2.3 N/A with a turbo - The Saab Link Forums
Old 07-29-2009, 07:34 PM   #1
Greek Mod
grkguy89's Avatar
so some of you may remember me saying i was going all the way (giggidy) and by that i mean boosting my '95 900s 2.3 N/A
well i did it
and here's how it went
DAY 1:
taking things apart:
head lights off:
took off bumper plus cooling off the headers faster with the aid of a fan:
Current Activity: Moderating
grkguy89 is offline
Old 07-29-2009, 07:35 PM   #2
Greek Mod
grkguy89's Avatar
mount up oil cooler:
then the intercooler:
then taking off O2 senser and 6-point brace:
disconnecting exhaust to then unbolt headers:
removing headers:
grkguy89 is offline
Old 07-29-2009, 07:35 PM   #3
Greek Mod
grkguy89's Avatar
END OF DAY 1:
START OF DAY 2:
replacing injectors:
replace oil filter housing and connect oil cooler:
punch hole in "freeze plug" to remove for oil return line:
install small tube for oil return:
install turbo manifold:
and install turbo (td04):
grkguy89 is offline
Old 07-29-2009, 07:36 PM   #4
Greek Mod
grkguy89's Avatar
closing of lines to connect oil and coolent lines to the turbo:
fitment of the high flow cat and beggining of the dp construction:
tacking things up:
final product of dp:
placement of charge pipe:
and then putting things back together (and my cousin always getting in my shots):
grkguy89 is offline
Old 07-29-2009, 07:44 PM   #5
132417SAAB's Avatar
what are you going to run for boost and engine manegment?
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 07-29-2009, 07:59 PM   #6
Greek Mod
grkguy89's Avatar
MAF and using a boost controller to try and peak at bout 8psi
but my base boost is really low... gotta fix that
been driving the car since last sunday... no problems
grkguy89 is offline
Old 07-29-2009, 08:22 PM   #7
saabhater09's Avatar
turbo
Are the internals of ng900 less beefy than the 2.0 or are they the same?
MY SAAB 9-3
saabhater09 is offline
Old 07-29-2009, 09:17 PM   #8
User
zingZACH's Avatar
This has me worried...
In most cases, boosting a somewhat high compression motor (10.5:1) without an ecu tune providing the car with the needed fuel, you are going to be leaning out and is essentially like holding an m80 in a closed fist. BOOM
I'll be very shocked if this lasts.
1988 900 Springtime in Sweden
zingZACH is offline
Old 07-29-2009, 09:30 PM   #9
Castor Troy's Avatar
i too am curious to see how it runs from here
Castor Troy is offline
Old 07-29-2009, 10:31 PM   #10
comtrang's Avatar
Yeah I really hope for your sake things hold out! But you really should look into some kind of stand alone or something if you want it to really last. Not sure how much of a beating the motor's gonna take but I guess you'll find out.
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 07-30-2009, 05:10 AM   #11
8valvegrowl's Avatar
I would definitely get a wideband on there and keep the boost low (5-6psi). Do you have any way to datalog?
Once you find a way to enrich the fuel a bit then maybe use the boost controller to dial the boost up some.
Props for being adventurous!
8valvegrowl is offline
Old 07-30-2009, 05:28 AM   #12
kingofkrunk's Avatar
so ... in theory if he converted to t5 and had lower compression pistons, like forged and dished pistons, this would be quite the quick little ng .... correct? ... not that i have a spare 2.3L kicking around in my yard from an n/a ng that im contemplating building lol
kingofkrunk is offline
Old 07-30-2009, 08:17 AM   #13
coreyeroc's Avatar
great job - most of us arent that productive!! Good luck with it, hope the motor holds.
coreyeroc is offline
Old 07-30-2009, 08:42 AM   #14
ohlins8990's Avatar
Send a message via AIM to ohlins8990 Send a message via Yahoo to ohlins8990
I have no doubts the block will hold up fine, the internals are very close to the b234R. But it needs a tune to do this. The NA ECU doesnt have fueling to run boost.
ohlins8990 is offline
Old 07-30-2009, 09:53 AM   #15
Greek Mod
grkguy89's Avatar
i have 2 t5 harnesses at my disposal along with a t5 ecu and dic (and a b204r)
if jzw or jak stol created a tune or could make a tune i may consider in converting to t5....eventually
but i see no reason for my car to have fuelling problems with the bigger injectors i put in
grkguy89 is offline
Old 07-30-2009, 09:56 AM   #16
i say buy a wideband o2 sensor as well .... you will be running very rich on idle, then when you go into boost ... it will correct it temporarily, but its hard to say if it will be enough fuel to keep from leaning out further into boost .... a wideband IMO is cheap considering it gives you peace of mind knowing what is going on ..... knowledge is everything
just my opinion, that is what i would do
Old 07-30-2009, 10:36 AM   #17
Greek Mod
grkguy89's Avatar
why?
grkguy89 is offline
Old 07-30-2009, 10:46 AM   #18
the injectors have a duty cycle controlled by the ecu .... if you have bigger injectors, but run the same tune, more fuel is being injected .... running propertionally rich
Old 07-30-2009, 10:47 AM   #19
because the stock maps are programmed for a specific size fuel injector at a specific fuel pressure. it will most likely not be able to compensate for larger injectors, meaning very rich (possibly to the point of not running, ESPECIALLY on cold start) while at idle. you'll run rich throughout the entire rpm range, except when under boost.
Old 07-30-2009, 10:52 AM   #20
Greek Mod
grkguy89's Avatar
then why do cars have o2 sensors?
so they can smell the roses in the morning?
my car starts up no problem every morning since i installed the turbo
grkguy89 is offline
