Any tweak for T5Suite Stage 3 .bin after T25 to TD04 upgrade? - The Saab Link Forums
Old 08-13-2009, 09:02 AM   #1
DanF.'s Avatar
1999 9-3 SE w/T5 Suite stage 3 (automatic trans.), open filter, 3" full exhaust.
My friend recently upgraded his 9-3 to the above specs. and today has fitted a Td04 to replace the stock T25 that died ( 1/4" shaft play... eek). My question is whether the current tune will adapt to the larger turbo, or will we have to flash a different .bin file to his ECU.
Thanks.
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1987 900 SPG parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 08-13-2009, 09:07 AM   #2
8valvegrowl's Avatar
While it's most likely fine to run on the T5Suite stage 3 .bin, he should definitely tweak it if he wants to maximize performance. There are some Stage 3+ / Stage 4 bins floating around on ECU project to provide a starting point. I may be doing this exact same thing to my car this winter...I have the TD04 sitting on my workbench.
8valvegrowl is offline
Old 08-13-2009, 09:17 AM   #3
DanF.'s Avatar
Ok... cool. Thanks.
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 08-13-2009, 12:00 PM   #4
comtrang's Avatar
The main thing is the TD04 will be moving a bit more air and spool won't be exactly the same and so if you're wanting to really tweak the old tune you would just have to support those two changes. I'm sure there's more to it than that, just something to think about.
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 08-13-2009, 12:20 PM   #5
^eggsackery.
Boost request limits can be raised, but at the same time, the air values and rpm ranges will be a little different. There are some TD04 bins out there for B204 engines...just get a bin and compare to the Stage 3 T25 bin to get a feel for the difference in air flow.
But it should be OK to drive it around in the meantime, I just wouldn't push it super hard.
Old 08-13-2009, 12:45 PM   #6
dan-the-kid's Avatar
Ok so. My brother and I did the same TD04 Swap on his NG. Same engine etc....
Lurking on ECU project is a B204R file. There were a few T5 1999 93s that were HOT and came with TD04(dunno about here, probably in europe).
Any ways, just find that file, stage it up. The biggest difference is the VE maps(volumetric efficiency) between the T25 and the TD04.
dan-the-kid is offline
Old 08-13-2009, 12:54 PM   #7
^really?
At least in the US B204R was just a T25 car witha crossflow IC and a slightly modified map, or so I thought. I posted a US B204R bin on ECUproject, and it was car with those specs.
But if there is a Euro B204R T5 with TD04, that will be easy, as D-t-K said, just stage it up.
**Update**
According to this thread, even the Euro B204R is a T25.
http://forum.ecuproject.com/viewtopic.php?f=48&t=200
Old 08-13-2009, 01:03 PM   #8
Unfortunately no B204 ever came with a TD04
9000 Aero STG 6 + , 900 SET STG 3
lastaero is offline
Old 08-13-2009, 01:07 PM   #9
Huh, I wonder why I thought that....
But either way,*I think* the VE maps are better on the B204R file.
Old 08-13-2009, 08:09 PM   #10
DanF.'s Avatar
My friend got his car all back together, although he had to fab up the water lines for the turbo. It fired right up and idled great for 15 minutes, but when we went for a drive something bad happened, and we think that the engine is starting to seize. Will know more tomorrow when we drop the oil pan.
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 08-13-2009, 08:25 PM   #11
Did you check to make sure there was a good seal for the oil return pipe?
Thats always a bit of a problem on the TD04 swaps if you dont get the right parts.
Old 08-13-2009, 08:43 PM   #12
DanF.'s Avatar
yeah, we checked everything twice. No leaks at all, and everything seemed fine. (My buddy had also taken the head off to replace the headgasket, and I had helped him replace the valve seals while the head was off...PITA)
Something had seized up the motor, now you can't turn it over by putting a long wrench on the cam and turning. The top of the motor was getting oil though, as there was plenty there when we took the valve cover off.
It ran kind of crumby, so we figured the cam timing might be a bit off. But on the way back to his shop it made a popping sound under boost and the engine died. No intake hoses popped off, and I wonder if maybe he spun a bearing or something.
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 08-14-2009, 03:04 AM   #13
Shit. Sounds like the timing may have been off. Bummer man, let us know what you find!
Old 08-14-2009, 05:05 AM   #14
DanF.'s Avatar
Just got this message from my buddy. Bad crank I guess.
Is it possible to put a B234R into a '99 9-3? That's what he's mulling now.
Can a B234 block be mated to the B204 transmission? I suppose anything is possible, but is there an easy straight swap?
Needless to say he's not happy.
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 08-14-2009, 05:12 AM   #15
NahumCC's Avatar
B204 block is a B234 block. The only difference is in the crank, rods, pistons, and oil pan (9k tilts it forward).
So yes you could put in a b234 motor in no problem.
2013 FR-S
NahumCC is offline
Old 08-14-2009, 05:35 AM   #16
DanF.'s Avatar
Cool, I just stumbled on the sticky for the swap ( that thing about not seeing the forest through the trees... or something like that)
Plans are being made...
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 08-14-2009, 06:15 AM   #17
Ooof, bummer! Just make it stronger, faster, better now!
