, the motor feels/sounds more raw. The increased vibration is only noticeable above 4k rpms. Did it help the motor out in HP or spin up? Maybe, its hard for me to tell as I also lightened the flywheel at the same time.
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 08-18-2009, 10:31 AM   #4
skinny's Avatar
Is there a noticable difference to be had in deleting them? Would it affect a road going car that much to shake you senseless?
Only asking as I'm Stage 3 tuned and heading to Stage 4 but, like all, I want more!
skinny is offline
Old 08-18-2009, 10:33 AM   #5
skinny's Avatar
*edit* I see PB already answered some of my questions, thanks!
skinny is offline
Old 08-18-2009, 10:34 AM   #6
9-3sleeper's Avatar
are there any long term detriments to doing this? all the extra vibration must hurt something?
9-3sleeper is offline
Old 08-18-2009, 10:35 AM   #7
Just use more lock tight!
Really, at idle and even 2 or 3k while looking at my engine I dont know if you could tell that they were not spinning.
2012 VW Golf TDI
Old 08-18-2009, 12:34 PM   #8
spanky's Avatar
Send a message via AIM to spanky
i deleted mine back when i was building my 2.3. It does vibrate some, you can feel the power. Couldn't tell you if it made a power difference.
97-900se blk/blk 5speed, 2.3 aero motor, td04 18t......SOLD
92 dodge w250 cummins.....SOLD
97 900SE blk/blk, 5speed, TD04, upgraded fmic-----Back in the game
03 f250 CCSB Lariat 6.0
spanky is offline
Old 08-18-2009, 02:25 PM   #9
mcrowley's Avatar
My car doesn't have the chain in it anymore either (also a 2.3 swapped 900). I didn't use the plate gs sells. Instead we tapped the passage in the block and used a grade 9 bolt to plug the hole. I've got about 6000 miles on it so far, no problems.
There is plenty of vibration, esp with gs motor and trans mounts.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 08-18-2009, 04:19 PM   #10
turbojohnny's Avatar
I haven't read the whole thread but did you guys make it clear to the O.P. that you only delete the chain, and you leave the shafts in place?
turbojohnny is offline
Old 08-18-2009, 04:50 PM   #11
Adrenaline406's Avatar
if you want to do it in the car, you're supposed to drop the pan, and cut the chain. This leaves the shafts and everything intact.
If you pull the engine, then you have the option of fully removing the shafts and all the other junk that gets left behind with the delete.
The reason for the block off plate or tapping the oil opening is to replace the balance chain tensioner (bct). The bct has an oil port in the back of it that feeds it oil and the balance chain too. If the chain is removed and the bct breaks, you will loose all oil pressure (major issue of course). So the best solution is to remove the engine, take of the shafts and replace the bct with an oil blocker.
Many ppl on here have pulled the chain and had great results, as in the bct never went bad, JZW for example. Maybe they can chime in.
hope that helps...
Adrenaline406 is offline
Old 08-18-2009, 04:57 PM   #12
If you pull the shafts out themselves, you MUST block the passages that are in by the shafts too.
I left the shafts in to avoid that problem.
2012 VW Golf TDI
Old 08-18-2009, 05:10 PM   #13
this!
just to emphasize what poisonbeef is saying.
if you pull out your balance shafts and put all the motor back together and put it back in the car, you might as well punch yourself in the face and go buy another motor. the balance shafts must stay in place to maintain your oil pressure. or if you pull them out you must have something in place of the shafts to maintain your oil pressure.
If people could just search, you would find that this subject has been talked about plenty of times.
anyway, good luck with your project!
Old 08-19-2009, 04:27 AM   #14
mcrowley's Avatar
Mine was done with the motor in the car, w/o pulling the pan. Head and timing cover were off instead.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 08-19-2009, 06:46 AM   #15
taking the timing cover off in car has to be a beyatch.
2012 VW Golf TDI
Old 08-19-2009, 06:48 AM   #16
mvadenais's Avatar
People have found that doing this to a 9-3 or 9-5 yeilds too much vibration. My 9k w/ all poly isn't bad w/ vibration.
88 900 SPG Black
95 9000 Aero Green
00 9-3 Viggen Silver
mvadenais is offline
Old 08-19-2009, 07:46 AM   #17
mcrowley's Avatar
I think a lot of it has to do with the differences in the motor mounts. I've had people comment on numerous occasions that the floor of the car felt like it was going to shake apart.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 08-19-2009, 10:06 AM   #18
cabin vibrations
I have deleted the balance shafts (one out and hole obturated, one still on the car, by cancelled).
I also have Sport Engine Mount (Stage2) from Nick T. (who admits it "Slightly increases vibration in the cabin at idle (more like automatic at idle but not as bad) but keeps it at a reasonable level most people cannot tell. Reduces drivetrain slop giving a much better feel"
and
Sport Transmission Mount also from Nick.
The vibration in the cabin is quite noticeable, but everything comes with a price in this life!
As someone said as a review of this great products, "There is a slight increase in vibration at idle but I don't mod my car to make it feel nice at idle."
On the other hand, the vibrations with the engine mounts upgraded disappears completely as soon as the engine RPM climbs up away from idle thanks to those lovely Saab counter-rotating ballance shafts. So if you delete them, you will get more vibration. But more freely power output and better feeling of the engine!!!
I think Adam, Ryan, Nahum, Aaron, Cedric and other guys on TSL can give some good inputs.
join me:
av_dumitrascu is offline
