bpv question. - The Saab Link Forums
Old 07-18-2009, 07:14 PM   #1
acf101's Avatar
bpv question.
this week i plan to make a homemade air intake. but while i was under the hood i wanted to take off the hose that goes from the bpv to the intake pipe. so it releases into the air. that way i get more of a whooosseee! is this okay to do? no filter needs to be attachted? negitive side effects? this is temporary until i get a forge bov in a month or two. thanks for any help!
- Andrew
acf101 is offline
Old 07-18-2009, 07:26 PM   #2
It will make the WOOOOOOSH sounds
You don't need a filter
It will not mess up your engine or anything.
Here is my custom intake just to give you an idea.
1994 9000 Aero - Sold
1999 Stage 3+ 93 - Current
9k aero is offline
Old 07-18-2009, 07:31 PM   #3
acf101's Avatar
nice man! i figure i could prob do the same sorta set up for about $50ish. drawling in air from behind the headlight mostly?
acf101 is offline
Old 07-18-2009, 07:57 PM   #4
Legit's Avatar
Just make sure to block off the hole in your intake pipe
2002 Viggen Convertible
Legit is offline
Old 07-18-2009, 08:06 PM   #5
acf101's Avatar
i know gs sells plugs. but until that gets shipped here any temperary plug ideas?
acf101 is offline
Old 07-18-2009, 08:31 PM   #6
Legit's Avatar
people have used coke bottle caps, but you should just wait for your plug
Legit is offline
Old 07-18-2009, 08:41 PM   #7
acf101's Avatar
what about a mini breather filter? i believe i have one laying around instead of a plug.
acf101 is offline
Old 07-18-2009, 08:51 PM   #8
Legit's Avatar
to put on your intake hole? you need something that completely blocks it off
Legit is offline
Old 07-18-2009, 08:55 PM   #9
acf101's Avatar
hmm okay, i think i will just wait until i get a new plug in. as well as a new hi temp hose for the bpv. until then i will focus on the custom intake.
acf101 is offline
Old 07-18-2009, 09:15 PM   #10
Legit's Avatar
You should get 15 feet of 3.5mm or 4mm silicone hoses for the vacuum lines. Im sure someone has the diagram for T5 vacuum lines somewhere
Legit is offline
Old 07-19-2009, 07:24 AM   #11
acf101's Avatar
yep we think alike, i was going to order some and redo all the lines. you need about 12 feet to do everything right?
acf101 is offline
Old 07-19-2009, 08:43 AM   #12
I ordered 15 just to be safe and Its been nice to have a little extra lying around just in case...its only what $1.50 per foot? I think you can probably do it with 10 feet if you pre-measure thoroughly.
2000 9-3 h.o.t.
J93O is offline
Old 07-19-2009, 09:23 AM   #13
Legit's Avatar
Yes, its 12 feet but its always good to have extra
Legit is offline
Old 07-19-2009, 01:02 PM   #14
acf101's Avatar
agreed, you find the hose diagram for the all the hoses? i cant seem to find it..... i remember seeing a thread before.
acf101 is offline
Old 07-19-2009, 01:54 PM   #15
christian900se's Avatar
There are very few vacuum lines to replace on a T5 car. The BPV line, the line that goes from the PCV barb to the throttle body, and a few others that are pretty obvious.
christian900se is offline
Old 07-20-2009, 05:34 PM   #16
132417SAAB's Avatar
just do what I do; when I want to replace a vac line I take off one side of the old one and put the new one on. The I follow the old line to where it was connected at the other end and put the new vac line on; that way you dont get confused
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 07-20-2009, 07:41 PM   #17
acf101's Avatar
Hey i got my intake in... however its really close to the belt that is under the intake hose. i see you have a large bend. what size is that? where did you get it...? i sorta need one bad
acf101 is offline
Old 07-20-2009, 07:44 PM   #18
ehh, mines really close to the belt, but it is fine. Make sure it wont move and doesn't touch and you should be all good.
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 07-20-2009, 07:47 PM   #19
acf101's Avatar
well i had to leave the bottom of the air box in as a temporary to hold up the filter so it wont hit, kinda want a more stable and reliable solution. haha
acf101 is offline
