T5.5 97 and up ECU's? - The Saab Link Forums
Old 06-05-2009, 05:03 AM   #1
VWSAABVT's Avatar
Just wanna double check what years had T5.5
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 06-05-2009, 05:06 AM   #2
JK
JK's Avatar
in the US:
1994-1998 ng900s turbos
1999 non-Viggen 9-3s
1994-1998 9000 turbo and non-turbo
always a SAAB guy at heart
JK is offline
Old 06-05-2009, 05:24 AM   #3
VWSAABVT's Avatar
ok what about the 20 mhz ones? I'm trying to grab one for someone with a 99 9-3 and I know that they need the 20 mhz ones to run vs the 16
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 06-05-2009, 05:48 AM   #4
JK
JK's Avatar
Not sure what year they changed from 16 to 20mhz, but that was not your original question. You asked what years were T5.5. Some of those years were 16, some were 20, but they are all T5.5 ECUs.
And yes, I suggest using the 20mhz on the cars that should have them. I was running a 16mhz on my 9-3 as an experiment, then my other 20 mhz box wouldn't reflash correctly anymore...so I'm currently stuck with the 16 in there. It seems "dumber."
JK is offline
Old 06-05-2009, 05:56 AM   #5
DeLorean's Avatar
There is no logic to what ones are a 20 MHZ. We were thinking maybe OBD2, but no. Just last week, I pulled 2 core ECU's, one from a 1996 9000-CS, and one from a 1995 9000 CS "super" (Basically a CSE), and the 96 was a 16 mhz, the 95 was a 20.
If you are specifically looking for a 20 MHZ, pull it apart in the junk yard and check before you buy it. That's really the only way to tell. Also, FYI, the T 5.2 cars are usually 20 mhz, but clearly you can't use those on a T5.5 car.
DeLorean is offline
Old 06-05-2009, 11:49 AM   #6
In the US, from what I understand, 97 and up are 20mhz models
The 16mhz models can work in cars that are used to 20mhz as long as they are still running a 16mhz program (its flashed onto them)
Some people have 16mhz ecus running 20mhz programs and vice versa, I one way with no problem the other with a few glitches, though I wouldn't recommend this!
If you open up the ecu you can see if the processors model ends in 20 or 16 and that will be the best way to tell but if you get 97 and up you should be fine!
Just make sure you get a trionic and dont fall for one of those people selling the motronic (non turbo) that you see on ebay all the time!
yoursolace is offline
