Clutch hydraulic fitting size? - The Saab Link Forums
Old 06-24-2009, 10:40 AM   #1
Castor Troy's Avatar
So I'm going to be converting my 900 to hydraulic clutch shortly. I will be using a teflon/braided stainless line instead of the factory soft hose. However, I need to know the size of the fittings on the clutch master, and the clutch slave. Does anybody have one out and about that they could measure for me, or know off the top of their head?
Thanks!
Castor Troy is offline
Old 06-24-2009, 10:45 AM   #2
srp
srp's Avatar
Send a message via AIM to srp
I have one I should be able to measure this weekend.
srp is offline
Old 06-24-2009, 08:44 PM   #3
NahumCC's Avatar
Well the clutch master doesn't have a threaded fitting. It's a push fitting with an O-ring that seals it tight. A cotter pin is then used to keep it in place. Same story down at the slave pretty much other than its a block fitting.
Also the og9-3 clutch line is metal all except for a short section. I would think any good hydraulic shop would/should be able to change that section out for a braided section.
Just saying.
2013 FR-S
NahumCC is offline
Old 06-25-2009, 12:24 PM   #4
spgeebee88's Avatar
i Heart those lines sooooooooo easy
spgeebee88 is offline
Old 06-25-2009, 12:28 PM   #5
NahumCC's Avatar
Except bleeding sucks. Would have been nice if they made the bleed valve post slave cylinder like on the 9000 to make sure you have all the air out.......just saying.
2013 FR-S
NahumCC is offline
Old 06-25-2009, 12:32 PM   #6
spgeebee88's Avatar
well ya you just got to remember to bleed the slave b4 you put the transaxle back in... if ya dont your F'ddd
Old 06-25-2009, 12:41 PM   #7
NahumCC's Avatar
Yeah...........I've put that together. Just haven't torn back into it to get it all out of the way to rebleed the slave directly from above with the trans still attached to the car.
I did bleed it but not well enough apparently. Oh well, one day it'll get done and seeing as I did the master recently the entire thing is brand new except that line.
2013 FR-S
NahumCC is offline
