308mm Front Brakes & SS Lines Project - The Saab Link Forums
Old 06-04-2009, 01:40 PM   #1
Passenger 57's Avatar
I decided to rewrite this so that it made a bit more sense and I could address some issues that I had with the install.
A little history… I bought a full set of 308mm front brakes off a 01 9-5 Aero & 300mm rear brakes off a 02 9-5 from EFA, elite foreign auto, and Goodridge stainless lines off 93forum last year and finally got around to installing the fronts on 6/3. I used Dip's DIY write up as a guide and everything went rather smoothly except for the dust shields which had to be drilled to get the bolts off. I prepped the calipers and rotors with some good degreaser and some wire wheels on an electric drill. If you have a vise wire brushing the calipers will be 100 time easier, I didn’t so it took a lot longer. I painted everything except the hats on the front rotors the week before with a kit I got from G3. It uses a 2 part epoxy paint that you brush on. I was very impressed by how easy it was to apply and how much you could cover with such a seemingly small amount of paint. One could easily cover 4 calipers and all 4 hats of the rotors. My only recommendation would be to use a bigger brush than what comes in the kit.
I didn’t prep the hats on the front rotors when I painted the calipers so I had to paint them later. When I did I used some black duplicolor caliper spray paint. This stuff worked great as well!! At this point I cant recommend the G3 kit or the duplicolor caliper paint, we’ll see which one holds up better. I used ATE super blue for fresh brake fluid.
Initially I wanted to do braking distance tests, stock vs. 308mm fronts vs. 308mm fronts & 300mm rears, but time constraints and weather conspired against me. The 300mm rears were installed on Sat. 6/6. It took my friend and me all day to complete this job. We had to do some modify some brackets that hold the E-brake springs in place so that they would work with the new calipers. The pics below show the brackets after we modified and installed them. Another issue we had was the clips that hold the lines in place weren’t that effective. We installed them but you could probably get away with leaving them out. Finally, one of the rear rotors was warped or not true and didn’t spin all that freely, oh well… Also the right front brake pad isn’t contacting the rotor completely as you can see in the picture. I would highly recommend that you get new rotors and pads if you do this upgrade to avoid issues like these. Be aware that 16in wheels will be the smallest you can fit with 308mm brakes.
As far as improved braking and pedal feel, I am a bit disappointed, my pedal is still a little mushy. The car feels like it is stopping better but I was expecting better pedal feel. I may try and bleed all the calipers again to see if it improves, new pads and rotors should help as well. Cosmetically, the car looks great!! The rotors fill up the wheels nicely, especially in the rear.
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”
Passenger 57 is offline
Old 06-04-2009, 02:15 PM   #2
It's an awesome difference. In recent history I have done mine, Rudedog's and soon Immo's.
The peddle should be nice and stiff.
Old 06-04-2009, 06:46 PM   #3
srp
srp's Avatar
Send a message via AIM to srp
Pedal feel should increase more once you flush the whole system.
srp is offline
Old 06-04-2009, 06:57 PM   #4
WASSAB Member
Immo's Avatar
Send a message via AIM to Immo Send a message via MSN to Immo Send a message via Yahoo to Immo Send a message via Skype™ to Immo
Can't wait!
2001 9-3 HOT SE 5 Door Sold
2003 9-3 2.0T Arc 4 Door Sold
1985 900 SPG Sold
2002 9-3 Viggen Convertible (Silver w/Blue Top)
2010 Jeep GC SRT-8
Immo is offline
Old 06-04-2009, 07:07 PM   #5
WASSAB Member
Immo's Avatar
Here is a nice 300mm Rear Brake kit
http://www.genuinesaab.com/catalog/p...products_id=70
1985 900 SPG Sold
2010 Jeep GC SRT-8
Immo is offline
Old 06-04-2009, 07:14 PM   #6
srp
srp's Avatar
I ended up buying the kit from GS. Every place I called wanted $200 or more for the rear calipers and carriers used.
$200.00(+/-) for Calipers and carriers
$152.00 for rotors
$67.20 for pads
$63.00 for the custom brake lines
=$482.20
Kit from GS = $589.45 and is brand new parts.
I think it was cheaper when I bought it.
srp is offline
Old 06-05-2009, 03:07 PM   #7
nice.....
still newbie to Saab.. i know the 308mm front rotor is essentially Viggen sized..
tell me,i imagine that there should be some sort of new mounting point for the calipers...so, what hardware is needed to adapt this size to a regular 9'3..
and would stock 9'3 calipers still work?
can i go out and just purchase Viggen calipers & rotors and have a bolt in affair?
let me know... thanks !!
--Hayden--
'99 9'3 Coupe
'87 BMW E30 Track Rat
'92 Integra GS-R
Haydende is offline
Old 06-05-2009, 09:15 PM   #8
srp
srp's Avatar
You don't even need the calipers. Yours are "the same" as Viggen/Aero's. You just need the carriers from a 00-01 9-5 Aero or 99-02 Viggen(might be off by a year or two). Unfortunately most yards won't sell just the carrier.
Elite has some for sale right now. https://saablink.net/forum/showthread.php?t=39046
srp is offline
Old 06-07-2009, 01:46 PM   #9
thanks for the info...
--Hayden--
'99 9'3 Coupe
'92 Integra GS-R
Haydende is offline
Old 06-09-2009, 07:54 PM   #10
saabskijc's Avatar
So if one was to get those calipers and carriers what else would u need to get viggen brakes upfront obviously rotors and pads anything else
saabskijc is offline
Old 06-09-2009, 08:12 PM   #11
Castor Troy's Avatar
all you need are the caliper carriers(aka caliper brackets) and the rotors. the backing plates are different, but you can bend your old one back, or remove it.
everything else is the same (pads, lines, calipers).
Castor Troy is offline
Old 06-11-2009, 12:50 PM   #12
added a few pics
Old 06-11-2009, 12:55 PM   #13
looks very good!
Old 06-11-2009, 01:17 PM   #14
JK
JK's Avatar
$70 for carriers or $100 for the carriers and calipers. Seems odd that they only want $25 for a pair of carrierless calipers but want $70 for the carriers. :shrugs:
Still a pretty good price!
always a SAAB guy at heart
JK is offline
Old 06-12-2009, 11:06 AM   #15
More pics added
Old 06-12-2009, 11:13 AM   #16
Originally Posted by Passenger 57 View Post
More pics added
www.imageshack.us
your pics are way too small.
rafal is offline
Old 06-12-2009, 03:03 PM   #17
srp
srp's Avatar
Originally Posted by rafal View Post
www.imageshack.us
Yeah they are lol!
Either way. Well done!
srp is offline
Old 06-16-2009, 12:43 PM   #18
Pics fixed...
Tags
308mm brakes, aero brakes, caliper paint, viggen brakes
