TDO4 needing new Seals=Upgrade or just Replace Seals? - The Saab Link Forums
Old 08-17-2009, 08:07 PM   #1
Question TDO4 needing new Seals=Upgrade or just Replace Seals?
Turbo is the stock Viggen/9-3 HOT 5cm based turbo with no shaft play and clean looking turbine. It does need the seals dealt with.
Since the turbo is a-ok, seals aside, what would you do?
A) Have the seals replaced and have a larger housing made for the turbo?
B) Port/Polish it?
C) Larger Housing and Wheel?
I'm considering the upgrade path at some point in time, though with this particular turbo, wouldn't it make most sense to just have the seals dealt with, turbo cleaned, and leave it stock or would one of the above options be better knowing the seals need replacing.
Thanks for the input on this one!
Progression is offline
Old 08-17-2009, 08:15 PM   #2
Legit's Avatar
how much $ do you have to put into it?
2002 Viggen Convertible
Legit is offline
Old 08-17-2009, 08:21 PM   #3
HIDSPG's Avatar
Depends on what you have planned for the car? If you are adding hardware to go a staged route or plan on having it tuned to your hardware I probably at this point send it to have a 19T wheel installed. if you plan on doing a different turbo completely i would just do seals now
88 SPG, 08 TX Combi
HIDSPG is offline
Old 08-17-2009, 08:26 PM   #4
This is an ultimate question. I do not plan to go any higher than 300WHP. Even 300WHP would be quite a feat to pull off "unless" I find my way into a very cheap Saab where I can use the money to do all the upgrades vs. the cost of the car (i.e. $1-$1.5K for the car, $2-$3K for upgrades).
Thanks
Old 08-17-2009, 08:34 PM   #5
See my other response. I do plan to make more power either getting another Saab or possibly with the one I have now. But I'm thinking it may be a waste to do any mods to a turbo that is perfectly fine less needing new seals, and just find a super cheap core to send in to have it rebuilt w/larger housing and 19T or even a 16G. I'd like to have a 16G which never gets mentioned around here...heck, an 18G surely wouldn't hurt.
Old 08-17-2009, 08:52 PM   #6
Legit's Avatar
turbo upgrade should be the last thing you do. get a 3"dp or ets IC instead
Legit is offline
Old 08-17-2009, 10:50 PM   #7
Deez Nutz
Palmer's Avatar
S55/LC100/KL
Palmer is offline
Old 08-18-2009, 04:41 PM   #8
How about both?
I know the stocker TDO4 5cm can supposedly handle 300hp while the 6cm based one can handle 310hp...not a huge difference, but a difference...But this is talking about max hp from what I understand.
I suppose the question is how much HP/TQ can a TDO4-5cm based turbo with 3" DP, better Exhaust parts where flow is restricted, and a big FMIC would be able to pull off while still being reliable=not killing the engine.
Cheers!
Old 08-18-2009, 05:33 PM   #9
The stock TD04 6cm wont get you to 300hp. There are people using either an 18T or 19T that are making just over 300. The stock Mitsu turbo is only really good for 270 on a 2.0 (thats pushing it hard). See my second place stage 3 and under dyno chart from JZW's SOC post. 2000 9-3 TD04 5cm, T5 cams, exhaust, ETS IC, 3.5 bar FPR.... 233 and 285 or something like that. And Erics car on a 2.3 made around 265-275 if I remember.
Joel
2000 9-3 h.o.t.
J93O is offline
Old 08-18-2009, 05:38 PM   #10
mike9000aero's Avatar
ive got the 6cm on my 9000 with 3inch and intercooler, and i pulled 265whp and 300wtq...i think he is talking 300bhp though i think im at about 305 to the crank
mike9000aero is offline
Old 08-18-2009, 06:05 PM   #11
Yea, a 2.3 motor and 6cm will be closer to 300. Your car makes some great numbers I saw that post in the Proof section, 200 something thousand miles nonetheless! I don't even know what car he has...for some reason my mind wasn't registering bhp.
2000 9-3 h.o.t.
J93O is offline
Old 08-22-2009, 07:58 PM   #12
Thanks for the posts guys. Sounds like it's not worth having the TDO4 if one is going for some better HP especially seeing that one person's numbers with all those add-ons and only making 233WHP. I think my car now is probably "very close" to 200WHP and sure, 33WHP more would be nice, but that's not enough to make me want to buy a load of performance parts for.
Now that Aero making what it is making is a different story. Sounds like the T7 cars "really" need the 6cm housing at a minimum and then a T18 or T19 depending on preference of final HP/TQ goals.
Old 08-23-2009, 04:49 PM   #13
Its not that T7 cars specifically need the 6cm2 housing, but TD04s have small housings to begin with. If you are flowing any more air than a 15T wheel can, or even at the limits of the 15T wheel, it would greatly benefit your turbo if you put on the larger housing, 5cm2=tiny, someone said that equates to an a/r of like .39?
I specifically asked for a less aggressive tune from my tuner, but my car still makes about 250/260wheel torque until 4500rpms... its a huge improvement.
That being said, a 19T wheel with 6cm2 turbo (with injectors and full supporting HW), you can put down over 300 wheel hp and over 350 wheel torque, but not necessarily on a T7. Our pistons aren't the best.
2000 9-3 h.o.t.
J93O is offline
Old 08-23-2009, 04:59 PM   #14
Ahhhh...gotcha. Sounds like it's time to find my T5 suite ride for modifications. I'll just try to maintain the car I have on T7 since it is my wife's primary car, but I love driving it and am the driver when we go on trips and can push it to 140mph (fastest I was able to go since there's not enough open space on the two lane highways here). Wish I could take the car down to Nevada and ride out in the open there
