Recommendation on a Cat - The Saab Link Forums
Old 07-08-2009, 03:40 PM   #1
christian900se's Avatar
So that CEL came back for the rear o2 sensor. My mechanic, John Williams, and the readings from the tech 2 seem to lead to the magnaflow cat that is in my exhaust now takes too long to warm up. It warms up after the 'startup' procedure for the o2 sensors are over and is throwing the CEL.
So this means that I am looking to get a new cat. I had my eye on the GS race cat, but was wondering if you guys have some recommendations?
Thanks as always!
Edit: The reason how I know the cat takes too long is that on the tech 2, you can see how the pulsing current from the o2 sensors are graphed on screen. It also indicates the pre-heater as well, which were all reading normal as were the voltage readings from both sensors. The upstream sensor would shoot right up and start ossilating while the rear would take a very long time to come up (wave length was excessively long until driven). If anyone has a re-occuring CEL for the rear o2 sensor, that may be the cause.
christian900se is offline
Old 07-08-2009, 04:20 PM   #2
Harvey's Autohaus's Avatar
Thanks as always!
Good Luck with that thoery, Thats Very Similar to How they work Properly too...Maybe add a Ground Strap to your cat first. And solder the Wiring harness outside of the firewall Below the strut bar. Thats where the Crimps that need atention for the O2s are. Resolder those.The ones in the Main Engine harness. Both of those fixes are for "96 model year only" O2 Code's Per old Saab tsb's from the 90's And yes they do fix the problems too. For Free.
HakbarSAABzzz
Harvey's Autohaus is offline
Old 07-08-2009, 04:23 PM   #3
Castor Troy's Avatar
cross posting
Castor Troy is offline
Old 07-08-2009, 04:23 PM   #4
Hmmm, my car is a 1996. The junction for the o2 sensor in the main harness was replaced, before the o2 sensor just so it was sure that was not the issue.
Old 07-08-2009, 04:24 PM   #5
Originally Posted by Castor Troy View Post
cross posting
haha, I changed it alittle bit for you
Old 07-08-2009, 04:44 PM   #6
Now see, I would have recommended a Calico.
But obviously you're talking about different kinds of cats here.
-- My Fleet --
1988 Saab 900 SPG Project DD - Just passed 270k
1996 Saab 9000 CSE Benchwarmer - About to hit 200k
zmhdesigns is offline
Old 07-08-2009, 05:09 PM   #7
Thats why I said cats, there seems to be quite a following here haha. Yep, different cats
Old 07-08-2009, 05:50 PM   #8
LOL. I have a Calico. I hate it. I am quite fond of my V2 Dp though. Christian, at these crazy power levels, you do have an aftermarket DP right ??
2004 Silverado 2500HD Crew cab LT 6.0 LQ4, K+N intake, Magnaflow dual exhaust. Diablosport tuner.
2000 Viggen Vert *Gone - buy/enjoy my parts!
2010 Corolla S I dig it.
Marksy is offline
Old 07-08-2009, 07:03 PM   #9
Nope, stock exhaust*
JSP 3" exhaust, the welds arent great so when I have a new cat put in, I will have some pin holes welded up as well.
Old 07-09-2009, 10:52 AM   #10
JZW
I forgot to tell you another method that has worked for quite a few people. There is something called a plug fouler and that has worked very well to keep the second 02 sensor from throwing a cel. You go to the parts store and buy 2 of the plug foulers, hollow out one of them so the threads of the 02 sensor can go through it and then thread in the 02 sensor through the second one and that will dampen the signals so you do not get the cel for too high or too low of a current.
This may be worth a shot as its only about 9 bucks and it has helped many people to avoid those pesky rear 02 sensor cels. The other option is having me turn off the rear 02.
good luck,
John
JZW is offline
