Clutch stuff. - The Saab Link Forums
Old 05-30-2009, 09:21 AM   #1
stig's Avatar
Clutch stuff.
Whelp, it appears I'm kinda taking on a new project. Looking at clutch options.
Right now the car has somewhere around 140k on it. It has a blown trans, so it's coming out anyway and I'd rather just have to rip it all apart once.
The car is a '95 900SET and will have an N/A trans.
It's mostly going to be my race beater, and will hopefully be tuned at some point.
So, options. Viggen pressure plates are supposed to be stronger/hold more power than the stock one, correct? If I go Vig PP, what should I use for a disk? Will a stock disk + Vig PP hold up to, say, stage 3 power? How much should I expect to pay for one, and how bad of an idea is a used one?
'96 Miata - Simplify and add lightness
'96 9000 Aero - Complicate and add torque steer
stig is offline
Old 05-30-2009, 09:49 AM   #2
132417SAAB's Avatar
the big thing with viggen pressure plate and still using the clutch cable is the amount of force required. Alot of people here dont like that and will also do the hyrdo conversion also which will run you another 400ish in parts alone. Can anyone here confirm if just a regular ng900 turbo clutch will hold stg 3?
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 05-30-2009, 10:41 AM   #3
Green9kAERO's Avatar
hydro conversion FTW.....
I HATE CABLE CLUTCHES!.
Green9kAERO is offline
Old 05-30-2009, 09:21 PM   #4
stig's Avatar
Hydro conversion also = $$$
The clutch in that car takes a LOT more force than mine. I got used to it in about a day lol.
stig is offline
Old 05-30-2009, 09:27 PM   #5
turbojohnny's Avatar
if you go to GS and order the vig clutch kit (viggen PP and disk)it will hold stg 3 power perfectly. that's what i've used in my car for the longest time, it was also not bad with the cable clutch.
edit: link...
http://www.genuinesaab.com/catalog/p...roducts_id=155
turbojohnny is offline
Old 05-31-2009, 03:14 AM   #6
stig's Avatar
Alright cool.
I think I'm just gonna throw the trans in for now. By the time I have $$$ to do what I want to do in there... I dunno, but it'll take a long time
stig is offline
Old 06-01-2009, 12:15 PM   #7
Nick Taliaferro
GenuineSaab's Avatar
We run a stg3 disk, vig pp and alu flywheel in the drag car. If you keep the torque spike reasonable in the tuning it will be fine and the gearbox will be your friend.
Nicholas Taliaferro
GenuineSaab is offline
Old 06-01-2009, 05:29 PM   #8
That NA box is going to make the car a beast!
Old 06-01-2009, 05:36 PM   #9
Castor Troy's Avatar
parts for the hydro conversion cost me $250; most of that was the cost of a new slave cylinder.
Castor Troy is offline
Old 06-01-2009, 06:18 PM   #10
viggenkid's Avatar
do the hydro clutch conversion while your at it.
viggenkid is offline
Old 06-01-2009, 08:34 PM   #11
My car is hydro already so I just took out the throwout bearing from my N/A tranny and threw in the slave cylinder and hooked back all the lines.
1998TurboSaab is offline
Old 06-02-2009, 03:45 AM   #12
stig's Avatar
Is there any benefit to the hydro conversion other than a lighter pedal?
stig is offline
Old 06-02-2009, 04:26 AM   #13
mcrowley's Avatar
Its reliable.
My car has a viggen pp/stage 3 clutch setup. I drove it for a little over a year with the cable setup....absolutely awful. Hydraulic is without question the way to go.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 06-02-2009, 05:03 AM   #14
8valvegrowl's Avatar
N/A NG900 gearing is no different than 99+ 9-3 gearing, every ratio is the same except third [1.12 vs 1.18]. NG Turbos had a taller final drive, but 9-3s have 4.05 just like the N/A NG's.
While its better than the NG turbo gearboxes, it's not as dramatic a difference as one would think. I really wish I had a F25 option for a slightly taller 1st and close 1, 2, 3 (without going to the quaife 6-speed, which is spectacularly awesome and spectacularly spendy), that and a cheaper LSD option and I'd be a happy man....
FWIW, the stock clutch/PP will hold stg3 power, but probably not for very long. Viggen clutch/PP is the best cheap option for stg 3 2.0 cars IMO.
8valvegrowl is offline
