My Holset needs a new turbine wheel/shaft and rebuild.... :( - The Saab Link Forums
Old 06-25-2009, 06:55 PM   #1
Moosepuck's Avatar
Unhappy My Holset needs a new turbine wheel/shaft and rebuild.... :(
I believe if I put a new turbine wheel in it, it needs to be balanced. The "very slight side play" I was told about is enough to make the compressor wheel hit the housing. Does anyone know a good place to have a turbo rebuilt at? I thought there used to be someone that used to advertise on Saab Net, but I didn't see it just now. It really sucks, but I suppose after all is said and done, I'll have a really nice and fresh turbo......
06 W211 E55 AMG (his)
08 9-3, Aero vert, 2.8t(hers)
Gone but not forgotten: several NG' and C's
Moosepuck is offline
Old 06-25-2009, 07:11 PM   #2
christian900se's Avatar
Go on the dodge forums, there are a dozen turbo rebuilders on there specializing in Holsets.
christian900se is offline
Old 06-25-2009, 07:14 PM   #3
Moosepuck's Avatar
good idea, thanks... I'll check it out tomorrow, I found the guy I was looking for "Chadwick"...
Old 06-25-2009, 08:31 PM   #4
BurnsSide42's Avatar
or for under $200 get another unit....
Check out
for your repair needs
BurnsSide42 is offline
Old 06-25-2009, 08:51 PM   #5
Castor Troy's Avatar
www.gpopshop.com
Castor Troy is offline
Old 06-26-2009, 05:36 AM   #6
Moosepuck's Avatar
I guess I'm going to try my luck on another used one. After a professional rebuild and the new turbine and shaft, It'll be close to $600.... If I could do it myself, I would, but the assembly balancing with the new shaft has to be done by someone that's equipped to do so. So, back to the classifieds.
Old 06-26-2009, 06:28 AM   #7
JZW
That sux! Keep looking, good deals come up every now and then,
John
JZW is offline
Old 06-26-2009, 08:24 AM   #8
a12
a12's Avatar
Can't you just send the shaft and wheels out for balance and rebuild the thing yourself? I have seen prices of like $50 to balance and rebuild kits are like $100 I think.
a12 is offline
Old 06-26-2009, 10:05 AM   #9
comtrang's Avatar
I think rebuild kits are even less than that, I wanna say $45.
I read something interesting about using the newer ones off of Dodge Rams that can alter the exhaust housing size, or something like that. Several people have made this work to great success. Something to think about if you come across a cheap one and feel like being different
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 06-26-2009, 10:23 AM   #10
gpopshop should be able to take care of you for less than $350.
Old 06-28-2009, 06:52 PM   #11
Moosepuck's Avatar
John
Yes....yes it does, still searching...\
I'll check into this for sure, thanks for the idea.
Nope, that's JUST the rebuild, the new turbine/shaft assembly is another $165 at least.....
Old 06-29-2009, 12:03 PM   #12
I think that if you go to a place like Gpop, you will have a warrantied rebuilt turbo that will last you a long time for more money.
But, you can try and find another Holset but run the risk of having another one just like this.
The choices!
Old 06-29-2009, 12:39 PM   #13
Moosepuck's Avatar
yeah, I know... I have no doubt that Gpop would do a top notch job. ... Just got it in the mail today from Vigge and it looks great! Very heavy duty! Need to do something soon!
Old 06-30-2009, 11:24 AM   #14
comtrang's Avatar
HX40 with a billet compressor wheel for $400.
http://kcsr.org/showthread.php?t=25085
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 06-30-2009, 11:37 AM   #15
Moosepuck's Avatar
Thanks for looking out, but I'm going to stick with the 35, maybe it'll take longer to blow something up that way...
Old 07-02-2009, 09:13 AM   #16
Green9kAERO's Avatar
im told the wheels are individually banlenced so you could put a good one on yourself??
Green9kAERO is offline
Old 07-05-2009, 06:22 PM   #17
Moosepuck's Avatar
yep, I've been told all of the parts are "zero balanced".... but I've also been advised that I really 'should' have the assembly professionally balanced... I'm still tossing the idea around of just getting the parts and doing it myself without the balancing.... If I can find a reasonably priced hx35 12cm again soon, that's probably what I'll do.
