sub-frame-skid plate in the works - The Saab Link Forums
Old 06-24-2009, 11:07 PM   #1
JZW
Some testing of this new skid plate/sub-frame brace is in the works, see how well it works, maybe see if people may want to try it.
John
JZW is offline
Old 06-25-2009, 12:30 AM   #2
Supergreensol's Avatar
Definitely interested...will this work with the GS 6 pt brace?
'95 900se Vert Black on Black...RIP
"If you pull the pan and find anything other than what I described, I'll eat a pile of hammers." ~spgproject
Supergreensol is offline
Old 06-25-2009, 05:26 AM   #3
Defiantly interested, when I get the car back together.
OcCrew is offline
Old 06-25-2009, 05:38 AM   #4
Subframe/skidplate
The welds are part of the skidplate. The complete unit bolts to the subfrome with four bolts on each side. It can be installed from under the car easily. It should support the subframe as well as any of the multy point attachment systems.
Once installed, Removing is a 5 minute job if necessary.
The cutouts can easily be enlarged to make clearance for exaust mods and easiy access to oil filter ect.
Should have it on car and running next week.
I have busted two oil pans on some of my off road excursions, one in my Aero and one in my Viggen.
MTAERO is offline
Old 06-25-2009, 07:14 AM   #5
mvadenais's Avatar
How are you going to test it? Shitty roads? Have a lot of people been killing their undersides
88 900 SPG Black
95 9000 Aero Green
00 9-3 Viggen Silver
mvadenais is offline
Old 06-25-2009, 07:34 AM   #6
mcrowley's Avatar
Interested...
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 06-25-2009, 07:36 AM   #7
srp
srp's Avatar
Send a message via AIM to srp
Very cool. Also interested. Will it cover the oil pan? Or just make the surface level leading up to it?
srp is offline
Old 06-25-2009, 07:42 AM   #8
aireeca's Avatar
You never know when the spirit to go rallying will strike.
You might ask Codesplice to snap a photo of his Saab Savior 9-3 skid plate. I saw it a few weekends ago and it looked pretty neat and has, if I remember right, a removable access panel for oil changes.
aireeca is offline
Old 06-25-2009, 07:47 AM   #9
srp
srp's Avatar
Still on the website: http://www.saabsavior.com/9-3_NG900.html
srp is offline
Old 06-25-2009, 07:49 AM   #10
Castor Troy's Avatar
supergreensol, this would take the place of the 6pt brace
i may pick one of these up, depending on their price. my car is ridiculously low
ETA: SRP, IIRC most of the custom products on their website are not actually available anymore
Castor Troy is offline
Old 06-25-2009, 07:52 AM   #11
srp
srp's Avatar
Yup, I know there not available. Just providing a picture as reference.
srp is offline
Old 06-25-2009, 08:00 AM   #12
christian900se's Avatar
How will this compare in terms of structural rigidity to the GS 6pt? If its stiffer and lower profile, I am down to try it out.
christian900se is offline
Old 06-25-2009, 08:01 AM   #13
codesplice's Avatar
Originally Posted by srp View Post
That's the one. Except mine has some pretty deep gouges in it. I think buying that was money well-spent. I love the access panel for the oil filter, and it also has a cut-out in the rear which perfectly matches the trajectory that oil takes on its way out through the drain hole on the pan. Makes oil changes a breeze.
I don't like the way it mounts, namely with spacers. It wasn't designed to bolt up flush to the subframe (which I'm not even sure is possible given clearances underneath). It's great for catching rocks and gravel and the like, but I'm not sure it would survive a hard crash-landing. I like to think that it would at least soften the blow to my oil pan.
I would definitely be interested in swapping to a new style skidplate that I could be more confident with. I'm waiting anxiously to see what you guys can cook up
2001 9-3 - Nordic Stage 3
2007 9-5 2.3T Wagon
codesplice is offline
Old 06-25-2009, 08:31 AM   #14
i'll be in a need of a 6point brace. whoever gets this, sell me your 6point!
rafal is offline
Old 06-25-2009, 08:45 AM   #15
Yes, it will keep me from landing on my oil pan during porshe rallys.
Old 06-25-2009, 09:00 AM   #16
WASSAB Member
Immo's Avatar
Send a message via AIM to Immo Send a message via MSN to Immo Send a message via Yahoo to Immo Send a message via Skype™ to Immo
Originally Posted by tweek's turbos View Post
yes, it will keep me from landing on my oil pan during porshe rallys.
lol!!!!
2001 9-3 HOT SE 5 Door Sold
2003 9-3 2.0T Arc 4 Door Sold
1985 900 SPG Sold
2002 9-3 Viggen Convertible (Silver w/Blue Top)
2010 Jeep GC SRT-8
Immo is offline
Old 06-25-2009, 09:23 AM   #17
interested for sure.
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 06-25-2009, 09:47 AM   #18
me2!
99 lb viggen
dcr99vig is offline
Old 06-25-2009, 10:40 AM   #19
lms
Wasn't one of the main reasons that Nick did not make one like this was in regards to heat buildup?
lms is offline
Old 06-25-2009, 10:42 AM   #20
Originally Posted by dcr99vig View Post
me2!
Me3 ; I need one for the Viggen vert and I'm interested in thew skid plate too but how thick is the metal gonna be and how would the regidity be compared to Gs's 6 point brace?
hkayssi is offline
